opamp AC square wave to to DC
111 posts / 0 new
Pages
Double-check that the signal out of your op-amp is the expected 10KHz square wave and not your local line frequency (50Hz/60Hz).
frog_jr wrote:
Deionized water is not the same as distilled water.
Indeed.
The Wikipedia article I linked in #83 discusses various types of "purified" water - including deionised & distilled ...
Yes it is outputting the 10kHz.
Is the way U9 and U10 are configured the correct way?
AVR outputs a pulse to  U9 and   U10 with R12 removed is connect to the Op-AMP
Should U 10 be connected to GND via a resistor?
Regards
DJ
I do no believe that a resistor is needed.
If the voltage at U10 is too high, then make the electrodes smaller or farther apart. Those are your only choices. Note that "farther apart" is in the sense of the path. If you put an insulating barrier between them so that the current must travel a greater distance, then that is "farther apart".
Voltage from the AVR is 3.3V.
I will work on what you reccomended. Maybe i can expirment with some wires to just see it is working in principle.
Regards
DJ
The voltage at U10 is 3.3V? This is when the 10KHz output from the MCU is close to 5V (U9)? You have said, earlier, that the MCU runs from 5V.
Sorry if i mentioned 5V but its 3.3V.
How low should voltage be?
Regards
DJ
Deionization does not remove organic material.
Depending on the original water source, deionized water may have a tendency to become acidic upon exposure to CO2 in the air.
You may want to check the pH of the water you are using...
It really doesn't matter how you purify it; Once water is in contact with the air, CO2 is always absorbed until the pH reaches about 6 (slightly acidic).
What would be the recommended voltage? As i only if a small proportion(2mm) of the electrode is exposed then i get variation in my adc results.
Regards
DJ
You expect variation in the output. If you do not have it, then the amplifier is driven too hard and the amplifier is saturating. Once that happens, your reading is invalid.
Your description leads me to believe that your electrodes are simply too large (or too close together) (or both). Or, that your drive voltage is too high or your feedback resistor is too large. Or, all of the above.
By the way, you can get lower drive by using a voltage divider from your MCU port  pin.
Pages
