128x64 GLCD (KS0108) Text Orientation
16 posts / 0 new
Hello everyone,
I am using Fabian Maximilian Thiele library and my GLCD is working very well. However I am having hard time to display text in portrait mode. Is there a way to display portrait text? Any input is highly appreciated.
Niral
I guess this is probably obvious but I'll say it anyway. In this code:
        // last but not least, draw the character
	for(uint8_t i=0; i<bytes; i++) {
		uint8_t page = i*width;
		for(uint8_t j=0; j<width; j++) {
			uint8_t data = ks0108FontRead(ks0108Font+index+page+j);
			if(height < (i+1)*8) {
				data >>= (i+1)*8-height;
			if(ks0108FontColor == BLACK) {
				ks0108WriteData(data);
			} else {
				ks0108WriteData(~data);
		// 1px gap between chars
			ks0108WriteData(0x00);
		} else {
			ks0108WriteData(0xFF);
		ks0108GotoXY(x, ks0108Coord.y+8);
You need to switch the X and Y directions.
Till now I have used it in landscape mode. But now I have to use portrait mode. I have try to switch X and Y position but text is not rotating.
Thank you,
nIk
Show what you changed.
At the end of the day a character is just a rectangle of dots. To drawy it you go up/down the Y and across the X. So to rotate you should use the same data but now draw by going across the X then up/down the Y within that instead.
BTW In the above code both the data and the screen are being indexed by the same i/j. You will have to break that link obviously.
I have changed position of X and Y but it places new character slightly lower than previous char for all. I want to rotate text.
				} else {
			} else {
		ks0108GotoXY(y, ks0108Coord.x+8);
	ks0108GotoXY(y+width+1, x);
	return 0;
So perhaps an index is off by one?
note that you can also most likely rotate the display, it has an inverse X and inverse Y bit in a register by swapping these you can write test in any direction you want ans this will give the orientation of the display.
It has been a long time since I played with a 108 display and do not have the code at work, but it should be very obvious from the datasheet.
Hello everyone,
I have switched to universal library for KS0108 and created customized fonts and that works..
nIk
For the benefit of future readers:
Would you care to give a link for that?
And would you care to give a link for that?
and that works..
Excellent. Now please mark the thread as solved: http://www.avrfreaks.net/comment...
AFAIK Thiele's web site (http://www.apetech.de) is no more. His LCD library is floating around as copies here and there on the Web. E.g.: http://www.codeforge.com/article...
Indeed.
Which is why it would be particularly helpful for the OP to say specifically which copy (s)he used
KS0108 Library I used : http://en.radzio.dxp.pl/ks0108/
For Creation of 8x8 font : https://www.riyas.org/2013/12/on...
also you have to replace code of 'GLCD_WriteChar(char charToWrite)' with following..
    int i;
	charToWrite -= 32;
	for(i = 0; i<8; i++)
	GLCD_WriteData(GLCD_ReadByteFromROMMemory((char *)((int)font8x8 + (8 * charToWrite) + i)));
	GLCD_WriteData(0x00);
nIk
Thanks - and mark the solution ... ?
"We're goin' way back, WAY back.  'Cuz that's where the fun is... WAY BACK!"
https://web.archive.org/web/20070202061106/http://www.apetech.de:80/
"Read a lot.  Write a lot."
On that page:
Jippi, die neue Seite ist fertig!
So, should we now say
Verdamt, die alte Seite ist kaput!
