How do I load large amounts of data when programming (exceeding flash)?
15 posts / 0 new
I'm using an Xmega with 128K of Flash memory. I also need to store about 256K of data that could be pulled by the code while the program runs. Right now I am trying to do this using a micro SD card but even at this point this seems like an issue because the way the card is being read and the data stored in FAT file system.
I would like to connect a serial flash (SPI) that will hold all this non-volatile data, question is - what is the best way to load it onto the serial flash. It seems a little far fetched I could someone program everything using the JTAG debugger at a single go. Loading the code onto the external flash is possible as a separate step but if there is a better way I would like to hear about it.
Have a function in your code that reads the data from the serial port and store it into the serial flash.
That's what I have (in a smaller scale) with my electronic signs where you can download up to 1K of data from a text file, the function is only accessible at start up when entering a special character in the first few seconds followed by a password to get into, what I call, a monitor mode where that function is available as well as others to change parameters.
That's the option I can also implement, although it seems like something that will take some time to debug. Not sure if this is simpler than writing the external flash directly.
I've done the same with AT45. I simply implemented Xmodem/CRC so I could send the data from a "standard" terminal program and on through the AVR, into the DataFlash. If I had my time again I would have used Ymodem in fact (far easier to tell the length and where the data actually ends)
For the purpose of my reply, I'm going to assume that "single go" means connecting the JTAG debugger / programmer and executing a programming routine on the target.  No need to connect a second interface, etc.
This might be overly convoluted, error prone, etc, but working with this requirement, here's how I would go about it:
Write a series of programs that contain code to transfer blocks of your 256K to the SPI flash, the remainder of the "program" would be the data to load.  Data will be split up over these programs, so you need 2-3 of them.
Put together a batch file / script to program your target that will load each program in turn, pause long enough for it to program the external flash, load the next, wait, etc.  Once this is complete, load the final program and complete.
Depending on your application, like if you're programming 1000's of devices, this approach might be worth pursuing.  If it's just a few, probably not.
OK, I'll bite -- probably billions of devices in the world use SD cards to store bulk data.  (photos, tunes, ...)
But in >>your<< particular unique application, it won't work.
Tough row to hoe, then.
With the SD card you can load it externally with a $3.00 USB writer and Windows explorer.
Hmmm, so a bootloader-sort-of-thing that when loaded moves the lower xxxx kbytes into the SPI flash and then writes a value to EEPROM so that the next 'bootloader' knows what it is doing.
When you put it that way it makes it sound like my question does not make any sense, and I don't think that fair.
I've stated that I'm currently going with an SD card just to make a quick prototype. The final application will have a PCB that will be coated and having any kind of detachable memory card on it would make coating more difficult, will further limit board design and case design. Having a connector on top for programming is easier. These are my requirements, and they are not as special as your comment might suggest.
Apparently not.  Thus, you should have many proven examples to choose from.
THere was a thread on this recently where the OP was going to pot(encapsulate) the circuit board and did not want to use a SD card.  Cannot remember the thread title though.
JIm
JIm
But that was information that was not put in this question, and as such might have been for a different product, or there might have been a change in concept.
As the programming of the "external memory" is only once done.
why not make a special programmer for just the memory?
get data through USb/Uart to the programming board and through that program the onboard serial flash.
All you need to do is make sure that the Host processor does not do anything during that time.
So might be that first you set the board controller in "flash programing mode" then connect the programmer and program the onboard flash. and then set the board controller back to "normal mode"
you can then pot the board. or do it up front but leave the 6 needed programming lines available.
I assume most people here develop "factory test software" to check the integrity of the electronics during fabrication? Put the "flash loader" stuff into that so it runs once the board is proven. It will then replaced by the final application software before the device ships out.
Not unless I really have to, I don't. All my Test functions & Test / Configuration commands go into the customer firmware.
The most extreme example matching the OP problem that I can give is a Datalogger we designed with multi-lingual UI. The text for menus, UI & help was stored in external flash and uploaded via serial comms. This was beneficial in that whenever a new language became available all we had to do was upload a new languages file. In fact (given the up-loader program) the customer could have done this if necessary.
I once had to do this and simply added test pads to the flash memory SPI bus. Then when the board was being tested on a bed of nails the test jig could simply write the data directly to the flash memory while holding the microcontroller in reset.
