help in wireless communication between two atmega328p using nRF24L01+ ( mirf library )
7 posts / 0 new
Hello
I have two nRF24L01+ modules with two atmega328p and I'm trying to make wireless communication between the two atmega328p
and I'm using mirf library.
here is the code in both chips :
#define F_CPU 1000000L // 1 MHz
#include <util/delay.h>
#include "nRF24L01.h"
#include "spi.h"
#include "mirf.h"
int main(void) {
	spi_init();
	mirf_init();
	_delay_ms(50);
	mirf_config();
	uint8_t buffer[5] = {9, 9, 9, 9, 9};
	uint8_t buffersize = 5;
	uint8_t buffer2[5];
	while(1) {
		mirf_flush_rx_tx(); // Flush TX/RX
		mirf_send(buffer, buffersize);
		_delay_ms(1000);
		// If maximum retries were reached, reset MAX_RT
		if (mirf_max_rt_reached()) {
			mirf_config_register(STATUS, 1<<MAX_RT);
		while(!mirf_data_ready());
		mirf_get_data(buffer2);
		if(buffer2[0] == 9)
			PORTB |= (1<<6);
			PORTB &= ~(1<<6);
so I send a buffer of 5 bytes each hold value of 9
and I'm receiving after that a buffer and I check if the first byte in it equals 9 ( and if so I write HIGH on pin6 of PORTB - there's a LED there and it should light )
but it didn't work
is there any problems in my code ??
updates :
I made some changes to my code
I made one of the atmega328p transmit by this code :
 * nRF24L01_with_ATmega328p_2.c
 * Created: 8/25/2015 3:59:59 PM
 *  Author: Khalid
#include "spi.h"
#include "mirf.h"
int main(void) {
	spi_init();
	mirf_init();
	_delay_ms(50);
	mirf_config();
	while(1) {
		_delay_ms(1000);
and I checked if it transmits will using an arduino uno as a receiver and I managed to receive data and print it on arduinos Serial monitor
yet I couldn't till now receive the data on the other atmega328p
the code on the receiver atmega328p :
 *  Author: Khalid
#include "spi.h"
#include "mirf.h"
int main(void) {
	spi_init();
	mirf_init();
	_delay_ms(50);
	mirf_config();
	DDRB |= (1<<6);
	uint8_t buffer[5] = {0, 0, 0, 0, 0};
	mirf_CE_hi; // Start listening
	while(1) {
			_delay_ms(50);
		mirf_get_data(buffer);
		for (int x = 0; x < 5; x++) {
			if(buffer[x] == 9)
				PORTB |= (1<<6);
				PORTB &= ~(1<<6);
			buffer[x] = 0;
so for now we have a working transmitter but a bad receiver
any ideas ??
ok I've actually made it ! :D
the thing is that I had to activate the receiving mode on the other MCU
that's done by the mirf.c lib :
	PMODE = RXMODE; // Set to receiver mode
	RX_POWERUP; // Power up
hope this can help others
mostly Atmel products discussed here, rather than Nordic.
Killjoy!
277,232,917 -1 The largest known Mersenne Prime
I compile your code but can not debug it .
the warnnig is 'choose the simulator'
can you help me
Select the tool you want to use for debugging in Project / Properties / Tool in the "Selected debugger/programmer" box.
If you are debugging hardware, you must have a (supported) debugger connected between the uC and the PC and it should show up in that box.
If you are simulating using the Atmel Studio built-in simulator, choose "Simulator".
David (aka frog_jr)
