Joystick - Atmega8 - Atmega644p - roboclaw
7 posts / 0 new
Hello guys, Im trying to read a joystick via ADC with Atmega8 and send via usart to atmega644p, and then send to pc (the main goal is to send to roboclaw 2x15a)
I send the values directly atmega8 to pc and its ok, but when i send via atmega644p sometimes x and y have the same value.
joystick code
/* Created: 26/09/2017 11:58:03
 * Author : Eduardo Pilar
 // Atmega 8, @16Mhz
#include <avr/interrupt.h>
#include <stdio.h>
#ifndef F_CPU
#define F_CPU 16000000UL
#endif
#include <util/delay.h>
#define USART_BAUDRATE 9600
#define BAUD_PRESCALER (((F_CPU) / (USART_BAUDRATE * 16UL))-1)
void initADC(void)
	ADMUX |=(1<<REFS0); /* Utiliza VCC como Ref */
	ADCSRA |=(1<<ADEN)|(1<<ADPS0)|(1<<ADPS1)|(1<<ADPS2); /* ADEN enable do ADC, 128 Prescaler*/
uint16_t read_adc(uint8_t ch)
	//ch &= 0b00000111; // escolhe o canal
	ADMUX = (ADMUX & 0xF8)|(ch&7);
	ADCSRA|=(1<<ADSC); //Inicia conversao
	while(!(ADCSRA&(1<<ADSC))); //espera pelo fim da conversao
	return(ADC);
void initUSART(void)
	UBRRH=(BAUD_PRESCALER>>8);
	UBRRL= BAUD_PRESCALER; //valor relativo ao baud rate de 9600
	UCSRA=0x00;
	UCSRB=(1<<RXEN)|(1<<TXEN); // hablita transmissao e recepcao
	UCSRC=(1<<URSEL)|(1<<USBS)|(3<<UCSZ0); // 2 stops bit, 8 bit data
unsigned char receiveusart(void)
	while(!(UCSRA&(1<<RXC)));
	return UDR;
void send_usart ( uint8_t data)
	while((UCSRA & (1<<UDRE))==0);
	UDR = data;
void send_buffer(uint8_t x, uint8_t y)
	//Preparar o dados de x e y para enviar
	uint8_t joystick_enviar[2];
	joystick_enviar[0] = x;
	joystick_enviar[1] = y ;
	send_usart(joystick_enviar[0]);
	send_usart(joystick_enviar[1]);
	int x,y;
	initUSART();
	initADC();
    while (1)
		x = (uint8_t)(read_adc(0)>>2);
		_delay_ms(1);
		y = (uint8_t)(read_adc(1)>>2);
		_delay_ms(1);
		send_buffer(x,y);
Atmega644p Code
 * GccApplication3.c
 * Created: 11/10/2017 11:50:13
#include <stdio.h>
#ifndef F_CPU
#endif
void initusart1(void)
	UBRR1H = (BAUD_PRESCALER >> 8);
	UBRR1L = BAUD_PRESCALER; //valor relativo ao baud rate de 9600
	UCSR1A = 0x00;
	UCSR1B=(1<<RXEN1)|(1<<TXEN1);//hablita transmissao e recpcao
	UCSR1C|=(1<<USBS1)|(1<<UCSZ10)|(1<<UCSZ11);// 2 stops bit, 8 bit data
void initusart0(void)
	UBRR0L=(BAUD_PRESCALER >> 8);
	UBRR0L= BAUD_PRESCALER; //valor relativo ao baud rate de 9600
	UCSR0B=(1<<RXEN0)|(1<<TXEN0);//hablita transmissao e recpcao
	UCSR0C|=(1<<USBS0)|(1<<UCSZ00)|(1<<UCSZ01);// 2 stops bit, 8 bit data
unsigned int receiveusart1(void)
	while(!(UCSR1A&(1<<RXC1)));
	return UDR1 ;
void send_usart0 (unsigned char data){
	while(!(UCSR0A & (1<<UDRE0)));
	UDR0 = data;
enum {
	M1FORWARD = 0,
	M1BACKWARD = 1,
	SETMINMB = 2,
	SETMAXMB = 3,
	M2FORWARD = 4,
	M2BACKWARD = 5,
	M17BIT = 6,
	M27BIT = 7,
	MIXEDFORWARD = 8,
	MIXEDBACKWARD = 9,
	MIXEDRIGHT = 10,
	MIXEDLEFT = 11,
	MIXEDFB = 12,
	MIXEDLR = 13,
	GETM1ENC = 16,
	GETM2ENC = 17,
	GETM1SPEED = 18,
	GETM2SPEED = 19,
	RESETENC = 20,
	GETVERSION = 21,
	SETM1ENCCOUNT = 22,
	SETM2ENCCOUNT = 23,
	GETMBATT = 24,
	GETLBATT = 25,
	SETMINLB = 26,
