PWM PULSE WITH MEGA8A??
17 posts / 0 new
HI
can I produce a pwm pulse with mega8 that 5us=on & 10ms=off?
Depends on your skill level, but for those skilled in the art, your requirements are easy to achieve. Sounds like you want to control a RC servo. If so, there are plenty of examples on the interwebs.
I want to apply this pulse to a meg16.
Yes.
To my knowledge, in case of ATmega8, the best resolution of PWM is 1/1024 [10 bits]. The ratio 5us/10,000us is 1/2000. So, to me in the least, the answer to your question is no if ATmega8 is used... though I wish I am wrong.
And yet my screen grab above, and this one below, would appear to say otherwise...
Same 10ms repeat rate, here I've set a wider pulse width...
Yes you are wrong. Yes, there is at least one canned 10-bit mode. But there is also at least one canned 16-bit mode.
See the
See the
Thank you for pointing out that there is a 16-bit mode when using PWM of ATmega8 (the only MCU I have for my various projects).
Would you please let me know on which table on its datasheet this mode is shown (I write my codes in assembly only).
Thank you in advance for your time.
theusch wrote:
See the
Don't you just love a cliffhanger!
surprise  cheeky
KerimF wrote:
Would you please let me know on which table on its datasheet this mode is shown ...
Table 39 (or at least it is in the version of the datasheet I have downloaded.)
Thank you Brian for your fast reply.
Yes, it is on table 39; titled 'Waveform Generation Mode Bit Description'.
It seems I am getting old faster than I was expecting ;)
Only now I noticed that by using the 'Phase Correct PWM Mode' or 'Phase and Frequency Correct PWM Mode', a 16-bit PWM could be generated.
I used skipping these two modes because it happens that I didn't need better than 10-bit PWM in my projects.
So, thanks to you and theusch for opening my eyes on this.
Not a cliffhanger, it's a leehanger.devil
David (aka frog_jr)
I wondered if anyone else would spot that!
laugh
But it's not only that two modes. There are also 16 bit Fast PWM modes (mode 14 and 15).
Stefan Ernst
Yes, you are right. In Fast PWM mode, OCR1A\B or ICR1 is also used.
Thank you for your remark.
