Memory size limit and workarounds?
16 posts / 0 new
Hi, I'm having a small problem that I think is stemming form a program/data memory limit somewhere. I am using an ATmega48.
The problem basically originated when I tried to use large arrays for storing ADC readings (one for storing around 100 readings for a filter, and one for storing a few thousand of those filtered readings to keep a short history). After adding these arrays the flashed code seemingly did nothing. There were no warnings from avr-gcc or avrdude about any of this, however.
The following code is a boiled down version of the problem I was encountering. Based on riktronics' LED-blinker sample with one big array added.
#define F_CPU 8000000
#include <util/delay.h>
#include <avr/power.h>
#include <stdint.h>
uint8_t bigArray[785]; // LED won't blink at 786
int main()
 DDRB |= (1 << PB1); // make PB1 an output
 PORTB |= (1 << PB1); // turn on led at PB1
 _delay_ms(1000); // delay for a second
 PORTB &= ~(1 << PB1); //turn off led at PB1
 return 0; // the program executed successfully
The command to avr-gcc is:
avr-gcc -Wall -Os -DF_CPU=8000000 -mmcu=atmega48 -c main.c -o main.o
This compiled .o is 852 bytes on disk. avrdude claims "130 bytes of flash verified" after the fact.
So, my question is basically: where can I tell exactly how much memory I'm using in program/data and what type of limit I'm hitting? What workarounds are there? (I've tried searching the datasheet but wasn't exactly sure where my code was being placed and how much space it would end up occupying.)
Thank you!
Mega48 only has 512 bytes of SRAM.
That won't even fit the memory you have. Surely you must be getting build errors! You would if you use the Atmel Studio 7.x IDE, I'll bet. The IDE will also tell you exactly how many flash bytes are used. Code begins at the bottom of code space, just above the interrupt vector table. As I understand it, the reset vector always points to the beginning of executable code space.
An ATmega48 only has 512 bytes of sram...
Although I believe in the code you provide, the array would be optimized away.
Edit:
For the code you provided, AS7 shows 134 bytes flash, 0 bytes data memory (sram).
Normal AVR programs will load at 0x0000 where the actual code is preceded by the vector table and the C startup code, as seen in the .lss file:
00000000 <__vectors>:
   0:	19 c0       	rjmp	.+50     	; 0x34 <__ctors_end>
   2:	28 c0       	rjmp	.+80     	; 0x54 <__bad_interrupt>
   4:	27 c0       	rjmp	.+78     	; 0x54 <__bad_interrupt>
   6:	26 c0       	rjmp	.+76     	; 0x54 <__bad_interrupt>
   8:	25 c0       	rjmp	.+74     	; 0x54 <__bad_interrupt>
   a:	24 c0       	rjmp	.+72     	; 0x54 <__bad_interrupt>
   c:	23 c0       	rjmp	.+70     	; 0x54 <__bad_interrupt>
   e:	22 c0       	rjmp	.+68     	; 0x54 <__bad_interrupt>
  10:	21 c0       	rjmp	.+66     	; 0x54 <__bad_interrupt>
  12:	20 c0       	rjmp	.+64     	; 0x54 <__bad_interrupt>
  14:	1f c0       	rjmp	.+62     	; 0x54 <__bad_interrupt>
  16:	1e c0       	rjmp	.+60     	; 0x54 <__bad_interrupt>
  18:	1d c0       	rjmp	.+58     	; 0x54 <__bad_interrupt>
  1a:	1c c0       	rjmp	.+56     	; 0x54 <__bad_interrupt>
  1c:	1b c0       	rjmp	.+54     	; 0x54 <__bad_interrupt>
  1e:	1a c0       	rjmp	.+52     	; 0x54 <__bad_interrupt>
  20:	19 c0       	rjmp	.+50     	; 0x54 <__bad_interrupt>
  22:	18 c0       	rjmp	.+48     	; 0x54 <__bad_interrupt>
  24:	17 c0       	rjmp	.+46     	; 0x54 <__bad_interrupt>
  26:	16 c0       	rjmp	.+44     	; 0x54 <__bad_interrupt>
  28:	15 c0       	rjmp	.+42     	; 0x54 <__bad_interrupt>
