need help with clamping function.
2 posts / 0 new
X and Y data is a 7 bit -80 0 80 with a sign on the 8th. but the data typically is -60 to 60.  I need to expand and move to 0-255 with clamping. Loss of data is ok.
    uint8_t x=0,y=0;
    x=getX();
    y=getY();
    int xx = x * 1.5;
    int yy = y * 1.4;
    yy += 6;//offset
    yy = yy +127;// + 127 as the data rest is at 0
    xx = xx +127;
    //clamp
    if (yy > 253) yy = 254; else if (yy< 1) yy = 1;//clip if needed.
    if (xx > 253) xx = 254; else if (xx< 1) xx = 1;
    reportBuffer[X_MAIN_STICK] = (int8_t)(xx);
    reportBuffer[Y_MAIN_STICK] = (int8_t)(255 -yy);
I'm sure there is an easier way to do this then multiplication?
Actually, doing the clamp up front got the multiplication out of the way.
    uint8_tx=0,y=0;
    x=getX();
    y=getY();
    if (y > 63)y = 63; else if (y < -63) y = -63;//clip to 128 max
    if (x> 63) x = 63; else if (x < -63) x = -63;
    reportBuffer[X_MAIN_STICK] = (x<<1)+128;
    reportBuffer[Y_MAIN_STICK] = 255-((y<<1)+128);
