I2C on Atmel Start
5 posts / 0 new
I have a SAMD11 configured as I2C Master Sync and a SAMD21 configured as a Slave Sync.
Despite several attempts, it looks like the two parties can't communicate.
Is there anyone with some idea why?
MASTER (SAMD11)
Master SAMD11
#include <atmel_start.h>
struct io_descriptor *I2C_0_io;
int32_t result;
void I2C_init(void)
	i2c_m_sync_get_io_descriptor(&I2C_0, &I2C_0_io);
	i2c_m_sync_enable(&I2C_0);
	i2c_m_sync_set_slaveaddr(&I2C_0, 0x12, I2C_M_SEVEN);
	/* Initializes MCU, drivers and middleware */
	atmel_start_init();
	I2C_init();
	while (1)
		result = io_write(I2C_0_io, (uint8_t *)0xFF, 1);
		delay_ms(10);
SLAVE (SAMD21)
SLAVE SAMD21
struct io_descriptor *io;
uint8_t               c;
void I2C_slave_init(void)
	i2c_s_sync_get_io_descriptor(&I2C_0, &io);
	i2c_s_sync_set_addr(&I2C_0, 1);
	i2c_s_sync_enable(&I2C_0);
	atmel_start_init();
	PORT->Group[1].DIRSET.reg = PORT_PB30;
	PORT->Group[1].OUTSET.reg = PORT_PB30;
	I2C_slave_init();
	while (1)
		io_read(io, &c, 1);
		delay_ms(10);
		if(c == 0xFF)
			PORT->Group[1].OUTCLR.reg = PORT_PB30;
Thanks a lot in advance for any kind advice.
Filo
Show us your schematic, what pull up resistors are you using on the SDA/SCL lines?
Hi Jim,
I am using 4.7Kohm on both SDA and SCL as pullup resistors.
Circuit is 3.3V
I2C
Thanks so much for your help
Filo
Check your addresses.  The master is talking to slave 0x12 via  i2c_m_sync_set_slaveaddr(&I2C_0, 0x12, I2C_M_SEVEN) and the slave is listening to address to 0x01 via i2c_s_sync_set_addr(&I2C_0, 1).
Try setting the addresses to the same value.
Thanks so much ScottMN, definitely a very good spot!
I think there could be a BUG in the atmel start interface cause i have set 0x12 as slave address (as per picture above) in the slave config. interface and nevertheless the value was not set.
Below the working code for reference:
SLAVE
uint8_t               c;
	i2c_s_sync_set_addr(&I2C_0, 0x12);
	atmel_start_init();
	I2C_slave_init();
	while (1)
		io_read(io, &c, 1);
		delay_ms(10);
		if(c == 0xFF)
MASTER
int32_t result;
void I2C_init(void)
	atmel_start_init();
	I2C_init();
	uint8_t b = 0xFF;
	while (1)
		result = io_write(I2C_0_io, &b, 1);
		delay_ms(10);
Thanks again,
Filo
