ULTRASONIC SENSOR HY-SRF05
12 posts / 0 new
I am using ATmega16 and i want to blink a led when an obstacle is 10cm or less close to my ultrasonic sensor.I have the following code but the led blinks only when the obstacle has a specific distance regardless of the value that i use in the if statement.
CODE:
#include <avr/interrupt.h>
#define F_CPU 10000000L
#include <util/delay.h>
#include <stdint.h>
static volatile int pulse = 0;
	DDRB=0x01;
	PORTB=0x00;
	DDRD = 0xFB;
	_delay_ms(50);
	GICR|=(1<<INT0);  // External Interrupt Request & set (one) and the I-bit in the Status Register
	MCUCR|=(1<<ISC00)|(1<<ISC01); //define whether the External Interrupt is activated on rising
	//and/or falling edge of the INT0 pin or level sensed
	TCCR1A = 0;
	sei();
		PORTD|=(1<<PIND0);
		_delay_us(15);
		PORTD &=~(1<<PIND0);
		_delay_us(150);
		if((pulse/58)<= 10){
			PORTB |= (1<<PINB0);
			pulse=0;
		else{
			PORTB &=~ (1<<PINB0);
			pulse=0;
ISR(INT0_vect)
	TCCR1B|=(1<<CS10);
	while(PIND&0x04);
	TCCR1B=0; //No clock source
	pulse=TCNT1;
	TCNT1=0;
And what distance would that be?
Is your AVR really running at 10MHz?
Which LED is "blinking"?  The way I read the code, PB0 changes state depending on "pulse".
Don't you need to change from rising edge to falling edge?
Image result for hcsr05 timing diagram
There must be many HCSR05 discussions on this forum, including some quite recently.
I use an 10MHz crystall oscillator on stk500 and i have set the jumpers to use oscillator's frequency.Pulse is the value of the counter witch increases as long as the echo is high. PB0 is the output to the led  and i compare pulse's duration(echo) to find out the distance.
The distance led blins is about 25cm regardless of the value i use in if state.
Does it?
How have you checked?
Shouldn't that be unsigned ?
When i debug the programm with the simulator and i check the registers it increases correctly but when i run the programm on board i have the problem i mentioned before.
Why?
See the timing diagram.  You have configured your external interrupt for "rising edge", right?  You may be well timing to the start of the return pulse.
You are dividing by 58 to get distance in centimeters.  But that assumes that your timing is in microseconds, and your timer units are 100ns.
As asked before, which is the "distance LED"?
The distance LED is PB0.Do you have any formula from which i can calculate the denominator i have to use?
Distance = Speed x Time
The Speed is the speed of the ultrasound pulse, look it up on Google.
It varies a bit with pressure, temperature, humidity, etc., but you can ignore all of those factors given the resolution and hardware you are using.
Time is the units of time you are counting.
If you know the micro's clock frequency, and how your program is counting time "tics", then this is known.
You must, of course, make sure all of your units are the same.
Really? I am not aware of the MEGA timers having a gated counter mode.  And even if it has one, you are setting the TC to Normal mode.
Instead of using an external interrupt, why not use the TC's capture input?  This is precisely the sort of thing it is for.  And, as mentioned above, you need to toggle the edge sense from rising to falling after capturing the rising edge.  Something like this:
  1. Output trigger pulse
  2. Set TC to capture rising edge.
  3. When capture interrupt fires, store the rising edge timestamp and switch edge sense to falling edge.
  4. When capture interrupt fires again, store the falling edge timestamp.
  5. The difference between the timestamps is the width of the echo pulse.
Greg Muth
Portland, OR, US
Thank you all! Finally , the problem was that that "pulse" had to be unsigned as awneil said and should have changed the denominator (in the if statement) in order to take the accurate distance.
