ADC0 and ADC1 are not working
6 posts / 0 new
Hello, I need to use 2 ADC inputs, but when I see the Serial monitor, The value of the ADC0 is represented in the variable of the ADC1.
void casos(){
	g++;
	switch(g) {
		case 1:
		ADMUX= 0B01000000;		//MISMO ADMUX DEL LAB2
		ADCSRA= 0B10000111;		//MISMO ADCSRA DEL LAB2
		ADCSRB= 0;				//MISMO ADCSRB DEL LAB2
		DIDR0 |=(1<<ADC0D);		//DEFINE EL PIN ADC0 COMO ENTRADA PARA LM35
		ADCSRA|=(1<<ADSC);
		ValorTemperatura=ADC;
		Temperatura_Serial=ADC;
		envia_cadena_usart(array);//mensaje a enviar al ordenador
		char string1[8];
		itoa(Temperatura_Serial, string1, 10);  //convert integer to string, radix=10
		envia_cadena_usart(string1);
		break;
		case 2:
		ADMUX= 0B01000001;		//MISMO ADMUX DEL LAB2
		DIDR1 |=(1<<ADC1D);		//DEFINE EL PIN ADC1 COMO ENTRADA PARA SENSOR HUMEDAD TIERRA
		ADCSRA|=(1<<ADSC);
		ValorHumedad=ADC;
		Humedad_Serial=ADC;
		envia_cadena_usart(array2);
		char string2[8];
		itoa(Humedad_Serial, string2, 10);  //convert integer to string, radix=10
		envia_cadena_usart(string2);
		condiciones();
		break;
		g=0;
I have this routine, but the ADC1 is not working. Any solution?
You never wait for the ADC to finish! You need to poll the ADSC bit to see when the adc has finished.
		case 2:
		if(ADSC==1)
		ADCSRA|=(1<<ADSC);
		ValorHumedad=ADC;
		Humedad_Serial=ADC;
		char string2[8];
		condiciones();
		break;
Is it correct?
Or this?
void casos(){
	g++;
	switch(g) {
		case 1:
		ADCSRA|=(1<<ADSC);
		while (ADCSRA&(1<<ADSC))
				char string1[8];
		break;
		case 2:
		ADCSRA|=(1<<ADSC);
			ValorHumedad=ADC;
			Humedad_Serial=ADC;
			char string2[8];
			condiciones();
		break;
		g=0;
You can keep on guessing or you can Google the solution in 10 seconds.
Here's what I found:
uint16_t adc_read(uint8_t ch)
  // select the corresponding channel 0~7
  // ANDing with ’7′ will always keep the value
  // of ‘ch’ between 0 and 7
  ch &= 0b00000111;  // AND operation with 7
  ADMUX = (ADMUX & 0xF8)|ch; // clears the bottom 3 bits before ORing
  // start single convertion
  // write ’1′ to ADSC
  ADCSRA |= (1<<ADSC);
  // wait for conversion to complete
  // ADSC becomes ’0′ again
  // till then, run loop continuously
  while(ADCSRA & (1<<ADSC));
  return (ADC);
Modify to suit your requirements.
  return (ADC);
Thanks.