	SETMAXLB = 27,
	SETM1PID = 28,
	SETM2PID = 29,
	GETM1ISPEED = 30,
	GETM2ISPEED = 31,
	M1DUTY = 32,
	M2DUTY = 33,
	MIXEDDUTY = 34,
	M1SPEED = 35,
	M2SPEED = 36,
	MIXEDSPEED = 37,
	M1SPEEDACCEL = 38,
	M2SPEEDACCEL = 39,
	MIXEDSPEEDACCEL = 40,
	M1SPEEDDIST = 41,
	M2SPEEDDIST = 42,
	MIXEDSPEEDDIST = 43,
	M1SPEEDACCELDIST = 44,
	M2SPEEDACCELDIST = 45,
	MIXEDSPEEDACCELDIST = 46,
	GETBUFFERS = 47,
	GETPWMS = 48,
	GETCURRENTS = 49,
	MIXEDSPEED2ACCEL = 50,
	MIXEDSPEED2ACCELDIST = 51,
	M1DUTYACCEL = 52,
	M2DUTYACCEL = 53,
	MIXEDDUTYACCEL = 54,
	READM1PID = 55,
	READM2PID = 56,
	SETMAINVOLTAGES = 57,
	SETLOGICVOLTAGES = 58,
	GETMINMAXMAINVOLTAGES = 59,
	GETMINMAXLOGICVOLTAGES = 60,
	SETM1POSPID = 61,
	SETM2POSPID = 62,
	READM1POSPID = 63,
	READM2POSPID = 64,
	M1SPEEDACCELDECCELPOS = 65,
	M2SPEEDACCELDECCELPOS = 66,
	MIXEDSPEEDACCELDECCELPOS = 67,
	SETM1DEFAULTACCEL = 68,
	SETM2DEFAULTACCEL = 69,
	SETPINFUNCTIONS = 74,
	GETPINFUNCTIONS = 75,
	SETDEADBAND	= 76,
	GETDEADBAND	= 77,
	GETENCODERS = 78,
	GETISPEEDS = 79,
	RESTOREDEFAULTS = 80,
	GETTEMP = 82,
	GETTEMP2 = 83,	//Only valid on some models
	GETERROR = 90,
	GETENCODERMODE = 91,
	SETM1ENCODERMODE = 92,
	SETM2ENCODERMODE = 93,
	WRITENVM = 94,
	READNVM = 95,	//Reloads values from Flash into Ram
	SETCONFIG = 98,
	GETCONFIG = 99,
	SETM1MAXCURRENT = 133,
	SETM2MAXCURRENT = 134,
	GETM1MAXCURRENT = 135,
	GETM2MAXCURRENT = 136,
	SETPWMMODE = 148,
	GETPWMMODE = 149,
	FLAGBOOTLOADER = 255
//PARA ENVIAR COMANDO: Address, Command, ByteValue, CRC16
//PAG 64 - Manual
//VARIAVEL GLOBAL PARA GUARDAR O VALOR DO CRC
uint16_t m_crc;
//FUNCOES PARA CALCULO DO CRC
void crc_clear()
    m_crc = 0;
void crc_update( uint8_t data )
    int i;
    m_crc = m_crc ^ ((uint16_t)data << 8);
    for (i=0; i<8; i++)
        if (m_crc & 0x8000)
            m_crc = (m_crc << 1) ^ 0x1021;
            m_crc <<= 1;
uint16_t crc_get()
    return m_crc;
void send_command(uint8_t address, uint8_t cmd, uint8_t valor){
	int i;
	crc_clear();
    crc_update(address);
    crc_update(cmd);
    crc_update(valor);
    uint16_t crc = crc_get();
    uint8_t buffer_cmd_enviar[5];
    buffer_cmd_enviar[0] = address;
    buffer_cmd_enviar[1] = cmd;
    buffer_cmd_enviar[2] = valor;
    buffer_cmd_enviar[3] = crc>>8;
    buffer_cmd_enviar[4] = crc;
	for(i=0;i<5;i++){
    send_usart0(buffer_cmd_enviar[i]);
	initusart1();
	initusart0();
	uint8_t  x,y;
	uint8_t receve_joystick[2];
	//send_command(0x80,M1FORWARD,64); //127 - Velocidade max, 64 - metade da velocidade, 0 - stop
	while (1)
		for(int i=0; i<2; i++){
		receve_joystick[i] = receiveusart1();
			x=0;
            y=0;
			x = receve_joystick[0];
			x=x/2;
			send_usart0(x);
			//send_command(0x80,MIXEDLR,x); //127- full R, 64 stop turn, 0- full L
      _delay_ms(4000);
			y = receve_joystick[1];
			y=y/2;
			send_usart0(y);
			//send_command(0x80,MIXEDFB,y);// 127 - Full Forward, 64 Stop, 0- full backward
      _delay_ms(4000);
I think when i do recebe_joystick[i]=receiveusart1() sometimes x stay in position 0 and other times in 1 position.
