Learning Interrupts
6 posts / 0 new
Hi, I am trying to learn how to use interrupts and I am having trouble with the following code. I am using a STK500 along with the STK500's LED and Switches.  My AVR is a ATMega168A.  In the below code, I want to flash the LED on PORTC0 when an interrupt is detected on PORTB0. When I load the code, the LED stays on and when I push the button, nothing happens. I assume that how I am setting the interrupts incorrectly.
#define F_CPU 16000000L
#include <util/delay.h>
#include <avr/interrupt.h>
	/* LED C0*/
	DDRC |= 1<<PORTC0; // Set pin to output led
	PORTC &= ~(1<<PORTC0); // low
	/* Switch B0*/
	/* PCICR Pin change interrupt control register */
	PCICR |= 1<<PCIE0; // enable interrupts on bank b
	PCMSK0 |= 1<<PORTB0; // enable pin B0
	sei();
	    _delay_ms(10);
ISR(PCINT0_vect){
	PORTC = (1<<PORTC0); // high
	_delay_ms(1000);
	_delay_ms(1000);
Thanks for the help
"When all else fails, read the directions"
Never mind - There was a typo in my code. Noticed it when I was editing my post. The above code works.
Mom always said I never mind.
277,232,917 -1 The largest known Mersenne Prime
Where can I find the introduce of INT4_vect,INT5_vect...?
Such as them.
一个大学生
Adding to 'js' post, there might be a more recent list in the build of avrlibc that Atmel/Microchip does. It is online here: http://www.atmel.com/webdoc/AVRL...
If you're using Atmel Studio, there will be a similar locally stored page in the help there.
