4 bytes less RAM when using my own pointer to FILE instead of stderr
9 posts / 0 new
I've made a stderr redirection for using with LCD in a standard way:
FILE lcd_output = FDEV_SETUP_STREAM(lcd_putchar, NULL, _FDEV_SETUP_WRITE);
// main
stderr = &lcd_output;
fprintf_P(stderr, PSTR("fprintf"));
Then I decided to try to declare my own pointer to FILE so I can use another mnemonic instead of stderr:
FILE* stdlcd;
// main
stdlcd = &lcd_output
fprintf_P(stdlcd, PSTR("fprintf"));
and was surprised the latter compiles to 4 bytes of RAM less compared to the first case.
Why is that so and is it then better to declare a pointer to FILE than using one of the default stdio streams?
Chupo_cro
Look at the generated code. I suspect that optimisation is taking place.
My guess is that when you use stderr, stdin and stdout are also being allocated, even though they are not used.   Two extra pointers requires 4 bytes on an AVR.
Greg Muth
Portland, OR, US
Greg_Muth wrote:
My guess
Good guess:
http://svn.savannah.gnu.org/view...
37 	FILE *__iob[3];                 /* stdin, stdout, stderr */
stdio.h has:
279 	/**
280 	   Stream that will be used as an input stream by the simplified
281 	   functions that don't take a \c stream argument.
282
283 	   The first stream opened with read intent using \c fdevopen()
284 	   will be assigned to \c stdin.
285 	*/
286 	#define stdin (__iob[0])
287
288 	/**
289 	   Stream that will be used as an output stream by the simplified
290 	   functions that don't take a \c stream argument.
291
292 	   The first stream opened with write intent using \c fdevopen()
293 	   will be assigned to both, \c stdin, and \c stderr.
294 	*/
295 	#define stdout (__iob[1])
296
297 	/**
298 	   Stream destined for error output.  Unless specifically assigned,
299 	   identical to \c stdout.
300
301 	   If \c stderr should point to another stream, the result of
302 	   another \c fdevopen() must be explicitly assigned to it without
303 	   closing the previous \c stderr (since this would also close
304 	   \c stdout).
305 	*/
306 	#define stderr (__iob[2])
So if you access any one of these you get all 3 as they are an array.
clawson wrote:
Greg_Muth wrote:
My guess
Good guess:
<snip>
Yes, that seems to be the reason. If stdin/stdout was already used for RS232 communication then declaring a new pointer to FILE results in 2 bytes more compared to when using stderr. However, if only one stream is to be used (e.g. only for LCD out), then declaring a new pointer to FILE saves 4 bytes (+2 for a new pointer -6 for the array).
Here is the test program where two different outputs can be generated by switching NEW_POINTER from 0 to 1:
#include <stdio.h>
#define NEW_POINTER		0	// 0 --> 20 bytes of RAM, 1 --> 16 bytes of RAM
int lcd_putchar(char c, FILE *stream) {
	return 0;
#if NEW_POINTER
	FILE* stdlcd;
#endif
int main(void) {
#if NEW_POINTER
	stdlcd = &lcd_output;
#else
#endif
#if NEW_POINTER
	fprintf(stdlcd, "");
#else
	fprintf(stderr, "");
#endif
	return 0;
} // main
When the switch is 0:
00000092 <.do_clear_bss_loop>:
  92:	1d 92       	st	X+, r1
00000094 <.do_clear_bss_start>:
  94:	a4 31       	cpi	r26, 0x14	; 20
  96:	b1 07       	cpc	r27, r17
  98:	e1 f7       	brne	.-8      	; 0x92 <.do_clear_bss_loop>
When the switch is 1:
  92:	1d 92       	st	X+, r1
  94:	a0 31       	cpi	r26, 0x10	; 16
Chupo_cro
Great.
laugh
So please mark the solution: http://www.avrfreaks.net/comment...
BTW in this case the .map file would have given the answer:
C:\SysGCC\avr\bin>type avr.c
#include <stdio.h>
int main(void) {
    stdout = (void *)3;
C:\SysGCC\avr\bin>avr-gcc -mmcu=atmega16 -Wl,-Map,avr.map -Os avr.c -o avr.elf
C:\SysGCC\avr\bin>grep -C 2 __iob avr.map
                              c:/sysgcc/avr/bin/../lib/gcc/avr/5.3.0/../../../../avr/lib/avr5/crtatmega16.o (exit)
c:/sysgcc/avr/bin/../lib/gcc/avr/5.3.0/../../../../avr/lib/avr5\libc.a(iob.o)
                              C:\Users\uid23021\AppData\Local\Temp\cc0vevbF.o (__iob)
c:/sysgcc/avr/bin/../lib/gcc/avr/5.3.0/avr5\libgcc.a(_clear_bss.o)
                              c:/sysgcc/avr/bin/../lib/gcc/avr/5.3.0/../../../../avr/lib/avr5\libc.a(iob.o) (__do_clear_bss)
Common symbol       size              file
__iob               0x6               c:/sysgcc/avr/bin/../lib/gcc/avr/5.3.0/../../../../avr/lib/avr5\libc.a(iob.o)
Memory Configuration
 *(COMMON)
 COMMON         0x00800060        0x6 c:/sysgcc/avr/bin/../lib/gcc/avr/5.3.0/../../../../avr/lib/avr5\libc.a(iob.o)
                0x00800060                __iob
                0x00800066                PROVIDE (__bss_end, .)
                0x00000092                __data_load_start = LOADADDR (.data)
The use of stdout lead to the allocation of 6 bytes for __iob between 0x800060 and 0x800066
awneil wrote:
Great.
laugh
I did mark the solution. I already did that at the time of my last post. But I marked the Greg's post as the solution because he was the first one to give the correct answer. As you can see, Clawson quoted Greg - which can be seen in both Clawson's reply to Greg and my reply to Clawson where there are two levels of quoting. Clawson confirmed Greg was right and presented a proof. I replied to the last post which was Clawson's but marked the first correct answer - which was Greg's.
Chupo_cro
<snip>
Thank you very much! Good to know a bettery way. I was examining the .lss file because I am more familiar with assembler than with compiler internals so I thought it would be easier for me to find out what's going on. But clearly, reading the .map file is a better idea.
Chupo_cro
