problem with reading pin state using usart
9 posts / 0 new
i have written a program that toggles PB0 and PB1 by sending '1' and '2' and reads PIN states by sending '3'.
my problem is that PB1 state is not read correctly.
what is the reason?
here is the code:
#include <avr/interrupt.h>
void usart_init();
volatile uint8_t state0,state1;
    usart_init();
	DDRB=(1<<DDB0)|(1<<DDB1);
	sei();
    while (1);
ISR (USART_RXC_vect)
	uint8_t data=UDR;
	if (data=='1')
		PORTB^=(1<<PB0);
		if(bit_is_clear(PINB,PB0))
		state0=0;
		else state0=1;
	if (data=='2') {
		PORTB^=(1<<PB1);
		if(bit_is_clear(PINB,PB1))
		state1=0;
		else state1=1;
	if (data=='3') {
		while( !( UCSRA & (1<<UDRE)) );
		UDR=state0;
		UDR=state1;
void usart_init(){
	UCSRB=(1<<RXCIE)|(1<<RXEN)|(1<<TXEN);//enable recieve & interrupt
	UCSRC=(1<<UCSZ0)|(1<<UCSZ1);//8N1
	UBRRH=0;
	UBRRL=12;//BAUD 38400
You don't have brackets in your first if?
MG
Braces, spaces and comments are your friends, use them:
    if (data == '1') {
        PORTB ^=  (1 << PB0);           // Toggle PB0
        if(bit_is_clear(PINB, PB0)) {
            state0 = 0;    // Do you want 0x00 or '0'??
	} else {
            state0 = 1;    // Do you want 0x01 or '1'??
Are you wanting to send a human readable (ASCII) code below?
    if (data == '3') {
        while( !( UCSRA & (1 << UDRE)) );
        UDR = state0;  // Send 0x00 or 0x01 to UART???
        UDR = state1;  // Send 0x00 or 0x01 to UART???
Edit: typo
     0 does not equal '0'
David (aka frog_jr)
I edited the peogram
now both PB0 and PB1 are read incorrectly.
when PINS are high UART says they are Low and vice versa
void usart_init();
    usart_init();
	sei();
    while (1);
	uint8_t data=UDR;
	if (data=='1') {
		PORTB^=(1<<PB0);
		state0=0x00;
		else state0=0x01;
	if (data=='2') {
		PORTB^=(1<<PB1);
		state1=0x00;
		else state1=0x01;
	if (data=='3') {
		UDR=state0;
		UDR=state1;
void usart_init(){
	UBRRH=0;
    if (data == '3') {
Edit: typo
yes
Are you sure "the pins are high"? Or is this actually about switches being pressed or not?
If this is a starter kit board or similar then it is not unlikely that switches are wired so that when pressed the pin is low (pulled down) and when not pressed ithe pin is high (pulled up).
my circuit is on breadboard and two LED's are connected to indicate PIN state
It takes a clock time for the port state to be updated in the pin register. You need a nop(); after the port toggle
thank you so much
problem solved!
