Terminal for printing outputs?
65 posts / 0 new
Hey people,
I would like to see what a program is printing on a terminal. Does AS7 have any inbuilt terminals? If yes where? Otherwise, what are the options I have?
Azim
TeraTerm
PuTTY
Bray
RealTerm
etc, etc, ...
EDIT
This is a very frequently recurring question; eg, http://www.avrfreaks.net/comment...
I have TeraTerm installed. Can I print data without the hardware? I need to see what certain line of code are printing. If yes, how?
You mean you're running your code in a simulator, and want to see its UART output ?
EDIT
Is that specifically the Atmel Studio simulator?
So, I have this code that uses a circular buffer. It receives incoming bytes in these UART buffers. I want to know what these incoming bytes are. In my previous post I had inquired on how I can assign dummy values to those buffers but in vain. The project does a dummy capture. I am frustrated with this now. I just dont know what to do and whom to approach for such (maybe) trivial questions.
I do not know much about the ATMEL simulator. I was debugging the project to find out the flow of the program. But as usual its stuck in a while loop.
So are you running your code in the simulator or not?
Why not use the DEBUGGER to do this - stop at any moment and you can actually examine what is in the buffers in actual AVR memory - no need to "print" the contents
No..:/
AVR memory? whats that? I am using the debugger. So this AVR memory is where I can see what's in those buffers?
Are you serious?!
The AVR has 3 types of memory:
  1. RAM - where your variables, stack, etc, go;
  2. Flash - where your code goes;
  3. EEPROM.
EDIT
EDIT 2
typo
#AVRMemories #AVRArchitecture
Oh no. I am sorry. Lol. I know that. I thought AVR memory is a tool on AS7 blush. So how do I examine whats in the AVR Memory? ref: clawson
That's one of the fundamental tools of the AS7 debugger - in fact, of any debugger.
I think you need to spend some time reviewing the documentation and available tutorials for Atmel Studio ...
There's a whole load of resources - including videos - linked from the Atmel Studio pages on the Atmel & Microchip websites.
EDIT
To get you started: https://www.google.co.uk/search?q=atmel+studio+inspect+memory
Ok. Done.
AS7 has a terminal. That's what the documentation says. Under View. But I dont see any on my AS7 here. Ugh!!!
Read #8 again.
There used to be a 'terminal' program in AS, but it was never any good!
You can only use a terminal program(see list above) with real hardware, not with a simulator.
It will require some interface hardware as well, most likely a USB to serial TTL cable like this: http://www.ebay.com/itm/USB-To-R...
Note this has TTL outputs, not RS-232 outputs, you also need one in which the TTL signal levels match your VCC level, either 3.3v or 5.0v, the cables come in both versions, use the correct one for your project.
These will create a COM port when plugged into a PC, set your terminal program to use that COM port, connect the TX,RX and GND pins only to your AVR, like this:
PC - AVR
TX - RX
RX - TX
gnd-gnd
Now you should have serial comms between your PC and your AVR.   NOTE: the AVR needs a xtal in order to have an accurate and stable clock for async comms to work well!
No, that's not necessarily true.
eg, Keil has a simulator[1] which can send the simulated UART output to a COM port. So you could loop that back to a terminal on another real COM port, or use something like com0com to do it "virtually"
http://com0com.sourceforge.net/
However, given chips with on-board debug, I found it just as easy to use a real devboard - and that was over ten years ago.
Nowadays, given devboards with the debugger and virtual COM port built-in, it would be even more so.
[1] Of course, not an AVR simulator - but the principle applies.
EDIT
But, as pointed out in #8, a serial port and terminal is not the way to do what the OP is asking anyhow.
In case it's not clear what I am suggesting is that in either hardware debugging or simulation you use:
http://www.atmel.com/webdoc/GUID...
If you direct this to the location of "Rx_Buffer" or whatever your UART buffer is called you can immediately see the characters/bytes in the buffer.
You do not need to employ a UART to send them "out" of the AVR or a terminal program to take them "in" and display them.