  2a:	14 c0       	rjmp	.+40     	; 0x54 <__bad_interrupt>
  2c:	13 c0       	rjmp	.+38     	; 0x54 <__bad_interrupt>
  2e:	12 c0       	rjmp	.+36     	; 0x54 <__bad_interrupt>
  30:	11 c0       	rjmp	.+34     	; 0x54 <__bad_interrupt>
  32:	10 c0       	rjmp	.+32     	; 0x54 <__bad_interrupt>
00000034 <__ctors_end>:
  34:	11 24       	eor	r1, r1
  36:	1f be       	out	0x3f, r1	; 63
  38:	cf ef       	ldi	r28, 0xFF	; 255
  3a:	d2 e0       	ldi	r29, 0x02	; 2
  3c:	de bf       	out	0x3e, r29	; 62
  3e:	cd bf       	out	0x3d, r28	; 61
00000040 <__do_clear_bss>:
  40:	21 e0       	ldi	r18, 0x01	; 1
  42:	a0 e0       	ldi	r26, 0x00	; 0
  44:	b1 e0       	ldi	r27, 0x01	; 1
  46:	01 c0       	rjmp	.+2      	; 0x4a <.do_clear_bss_start>
00000048 <.do_clear_bss_loop>:
  48:	1d 92       	st	X+, r1
0000004a <.do_clear_bss_start>:
  4a:	a0 30       	cpi	r26, 0x00	; 0
  4c:	b2 07       	cpc	r27, r18
  4e:	e1 f7       	brne	.-8      	; 0x48 <.do_clear_bss_loop>
  50:	02 d0       	rcall	.+4      	; 0x56 <main>
  52:	17 c0       	rjmp	.+46     	; 0x82 <_exit>
00000054 <__bad_interrupt>:
  54:	d5 cf       	rjmp	.-86     	; 0x0 <__vectors>
00000056 <main>:
int main()
  56:	21 9a       	sbi	0x04, 1	; 4
  58:	29 9a       	sbi	0x05, 1	; 5
	#else
		//round up by default
		__ticks_dc = (uint32_t)(ceil(fabs(__tmp)));
	#endif
	__builtin_avr_delay_cycles(__ticks_dc);
  5a:	2f ef       	ldi	r18, 0xFF	; 255
  5c:	89 e6       	ldi	r24, 0x69	; 105
  5e:	98 e1       	ldi	r25, 0x18	; 24
  60:	21 50       	subi	r18, 0x01	; 1
  62:	80 40       	sbci	r24, 0x00	; 0
  64:	90 40       	sbci	r25, 0x00	; 0
  66:	e1 f7       	brne	.-8      	; 0x60 <main+0xa>
  68:	00 c0       	rjmp	.+0      	; 0x6a <main+0x14>
  6a:	00 00       	nop
  6c:	29 98       	cbi	0x05, 1	; 5
  6e:	2f ef       	ldi	r18, 0xFF	; 255
  70:	89 e6       	ldi	r24, 0x69	; 105
  72:	98 e1       	ldi	r25, 0x18	; 24
  74:	21 50       	subi	r18, 0x01	; 1
  76:	80 40       	sbci	r24, 0x00	; 0
  78:	90 40       	sbci	r25, 0x00	; 0
  7a:	e1 f7       	brne	.-8      	; 0x74 <main+0x1e>
  7c:	00 c0       	rjmp	.+0      	; 0x7e <main+0x28>
  7e:	00 00       	nop
  80:	eb cf       	rjmp	.-42     	; 0x58 <main+0x2>
00000082 <_exit>:
  82:	f8 94       	cli
00000084 <__stop_program>:
  84:	ff cf       	rjmp	.-2      	; 0x84 <__stop_program>
David (aka frog_jr)
The amount of consumed flash can be positively determined at build time. You do not tell which "distribution" of the avr-gcc tool chain you use, but it likely comes with a utility called avr-size. If you run that and feed it the .elf file it will tell you the flash consumed.
It will also tell you how much RAM is consumed by statically allocated data. But there will be more RAM consumed at run time than that number, e.g. for the call stack and function-local variables. Determining how much RAM that is so consumed at run-time is very hard, and sometimes impossible. Most of us use a rule of thumb of some sort, and combine that with our experience. If you search around you might find advice such as "leave at least 20% RAM free for runtime allocation".
You allocate an array
that is larger than the available RAM. An immediate recipe for disaster. The array needs 785 bytes, but the RAM on the mega48 is 512 bytes. As noted by frog_jr, since you never use the array it will most likely be optimized away. But as soon as you insert some code that references that array things will go really bad.
Depending on the complexity of your program, e.g. when it comes to function calls you might get away with an array of 400 to 450 uint8_t's, leaving the rest for some other non-complex variables and the call stack.
