SAMD20 timers based interrupt
5 posts / 0 new
Hi guys
I have just started working on SAMD20 and trying to make the timers work using ASF from the last two weeks but not getting any luck.
I am trying to debug it but not getting there.
Can anyone help me to understand the timers, i have gone through the datasheet but not making much sense to me and using ASF application but still it is not working.
I am trying to get the interrupt and make the led on after 2 seconds and then again turn that off after 10 seconds.
I have never worked on ARM before.
Your help will be much appreciated.
It's a matter of start when you do, you find self confidence.
You have some variables that probably need to be "volatile."
Thanks!, I will try and will see if that works.
How did you calculate the time that you want?
Where can I find a way to calculate the timer that I'm looking for? (1ms)
Where do you increment the counter1 and counter2?
There is no counter1 at all in the code...
Increment of counter2:
    // HERE:
	if((++counter2 > 31) && (timer1_flag==0 ))//2.04 sec
	// and HERE:
	else if((++counter2 > 155) && (timer2_flag==1))//10.04 sec