The memory view in AS7 will let you "see" the buffer contents directly.
You  also have facilities to view your variables by name: http://www.atmel.com/webdoc/GUID...
EDIT
eg,
I found this yesterday. Thanks Neil!  :) I will keep you posted.
I guess it's horses for courses but for "buffers" I think you are going to find a memory window rather than a variable watch is more useful for this kind of thing.
(well I do).
I will keep track of both.
Probably a combination of both - a memory view to see the content, and watches for the read & write indexes.
A watch can also be useful when you're interested in a particular buffer entry - eg, my_buffer[87] - rather than having to manually count through a memory view.
I want to use a printf() function for serial printing. I added the stdio.h header. I was trying to define a stream based on a reference online. But its' showing me this error.
Why??
After it's been amply demonstrated that you really do not need to do that!!
Does this AVR have two UARTs then?
As to the error, do you know what a "function declaration" is in C and why we need/use them?
or, in fact, what any declaration is?
Here's the UART definitions from the header
//UART define
//#define UART_DBG  //debug UART0
#ifdef UART_DBG
  #define UART_RECV_VECTOR SIG_UART0_RECV
  #define UART_TX_VECTOR   SIG_UART0_DATA
  #define UART_UDR         UDR0
  #define UART_UDRE        (1<<UDRE0)
  #define UART_UDRIE       (1<<UDRIE0)
  #define UART_UCSRA       UCSR0A
  #define UART_UCSRB       UCSR0B
  #define UART_UCSRC       UCSR0C
  #define UART_UBRRL       UBRR0L
  #define UART_TXC         TXC0
  #define UART_RXC         RXC0
  #define UART_TXEN        TXEN0
  #define UART_RXEN        RXEN0
  #define UART_ERRORS      ((1<<FE0)|(1<<DOR0)|(1<<UPE0))
  #define UART_UCSRB_INIT  ((1<<RXCIE0) | (0<<UDRIE0) | (1<<RXEN0) | (1<<TXEN0))
  #define UART_UCSRC_INIT  ((1<<UCSZ01) | (1<<UCSZ00))
#else
  #define UART_RECV_VECTOR USART1_RX_vect
  #define UART_TX_VECTOR   USART1_UDRE_vect
  #define UART_UDR         UDR1
  #define UART_UDRE        (1<<UDRE1)
  #define UART_UCSRA       UCSR1A
  #define UART_UCSRB       UCSR1B
  #define UART_UCSRC       UCSR1C
  #define UART_UBRRL       UBRR1L
  #define UART_SPEED       51
  #define UART_ERRORS      ((1<<FE1)|(1<<DOR1)|(1<<UPE1))
  #define UART_UCSRA_INIT  ((1<<TXC1) | (1<<U2X1))
  #define UART_UCSRB_INIT  ((1<<RXCIE1) | (0<<UDRIE1) | (1<<RXEN1) | (1<<TXEN1))
  #define BL_UCSRB_INIT    ((1<<RXEN1) | (1<<TXEN1))
  #define UART_UCSRC_INIT  ((1<<UCSZ11) | (1<<UCSZ10))
  #define UART_TXC         TXC1
  #define UART_RXC         RXC1
#endif
I could only locate UART definitions defined under the else condition in the project.
It tells the compiler what the function parameters are, what return type, etc.,
I wanted to play with code. I am able to see whats going in the memory.
So the firmware in the embedded board starts functioning based on commands from an application software (AS). So, the AS issues an opcode 02 03 11 12 03. I want to make the board independent of the application software. Forget the board, atleast the firmware. For now the firmware is doing a dummy capture. I would like the firmware to do a real time operation and be able to identify multiple modulation schemes and process that data accordingly. I tried inputting the opcode on a terminal like termite and its displaying some random values; all numbers.
In your screenshot in your post #25 you try to use usart_putchar_printf() (in the macro call to FDEV_SETUP_STREAM) before you actually define it.
Swap those two. First the definition, then do the macro call.