This is quite large amount of data as for 8-bit microcontroller. I can imagine a few solutions:
- use external RAM, most likely connected via SPI
- change requirements, so you don't need to store so much data
- use the microcontroller with larger RAM size
- compress data, for example if the ADC readings changed slowly, you could store only 4 bits for every one.
Data compression alone doesn't solve your problem, but if you replace ATmega48 with ATmega88 you have 1KB of RAM and if you reserve 200 bytes of RAM for the stack and global and static variables you can store more than 1600 samples.
From the Atmel Microcontroller Product Selector, ATMega1284 has 16K RAM, and various XMegas have 32K
http://www.atmel.com/selector.html#(actives:!(81041,8238,8394,8362,8282,8431,8300,8358,8392,8378,8445,8236,8449,8474,8248,8264,8447,8256,8254,8286,8462,8429,8458,8466,8400,8302,8278),data:(area:'',category:'34864',pm:!((i:81041,v:!(1,2,3,4,5,6,7,8,9,10,11,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,50,51,52,53,54,55,56,57,58,59,60,61,62,63,64,65,66,67,68,69,70,71,72,73,74,75,76,77,78,79)),(i:8238,v:!(0,19)),(i:8394,v:!(0,27)),(i:8362,v:!(2,49)),(i:8282,v:!(6)),(i:8431,v:!(25,42)),(i:8300,v:!(1,9)),(i:8358,v:!(2,75)),(i:8392,v:!(0,1)),(i:8378,v:0),(i:8445,v:!(1,4,5,6,7,9)),(i:8236,v:!(0,36)),(i:8449,v:!(1,11)),(i:8474,v:!(0)),(i:8248,v:!(0,1)),(i:8264,v:!(0,5)),(i:8447,v:!(0,1)),(i:8256,v:!(1,2,3,4)),(i:8254,v:!(3,18)),(i:8286,v:!(0,3)),(i:8462,v:!(0,10)),(i:8429,v:!(1,11)),(i:8458,v:!(0,8)),(i:8466,v:!(1,2,3,4,5)),(i:8400,v:!(0,20)),(i:8302,v:!(0,1,2)),(i:8278,v:!(0,1,2))),view:list),sc:1)
Thanks for all the advice. I understand that I'm hitting the SRAM limit, and I might look into another solution for storing ADC readings involving less memory (maybe a running average, or cautious use of flash/eeprom). I was expecting the compiler to warn about this limit, especially with -Wall, but again it was entirely silent on the matter.
I ran avr-size on my compiled file and got:
text    data     bss     dec     hex filename
 130       0     785     915     393 main.elf
Seems like the memory is still 'allocated' to bss, and at runtime something odd happens when this allocation tries to happen that causes the code to not execute properly.
Empty Set wrote:
This is because your large array has been optimized out. The compiler and linker are smart enough to realize that it is not used. You have to use the array in a way that will prevent it from being optimized out. I think it will be enough if you declare the array as volatile.
Perhaps store your data in the eeprom, 1k IIRC!
Why would you need to store 100 readings for a filter?  What kind of filter?
Or look for another chip with more memory.
It sounds like you are doing a data-intensive application - so why did you choose a chip with such a tiny amount of RAM??
It's not like chips with lots of RAM are hard to find or expensive these days ...
The ultimate goal is to make a control decision based on a sensor's input and some timing parameters.
There's no strict requirement here, and I'm probably running the ADC too fast as a result. That said, I think the larger bottleneck for memory usage isn't the samples for the filter, even at +100, but for the history which needs to be around 20 seconds or so. The thought was to aggregate at ~8ms currently, which is probably much too fast for the application, but I'm trying to err on the fast side in observation of other possible sources of latency in my system and slow things down after I get past a proof-of-concept.
While 'erring on the fast side' I may still reduce that sample rate to 32 or 64ms which would greatly reduce data usage, since it seems there is this limitation on the micro. I could use another one too, but that would probably only be necessary if a lower-data solution can't provide the accuracy needed.
I'll look into this on my own and come back if I have any further issues working around this limit. Thanks for the help!
Have a look at adding a FRAM memory chip and your speed and memory issues may well be resolved.
Empty Set wrote:
 it seems (sic) there is this limitation on the micro
There is no "seems" about it:  the  ATmega48 most certainly has only 512 bytes of SRAM - it is clearly stated in the product documentation.
Filter---There's no strict requirement here
 Are you doing averaging? If so, no need to store individual samples.  A few types like median & mode would require storage.
I tend to use indefinite language but yes, I understand that smiley
