How to software reset SAMD20
11 posts / 0 new
When my main app is running, I want to fall back to bootloader. To do that I set some flags  in flash then issue a software reset. I googled on how to software reset SAMD20 and it turns out that I have to reset the core by writing to the AIRCR reg. This is where I got the info:
cortex user guide
However the s/w reset is resulting in a hardware fault.
This is my code:
(*(uint32_t*) 0xE000ED0C) = (0x05FA << 16) | 0x04;
It looks like that address is not mapped? Is there some other way to reset SAMD20 using start project?
thanks for your help
Probably the best way out is to use the WDT timer.
Total votes: 2
NVIC_SystemReset?
NVIC_SystemReset?
Did this work?
Silly beans are always silly
I ended up using WDT. I let it overflow and reset the system.
YogiWannabe, could you send me any example?
I am with the same problem.
Thank you!
So what's wrong with the methods of #4 & #5?
I setup WDT in Atmel Start project then I called this function. For some reason when I try to add code, browser just hangs....
void software_reset_mcu()
    uint32_t clk_rate;
    uint16_t timeout_period;
    clk_rate       = 1000;
    timeout_period = 8192;
    wdt_set_timeout_period(&WDT_0, clk_rate, timeout_period);
    wdt_enable(&WDT_0);
    while (1)
What "browser" are you talking about??
I believe (s)he is referring to the known forum bug of trying to use the <> button here.
David (aka frog_jr)
