Strange execution times on test case.
6 posts / 0 new
I am trying to test a function 'funn' (a lowpass filter) that I implementet:
void inline funn( int16_t in, int16_t& out, uint8_t midiCC );
variable in' is the stream, 'out' is the result and 'midiCC' is a variable that changes the centre frequency.
The test case is:
void testing(uint8_t midiCC)
  int num_of_iter = 100;
  uint32_t beforeMillis = millis();
  uint32_t nextMillis = millis();
  Serial.print("midiCC: "); Serial.println(midiCC);
  for(size_t k = 0 ; k < num_of_iter ; ++k)
    for(size_t i = 0 ; i < len ; ++i)
      funn(inputs[i],out,midiCC);
  Serial.print("funn: "); Serial.println(nextMillis-beforeMillis);
  Serial.print("test"); Serial.println(out);
  Serial.println("");
  delay(1000);
void loop() {
  testing(0);
  testing(10);
  testing(50);
  testing(100);
  testing(120);
  testing(127);
Variable 'test' is just so the compiler does not optimize anything away.
Variable 'inputs' is just a big array that you could see as a square wave.
Variable 'iout' the momentan value.
Question, I got some strange result:
midiCC: 0
funn: 39
test1000
midiCC: 10
funn: 52
test1021
midiCC: 50
funn: 57
test1483
midiCC: 100
funn: 86
test2909
midiCC: 120
funn: 108
test3635
midiCC: 127
funn: 108
test2939
The time () it that takes to execute increments when 'midiCC' increments.
Could argue that it is a loop in the implementation but where are none.
I have no idea why it is not constant time.
//returns uint16in multiplied with uint8in gnoring the least significan byte.
inline uint16_t mulu8x16div8_16(uint8_t uint8in, uint16_t uint16in)
  uint16_t res;
  asm volatile (
  "clr %B0 \n\t"
  "mul %A1, %A2 \n\t"
  "mov %A0, __zero_reg__ \n\t"
  "mul %A1, %B2 \n\t"
  "add %A0, __tmp_reg__ \n\t"
  "adc %B0, __zero_reg__ \n\t"
  "clr r1 \n\t"
  "=&r" (res)
  "a" (uint8in),
  "a" (uint16in)
  return res;
  if(midiCC < 1) { out = in; return; }
  else if(in==out) { return; }
  midiCC <<= 1;
  midiCC = ~midiCC; // 0-127 => 255-0
  int16_t o = (in - out);
  int16_t c;
  if(o > 0)
    //out += (int16_t) midiCC;
    c = mulu8x16div8_16( midiCC , o );
    if(!c) c = 1;
    //out -= (int16_t) midiCC;
    c = - mulu8x16div8_16( midiCC , -o );
    if(!c) c = -1;
  out += c;
Running Arduino 1.8.2
Microchip: atmega32u4
The code is not in code tags.
len does not appear to be defined.
The inline assembly is a horror of obfuscation.
International Theophysical Year seems to have been forgotten..
Anyone remember the song Jukebox Band?
Ahh sorry! I tried to keep the explanation short forgot about 'len'.
I have 'len' defined.
This is my globals and setup()
uint8_t factor = 100;
size_t i = 0;
size_t len = 256;
int16_t inputs[256];
int16_t out;
void setup() {
  uint16_t sample[] = { 4095, 1000, 4095, 1500};
  size_t y = 0;
  size_t z = 0;
  for(size_t x = 0; x  < len ; ++x)
    if(++z > 50)
      z = 0;
      ++y;
    if(y>3) y = 0;
    inputs[x] = sample[y];
  Serial.begin(9600);
The assembly is whery simple. It is unsigned char multiplied with unsigned int and then remove the most significant byte.
One chould say that I scale the uint16in with uint8in.
Will give the same result in C.
  return (  ((uint32_t) uint8in  )  *  ((uint32_t) uint16in  )  >> 8 );
Ecit in a comments about the assebly now to my former post.
But that will become more operatons and bigger hex file.
Trying to avoid uint32_t calculations.
And I have tested the assembly code seperate with different values. Time is constant and gives correct results.
DONE, fanx.
I finally found it!!
It is the compiler that manage to do some optimization.
Inside 'funn' is the code:
    if(!c) c = 1;
When I remove the line
if(!c) c = 1;
I get a fixed execution time that is higher.
