sketch compiling larger by ~1k in AS7 compared to Arduino IDE
4 posts / 0 new
If I compile a sketch in AS7 for ATTiny841 it is now ~1k larger than when compiled in Arduino IDE.  This happened for the first time today.  Previously it has been the same size in both.  I use VisualMicro to load and edit the ino file in AS7.  In Arduini IDE I think it is the same size as it was last night, when I last worked on it.  Has anyone experienced this or know what might have changed?
The obvious prime suspect is the optimization setting.
Are you saying the exact same source code generated 1K larger today than yesterday? In the same project, or in a newly set up project?
You didn't by any chance introduce some floating point stuff - a double variable or a FP literal or some such?
If I open the same ino  file, right now, in either IDE and compile it, I get overflow by 1068 in AS7, and 7968 in Arduino.  I haven't been able to fix it yet.
Compare LSS files. You may also find "avr-nm -size-sort" on the ELF files useful.