Any function must be "seen", either by a definition (i.e. complete implementation) or by its declaration (its definition or just its prototype) before it is being used (referenced). This is absolutely basic C knowledge. IIRC we've advised you in the past to get a C textbook and read. That advice still stands.
Ok. I changed that.
static int uart_putchar(char c, FILE *stream);
 static FILE mystdout = FDEV_SETUP_STREAM(uart_putchar, NULL, _FDEV_SETUP_WRITE);
  if (c == '\n')
  uart_putchar('\r', stream);
  loop_until_bit_is_set(UCSRA, UDRE);
  UDR = c;
  return 0;
I have these two errors. I would shamelessly accept that my exposure to C in real world is less (I would say programming in general). This project has got me hooked on it now. Yes, I also have a text book on C. but Embedded C is completely new to me.
Update:
I changed the UCSRA and UDRE to how they are defined to in headers.
RE: post #34
7 of the warnings there say "This header file is obsolete" talking about your use of <avr/signal.h>. The message even says use <avr/interrupt.h> instead. Why on earth are you ignoring things like this?!?
As for UCSRA being undeclared. It should be (a) if you use the <avr/io.h> as you should and (b) you are actually building for a model of AVR that has a register called UCSRA
This is a complete guess but I think you probably do include the io.h header so presumably the AVR you are using is one that does not have UCSRA. Is it a "modern" AVR like mega48/88/168/328 or perhaps mega164/324/644/1284? Those models have UCSR0A not UCSRA for the first (sometimes only) UART. The same is true if UDR. The register is probably UDR0 in fact.
In #29 you posted some code (without any explanation) that mentions things like UCSR0A, UCSR1A, UDR0 and UDR1. That seems to confirm that you may be building for a "modern" (like last 10 years) model of AVR. The code you have found using UCSRA/UDR is probably from a 10+ year old AVR
Just start by telling us which model of AVR it is you are trying to use.
+1 .
Never ignore warnings. Just because they are warnings (rather than errors) does not mean they are always benign.
Are you referring to the MCU? If yes, atmega64, 8 bit. The avr/interrupt.h warning. I have replaced the avr/signal.h with the avr/interrupt.h in all the program files. It still shows this error SOMETIMES,  which is kind of weird. I have been noting this for sometime : whenever I add a new piece of code to the program, I get that error.
I changed UDR to UART_UDR and now I have one warning - mystdout defined but not used <-Wunused-variable>.
That's a warning that most programmers always ignore.
Try actually reading the data sheet. The datasheet for atmega 64 tells you that it has two UART so it has UCSR0A and UCSR1A. Equally it has UDR0 and UDR1.
I was going through the avr library manual and came across #defines in uppercase and lowercase like this one below. Can anyone tell me what's the difference?
#define fdev_setup_stream(stream, put, get, rwflag)
#define FDEV_SETUP_STREAM(put, get, rwflag)
two things:
1) you do know there is a user manual?
2) so what you are looking at has to be read in context:
#if defined(__DOXYGEN__)
   \brief Setup a user-supplied buffer as an stdio stream
   This macro takes a user-supplied buffer \c stream, and sets it up
   as a stream that is valid for stdio operations, similar to one that
   has been obtained dynamically from fdevopen(). The buffer to setup
   must be of type FILE.
   The arguments \c put and \c get are identical to those that need to
   be passed to fdevopen().
   The \c rwflag argument can take one of the values _FDEV_SETUP_READ,
   _FDEV_SETUP_WRITE, or _FDEV_SETUP_RW, for read, write, or read/write
   intent, respectively.
   \note No assignments to the standard streams will be performed by
   fdev_setup_stream().  If standard streams are to be used, these
   need to be assigned by the user.  See also under
   \ref stdio_without_malloc "Running stdio without malloc()".
#else  /* !DOXYGEN */
#define fdev_setup_stream(stream, p, g, f) \
	do { \
		(stream)->put = p; \
		(stream)->get = g; \
		(stream)->flags = f; \
		(stream)->udata = 0; \
	} while(0)
#endif /* DOXYGEN */
DOXYGEN is the program that creates the documentation in (1) from this header file. What the above section of code says is that "when parsing this header, if generating the documentation then use the first part, but for building your "normal" AVR programs use the second part". So the #define you referred to is simply a dummy one for documentation purposes. The true definition that is used is:
	do { \
	} while(0)
So you create a FILE stream object then use this function to populate the function pointers and flags within it.