Any solution to resolve my problem?
best regards
Not the problem but:
What is the purpose of the array in this? Surely it would work the same as:
	send_usart(x);
	send_usart(y);
This may or may not relate to your problem but in one lot of code you have:
	for(i=0;i<5;i++){
which seems to very sensibly wrap up the data to send in "packets" with things like crc to protect its integrity. While elsewhere you are just doing:
	send_usart(x);
	send_usart(y);
and receiving with:
which has no such "packetisation. If the send/receive ever "miss a byte" how do you get this back in step?
You really need a "protocol" to pass this data. Some kind of unequivocal "data packet starts here", then "data payload" then "end of packet with option checksum". That way if communication ever breaks down you can just skip bytes that arrive until  the next "start of packet" arrives and you can use the CRC to check that the data came in unscathed.
Just sending x,y,x,y,x,y,x,y... probably ain't going to cut it. If I unplug the cable then plug it back in and see n,m,n,m,n,m... how do I know if 'n' is an X or a Y value?
First thought:  Why not have the '164 do the X/Y reads?
There isn't much going on in the Mega8 app, so the below doesn't make much difference.  But look for ADLAR in the datasheet; use that if you want an 8-bit result instead of doing the shifts.
Or (s)he did start a new thread for the new question - but didn't bother to mention it anywhere.
Clearing things up:
The cross-post I was pointing to was a continuation on a separate subject (by same OP). Morten has split that into a separate thread, locked that and pointed to here for continuation.
THIS thread you're looking at right now is the thread where the subject should be spoken about and dealt with.
Sorry for any confusion (and kudos to Morten for the split, lock and pointer!)
Ok, i understand the problem. So i have to seend the data like send_comand right?
 // Atmega 8, @16Mhz
#include <stdio.h>
#ifndef F_CPU
#endif
void initADC(void)
	ADCSRA |=(1<<ADEN)|(1<<ADLAR)|(1<<ADPS0)|(1<<ADPS1)|(1<<ADPS2); /* ADEN enable do ADC, 128 Prescaler*/
	return(ADC);
	UCSRA=0x00;
	return UDR;
	UDR = data;
/*void send_buffer(uint8_t x, uint8_t y)
uint16_t m_crc;
void crc_clear()
	m_crc = 0;
	int i;
	for (i=0; i<8; i++)
		if (m_crc & 0x8000)
		m_crc <<= 1;
uint16_t crc_get()
	return m_crc;
void send_buffer(uint8_t x, uint8_t y){
	int i;
	//Calculo do CRC
	crc_clear();
	crc_update(x);
	crc_update(y);
	//Preparar o dados para enviar
	uint8_t buffer_cmd_enviar[4];
	buffer_cmd_enviar[0] = x;
	buffer_cmd_enviar[1] = y;
	buffer_cmd_enviar[2] = crc>>8;
	buffer_cmd_enviar[3] = crc;
	for(i=0;i<4;i++){
		send_usart(buffer_cmd_enviar[i]);
		_delay_ms(1000);
	int x,y;
	initUSART();
	initADC();
    while (1)
		x = (uint8_t)(read_adc(1)>>2);
		_delay_ms(1);
		y = (uint8_t)(read_adc(0)>>2);
		_delay_ms(1);
		send_buffer(x,y);
but, how i have to do on the receiver side?
cheers
