LUFA Code Works on Demo, Not in User Project
6 posts / 0 new
A bit of quirkiness thats been stumping me: I can load the LUFA VirtualSerial demo onto my chip and it works as expected, but when I try to run the exact same code from the VirtualSerial.c file in my own project, the chip doesn't communicate over USB after being programmed (doesn't show up in device manager).
I've done all the basic checks, included the VirtualSerial.h file in my project and everything, but I must be missing something still.
Am I missing something outside of my C file that's causing my project not to function like the demo does?
C file in my project(VirtualSerial.c, same as working demo)
#include "VirtualSerial.h"
/** LUFA CDC Class driver interface configuration and state information. This structure is
 *  passed to all CDC Class driver functions, so that multiple instances of the same class
 *  within a device can be differentiated from one another.
USB_ClassInfo_CDC_Device_t VirtualSerial_CDC_Interface =
		.Config =
				.ControlInterfaceNumber   = INTERFACE_ID_CDC_CCI,
				.DataINEndpoint           =
						.Address          = CDC_TX_EPADDR,
						.Size             = CDC_TXRX_EPSIZE,
						.Banks            = 1,
				.DataOUTEndpoint =
						.Address          = CDC_RX_EPADDR,
						.Banks            = 1,
				.NotificationEndpoint =
						.Address          = CDC_NOTIFICATION_EPADDR,
						.Size             = CDC_NOTIFICATION_EPSIZE,
						.Banks            = 1,
/** Standard file stream for the CDC interface when set up, so that the virtual CDC COM port can be
 *  used like any regular character stream in the C APIs.
static FILE USBSerialStream;
/** Main program entry point. This routine contains the overall program flow, including initial
 *  setup of all components and the main program loop.
	SetupHardware();
	/* Create a regular character stream for the interface so that it can be used with the stdio.h functions */
	CDC_Device_CreateStream(&VirtualSerial_CDC_Interface, &USBSerialStream);
	GlobalInterruptEnable();
	for (;;)
		CheckJoystickMovement();
		/* Must throw away unused bytes from the host, or it will lock up while waiting for the device */
		CDC_Device_ReceiveByte(&VirtualSerial_CDC_Interface);
		CDC_Device_USBTask(&VirtualSerial_CDC_Interface);
		USB_USBTask();
/** Configures the board hardware and chip peripherals for the demo's functionality. */
void SetupHardware(void)
#if (ARCH == ARCH_AVR8)
	/* Disable watchdog if enabled by bootloader/fuses */
	MCUSR &= ~(1 << WDRF);
	wdt_disable();
	/* Disable clock division */
	clock_prescale_set(clock_div_1);
#elif (ARCH == ARCH_XMEGA)
	/* Start the PLL to multiply the 2MHz RC oscillator to 32MHz and switch the CPU core to run from it */
	XMEGACLK_StartPLL(CLOCK_SRC_INT_RC2MHZ, 2000000, F_CPU);
	XMEGACLK_SetCPUClockSource(CLOCK_SRC_PLL);
	/* Start the 32MHz internal RC oscillator and start the DFLL to increase it to 48MHz using the USB SOF as a reference */
	XMEGACLK_StartInternalOscillator(CLOCK_SRC_INT_RC32MHZ);
	XMEGACLK_StartDFLL(CLOCK_SRC_INT_RC32MHZ, DFLL_REF_INT_USBSOF, F_USB);
	PMIC.CTRL = PMIC_LOLVLEN_bm | PMIC_MEDLVLEN_bm | PMIC_HILVLEN_bm;
#endif
	/* Hardware Initialization */
	USB_Init();
/** Checks for changes in the position of the board joystick, sending strings to the host upon each change. */
void CheckJoystickMovement(void)
	char*       ReportString  = "Hello world. ";
	static bool ActionSent    = false;
	if ((ReportString != NULL) && (ActionSent == false))
		ActionSent = true;
		/* Write the string to the virtual COM port via the created character stream */
		fputs(ReportString, &USBSerialStream);
		/* Alternatively, without the stream: */
		// CDC_Device_SendString(&VirtualSerial_CDC_Interface, ReportString);
/** Event handler for the library USB Connection event. */
void EVENT_USB_Device_Connect(void)
/** Event handler for the library USB Disconnection event. */
void EVENT_USB_Device_Disconnect(void)
/** Event handler for the library USB Configuration Changed event. */
void EVENT_USB_Device_ConfigurationChanged(void)
	bool ConfigSuccess = true;
	ConfigSuccess &= CDC_Device_ConfigureEndpoints(&VirtualSerial_CDC_Interface);
/** Event handler for the library USB Control Request reception event. */
void EVENT_USB_Device_ControlRequest(void)
	CDC_Device_ProcessControlRequest(&VirtualSerial_CDC_Interface);
/** CDC class driver callback function the processing of changes to the virtual
 *  control lines sent from the host..
 *  \param[in] CDCInterfaceInfo  Pointer to the CDC class interface configuration structure being referenced
void EVENT_CDC_Device_ControLineStateChanged(USB_ClassInfo_CDC_Device_t *const CDCInterfaceInfo)
	/* You can get changes to the virtual CDC lines in this callback; a common
	   use-case is to use the Data Terminal Ready (DTR) flag to enable and
	   disable CDC communications in your application when set to avoid the
	   application blocking while waiting for a host to become ready and read
	   in the pending data from the USB endpoints.
	bool HostReady = (CDCInterfaceInfo->State.ControlLineStates.HostToDevice & CDC_CONTROL_LINE_OUT_DTR) != 0;
The LUFA demo project also contains Descriptors.c and Descriptors.h.
Yep, I have those in my project too. Below is a picture of my directory (left) and the demo directory(right). Still not sure why my project doesn't create a Serial Device visible in Device Manager with my chip when installed.
This is not the first time you've had this problem - see this post (Link).
So what board are you using now?
Did you set the F_CPU and F_USB to the correct values?
Indeed.
I'm using an Atmega16U2 this time around and it, along with the proper clock values, have all been set in Atmel Studio.
Not a lot of sources in either project.
Start with the demo, gradually moving your source files into that, test after each change. Small steps! When it stops working you have a pretty narrow area to do the fine-grained analysis in.