As to the difference between the upper case and lower case versions. While there are subtle differences the actual intention is that FDEV_SETUP_STREAM is used in C and fdev_setup_stream() in C++. The latter has to exist because the former uses a feature of C (Named initialisers) that is not in C++
Thanks clawson. :)
One more question: Should I be making these changes in the main.c or UART source file?
It's not clear to me what "changes" you are talking about.
Changes for a user supplied stdio stream.
I would be tempted to keep that with the UART stuff. Maybe just make it part of uart_init() that stdin/stdout are connected to the local uart_getchar() and uart_putchar() routines so you main can look like:
#include "uart.h"
int main(void) {
    uart_init(); // maybe pass a baud rate here?
    printf("hello");
That keeps main() very "clean" so there's no knowledge of the connection to stdout here.
OTOH you might want to retain control of whether stdout connects to the UART output channel. Some libraries choose to do it more like:
#include "uart.h"
int main(void) {
    uart_connect_to_stdio();
    printf("hello");
so that the connection is more obvious and also so it can optionally be removed.
So yesterday, I put a main in the main.c file and the obvious happened; the program didn't compile. I am guessing defining the function for serial printing could be done in the uart source file. The init_uart() you are talking about is defined as UARTIni() under level4.c source file with its declarations and macros defined in level4.h. I am guessing I have create that function for serial printing in UART source file.
You do know about things like extern and function declarations etc?
Ultimately the code in a single C file can be split in any way you choose. But often it takes a little effort to get "cross links" between files working. For data you will need "extern" declarations so the non-implementing file can "see" the data in the other. For functions you do it by a split of function declaration and definition with the declarations usually being placed in a shared header file. Were you doing this?
I am getting a feel of it now. There are a lot of such declarations especially extern in the project. I am doing this on AS7 (is that what you meant?) and all the files are in C(with reference to the io stream declaration - does it matter if I go for the uppercase or lowercase declarations - I read that the upper case is used as an initializer for a variable type 'FILE'
Edited: I am getting a feel of it now. There are a lot of such declarations especially extern in the project. I haven't made much changes to the code yet - I will try doing it and keep it posted. and all the files are in C(with reference to the io stream declaration - does it matter if I go for the uppercase or lowercase declarations - I read that the upper case is used as an initializer for a variable type 'FILE'
How do you delete a comment on here?
Any views on this one?
http://www.avrfreaks.net/forum/o...
Do you have specific questions about it?
As Cliff says in that thread, the first post in it is more or less a repetition of what is written in the official avrlibc documentation.
