C Program Doesnt work with custom function
9 posts / 0 new
Hey guys,
I have a problem with my avr c programs, it works as long as I only use the main function, but when I add my own function it doesn't work anymore.
This works (my LED turns on and stays on)
int main (void) {
    DDRA = 0xFF;
        PORTA = 1 << PA0;
    return 0;
And this doesnt (my LED stays off)
void add(){
int main (void) {
    DDRA = 0xFF;
        PORTA = 1 << PA0;
    return 0;
This is the script I use for compiling and flashing
compile: 'avr-gcc -mmcu=atmega32a -Wall -Os -c main.c -o main.o',
link: 'avr-gcc main.o -o main.elf',
hex: 'avr-objcopy -O ihex -j .text -j .data main.elf main.hex',
flash: 'avrdude -p m32 -c usbtiny -F -e -U flash:w:main.hex'
Does anyone know where the problem is, am I compiling it wrong so that it doesnt the errors?
"doesen't  work" can mean anything. We can not guess what you're observing.
Tell us what you observe with the working variant. Tell us what you observe with the variant that "doesen't work".
Apart from that: The name is "blinky" suggesting it should make a LED on port A pin 1 blink.
But even the code you claim work does not do that. it simply alters the state of the pin once, and then the program ends.
If your LED is actually blinking then that suggests something else is going on, like the AVR constantly resetting itself.
You have to add -mmcu=atmega32a to the linking command line too.
Stefan Ernst
I updated my question.
Does work means my led turns on and stays on.
Doesnt work means my led stays off
originally it should blink, but I changed the code to the easiest so I can see it is a logic error
A first test shows that it works know, can you tell me why it doens't work without this?
Don't do that!
Now we have answers (#2 and #3) which refer to the original question, but we can no longer see the original question - so those answers no longer make sense!
So add or update stuff, do it in a reply.
danielr1996 wrote:
return 0;
To where, exactly, do you think that this is going to "return" ?
The programs in microcontrollers like this don't "return" - because there is nowhere for them to "return" to!
The programs in microcontrollers like this just keep running until the power dies.
@awneil: While what you say is generally sound advice, it can also be noted that the avr-libc run-time actually has this code to handle returning from main() :
0000007a <_exit>:
  7a:	f8 94       	cli
0000007c <__stop_program>:
  7c:	ff cf       	rjmp	.-2      	; 0x7c <__stop_program>
So.. The net effect of executing a return from main() is
i) Interrupts are disabled
ii) the program goes into an endless loop
I've used this on occasion for a firmware that was "one-shot". The OPs example of just lighting up an LED is such a one-shot.
Still, the cost of inserting ones own
while (1);
at the end of main() is negligible, so one might just as well get used to that habit.
Good point.
