Error programing Lock bits atmega32
8 posts / 0 new
I am trying to use lock bits for protection on atmega32.I am not being able to write lock bits to it its giving me verification error while doing it.Can you tell me correct way to do this?
This is the error I am getting while programing:
Note that the write fails (and then also the verification).
Add -v options to the AVRDUDE command line to get more info. You can add up to four of those, i.e.
avrdude -v -v -v -v ...
Please don't post screen shots. Copy avrdude output as text and paste it into a post here.
You 'Dude people will have to help -- the messages seem to imply that the dude is looking for a file named 0xfc, rather than trying to use a byte with value 0xfc as the lock bit settings?  Is that just the way the dude messages are phrased?
A nearly identical thread from 2011:  http://www.avrfreaks.net/forum/s...
The "failure" might have to do with the handling of the don't-care bits?  At least in that thread, the operation was actually carried out correctly.
Note that in that thread I don't see an answer on how to read lock bits successfully, like fuse values.  [hmm--haven't fussed in that area much -- are you allowed to read the lock bits when the lock bits are set on an AVR8?]
The output shows all the lock bits are already programmed to 0 (verify is 0x00). You cannot unprogram lock bits. They can only be returned to 1 by a chip erase.
"Read a lot.  Write a lot."
LOL! The obvious escaped both Lee and me.
To non-dudes, it isn't apparent from the pictured "log" what the state of the AVR is when carried out.
Back when I was your age, you couldn't even read the signature of a "locked" AVR.  Nowadays you can.  Can fuses be read from a locked AVR?  Can lock bits be read from a locked AVR?
As I always [can't think of an exception] do a full ISP sequence beginning with signature read and erase, I just don't remember.  Perhaps one/more 'Freaks just "know" the answer.  Scanning the Memory Programming section of a representative datasheet, I don't see it addressed.
Signature, calibration byte, fuses, and lock bits can always be read, regardless of the state of lock bits.  Lock bits prevent reading/writing of flash and EEPROM only.
EDIT: sp
sorry for late reply the problem was with don't care bits in lock bits.
thanks guys for your help.