In my previous attempt, I had done this:
 static int
  if (c == '\n')
  loop_until_bit_is_set(UART_UCSRA, UART_UDRE);
  UART_UDR = c;
  return 0;
 //some other stuff
 UARTIni();
 stdout = &mystdout;
 printf("Hello World!\n");
 return 0;
 //more other stuff
Errors:
After adding the code  in the link with some changes, instead of the previous one:
 if (c == '\a')			//'\a'
  fputs("*ring*\n", stderr);
  return 0;
 if (c == '\n')			//
 loop_until_bit_is_set(UART_UCSRA, UDRE);
 UART_UDR = c;
 return 0;
int	uart_getchar(FILE *stream)
 uint8_t c;
 char *cp, *cp2;
 static char b[UART_IN_BUFFER_SIZE];
 static char *rxp;
 if (rxp == 0)
 for (cp = b;;)
  loop_until_bit_is_set(UART_UCSRA, RXC);
  if (UART_UCSRA & _BV(FE))
  return _FDEV_EOF;
  if (UART_UCSRA & _BV(DOR))
  return _FDEV_ERR;
  c = UART_UDR;
  //behaviour similar to Unix stty ICRNL
  if (c == '\r')
  c = '\n';
  if (c == '\n')
   *cp = c;
   uart_putchar(c, stream);
   rxp = b;
   break;
  else if (c == '\t')
  c = ' ';
  if ((c >= (uint8_t)' ' && c <= (uint8_t)'\x7e') ||
  c >= (uint8_t)'\xa0')
   if (cp == b + UART_IN_BUFFER_SIZE - 1)
   uart_putchar('\a', stream);
    *cp++ = c;
   continue;
  switch (c)
   case 'c' & 0x1f:
   return -1;
   case '\b':
   case '\x7f':
   if (cp > b)
    uart_putchar('\b', stream);
    uart_putchar(' ', stream);
    cp--;
   break;
   case 'r' & 0x1f:
   for (cp2 = b; cp2 < cp; cp2++)
   uart_putchar(*cp2, stream);
   break;
   case 'u' & 0x1f:
   while (cp > b)
    cp--;
   break;
   case 'w' & 0x1f:
   while (cp > b && cp[-1] != ' ')
    cp--;
   break;
 c = *rxp++;
 if (c == '\n')
 rxp = 0;
 return c;
FILE uart_str = FDEV_SETUP_STREAM(uart_putchar, uart_getchar, _FDEV_SETUP_RW);
stdout = stdin = &uart_str;
I still get errors:
Question: What I am doing wrong here? When does one use vfprintf and vfscanf?
Possibly never (explicitly). the vfprintf(...) function is primarily the "worker" behind both printf(...) and sprintf(...). When documentation mentions vsprintf(...) it most likely does so to document that behavior that printf(...) and sprintf(...) shares, rather than documenting it for both of those two functions.
We can't tell.
You've shown a snippet of code, of about 100 lines. Yet all error messages in your screen dump are at line number 410, except for the venerable "recipe failed" - which is a stupid error message, better explained by the complete build output.
Speaking of that, haven't we told you before to switch to the output tab and post complete build output rather than those meaningless screen shots? If we've missed that, here it comes: Don't post screen shots. For build errors, post complete build output (switch to output tab, mark everything, copy and paste in a post here.
When posting such errors, also post the complete source file(s) (perhaps as attachments).
I wanted a green signal to do that. Thanks Johan.
------ Build started: Project: EMTestRun, Configuration: Debug AVR ------
Build started.
Project "EMTestRun.cproj" (default targets):
Target "PreBuildEvent" skipped, due to false condition; ('$(PreBuildEvent)'!='') was evaluated as (''!='').
Target "CoreBuild" in file "C:\Program Files (x86)\Atmel\Studio\7.0\Vs\Compiler.targets" from project "E:\EMTestRunDev\EMTestRun\EMTestRun\EMTestRun.cproj" (target "Build" depends on it):
	Task "RunCompilerTask"
		Shell Utils Path C:\Program Files (x86)\Atmel\Studio\7.0\shellUtils
		C:\Program Files (x86)\Atmel\Studio\7.0\shellUtils\make.exe all --jobs 4 --output-sync
		Building file: .././level1_4026.c
		Invoking: AVR/GNU C Compiler : 5.4.0
		In file included from .././level1_4026.c:61:0:
c:\program files (x86)\atmel\studio\7.0\toolchain\avr8\avr8-gnu-toolchain\avr\include\avr\signal.h(36,2): warning: #warning "This header file is obsolete.  Use <avr/interrupt.h>." [-Wcpp]
		"C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-gcc.exe"  -x c -funsigned-char -funsigned-bitfields -DDEBUG  -I"C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.2.132\include"  -O1 -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -g2 -Wall -mmcu=atmega64 -B "C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.2.132\gcc\dev\atmega64" -c -std=gnu99 -MD -MP -MF "level1_4026.d" -MT"level1_4026.d" -MT"level1_4026.o"   -o "level1_4026.o" ".././level1_4026.c"
		Finished building: .././level1_4026.c
		Building file: .././level1_41xx.c
		"C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-gcc.exe"  -x c -funsigned-char -funsigned-bitfields -DDEBUG  -I"C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.2.132\include"  -O1 -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -g2 -Wall -mmcu=atmega64 -B "C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.2.132\gcc\dev\atmega64" -c -std=gnu99 -MD -MP -MF "level1_41xx.d" -MT"level1_41xx.d" -MT"level1_41xx.o"   -o "level1_41xx.o" ".././level1_41xx.c"
		Finished building: .././level1_41xx.c
		In file included from .././level1_41xx.c:63:0:
		Building file: .././boot_ld.c
		"C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-gcc.exe"  -x c -funsigned-char -funsigned-bitfields -DDEBUG  -I"C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.2.132\include"  -O1 -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -g2 -Wall -mmcu=atmega64 -B "C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.2.132\gcc\dev\atmega64" -c -std=gnu99 -MD -MP -MF "boot_ld.d" -MT"boot_ld.d" -MT"boot_ld.o"   -o "boot_ld.o" ".././boot_ld.c"
		Finished building: .././boot_ld.c
		Building file: .././level2.c
		"C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-gcc.exe"  -x c -funsigned-char -funsigned-bitfields -DDEBUG  -I"C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.2.132\include"  -O1 -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -g2 -Wall -mmcu=atmega64 -B "C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.2.132\gcc\dev\atmega64" -c -std=gnu99 -MD -MP -MF "level2.d" -MT"level2.d" -MT"level2.o"   -o "level2.o" ".././level2.c"
		Finished building: .././level2.c
		.././level2.c: In function 'ExtractData':
E:\EMTestRunDev\EMTestRun\EMTestRun\level2.c(581,20): warning: variable 'column_parity' set but not used [-Wunused-but-set-variable]
		   register uint8_t column_parity;
E:\EMTestRunDev\EMTestRun\EMTestRun\level2.c(580,20): warning: variable 'line_parity' set but not used [-Wunused-but-set-variable]
		   register uint8_t line_parity;
		Building file: .././level2_4026.c
		"C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-gcc.exe"  -x c -funsigned-char -funsigned-bitfields -DDEBUG  -I"C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.2.132\include"  -O1 -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -g2 -Wall -mmcu=atmega64 -B "C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.2.132\gcc\dev\atmega64" -c -std=gnu99 -MD -MP -MF "level2_4026.d" -MT"level2_4026.d" -MT"level2_4026.o"   -o "level2_4026.o" ".././level2_4026.c"
		Finished building: .././level2_4026.c
		In file included from .././level2_4026.c:61:0:
		Building file: .././level2_41xx.c
		"C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-gcc.exe"  -x c -funsigned-char -funsigned-bitfields -DDEBUG  -I"C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.2.132\include"  -O1 -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -g2 -Wall -mmcu=atmega64 -B "C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.2.132\gcc\dev\atmega64" -c -std=gnu99 -MD -MP -MF "level2_41xx.d" -MT"level2_41xx.d" -MT"level2_41xx.o"   -o "level2_41xx.o" ".././level2_41xx.c"
		Finished building: .././level2_41xx.c
		In file included from .././level2_41xx.c:61:0:
		Building file: .././level3_4026.c
		"C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-gcc.exe"  -x c -funsigned-char -funsigned-bitfields -DDEBUG  -I"C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.2.132\include"  -O1 -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -g2 -Wall -mmcu=atmega64 -B "C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.2.132\gcc\dev\atmega64" -c -std=gnu99 -MD -MP -MF "level3_4026.d" -MT"level3_4026.d" -MT"level3_4026.o"   -o "level3_4026.o" ".././level3_4026.c"
		Finished building: .././level3_4026.c
		In file included from .././level3_4026.c:64:0:
		Building file: .././level4.c
		In file included from .././level4.c:73:0:
E:\EMTestRunDev\EMTestRun\EMTestRun\level4.c(413,1): error: conflicting types for '__iob'
c:\program files (x86)\atmel\studio\7.0\toolchain\avr8\avr8-gnu-toolchain\avr\include\stdio.h(407,23): info: previous declaration of '__iob' was here
		 extern struct __file *__iob[];
E:\EMTestRunDev\EMTestRun\EMTestRun\level4.c(413,16): warning: assignment makes integer from pointer without a cast [-Wint-conversion]
E:\EMTestRunDev\EMTestRun\EMTestRun\level4.c(413,10): error: invalid initializer
		make: *** [level4.o] Error 1
		"C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-gcc.exe"  -x c -funsigned-char -funsigned-bitfields -DDEBUG  -I"C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.2.132\include"  -O1 -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -g2 -Wall -mmcu=atmega64 -B "C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.2.132\gcc\dev\atmega64" -c -std=gnu99 -MD -MP -MF "level4.d" -MT"level4.d" -MT"level4.o"   -o "level4.o" ".././level4.c"
E:\EMTestRunDev\EMTestRun\EMTestRun\Debug\Makefile(149,1): error: recipe for target 'level4.o' failed
		make: *** Waiting for unfinished jobs....
		Building file: .././level3.c
		"C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-gcc.exe"  -x c -funsigned-char -funsigned-bitfields -DDEBUG  -I"C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.2.132\include"  -O1 -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -g2 -Wall -mmcu=atmega64 -B "C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.2.132\gcc\dev\atmega64" -c -std=gnu99 -MD -MP -MF "level3.d" -MT"level3.d" -MT"level3.o"   -o "level3.o" ".././level3.c"
		Finished building: .././level3.c
		Building file: .././level3_41xx.c
		In file included from .././level3_41xx.c:64:0:
		"C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-gcc.exe"  -x c -funsigned-char -funsigned-bitfields -DDEBUG  -I"C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.2.132\include"  -O1 -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -g2 -Wall -mmcu=atmega64 -B "C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.2.132\gcc\dev\atmega64" -c -std=gnu99 -MD -MP -MF "level3_41xx.d" -MT"level3_41xx.d" -MT"level3_41xx.o"   -o "level3_41xx.o" ".././level3_41xx.c"
		Finished building: .././level3_41xx.c
		Building file: .././main.c
		"C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-gcc.exe"  -x c -funsigned-char -funsigned-bitfields -DDEBUG  -I"C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.2.132\include"  -O1 -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -g2 -Wall -mmcu=atmega64 -B "C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.2.132\gcc\dev\atmega64" -c -std=gnu99 -MD -MP -MF "main.d" -MT"main.d" -MT"main.o"   -o "main.o" ".././main.c"
		Finished building: .././main.c
	Done executing task "RunCompilerTask" -- FAILED.
Done building target "CoreBuild" in project "EMTestRun.cproj" -- FAILED.
Done building project "EMTestRun.cproj" -- FAILED.
Build FAILED.
========== Build: 0 succeeded or up-to-date, 1 failed, 0 skipped ==========
I am still getting the signal.h warning. I am using the interrupt.h
Warning        #warning "This header file is obsolete.  Use <avr/interrupt.h>." [-Wcpp]    EMTestRun    c:\program files (x86)\atmel\studio\7.0\toolchain\avr8\avr8-gnu-toolchain\avr\include\avr\signal.h    36
This is line 410, right?
You can't do that outside of a function.
Edit: in your latest post it is line 413
Stefan Ernst
Ok. So in what function do I put that in?
Look at the lines just before it in the build output. Here's one example from your build output:
All those line together tell the true story:
It starts with the build system saying it compiles .././level3_4026.c , and ends with the warning about avr/signal.h . So, there is no question about avr/signal.h being included in .././level3_4026.c . You have several such errors.
UARTIni
Stefan Ernst
Solved that error. Thanks Johan, I hardly take a look at the build output. That was an eye opener.
I did that.
Build started.
		.././level4.c: In function 'UARTIni':
E:\EMTestRunDev\EMTestRun\EMTestRun\level4.c(294,21): error: 'uart_str' undeclared (first use in this function)
E:\EMTestRunDev\EMTestRun\EMTestRun\level4.c(294,21): info: each undeclared identifier is reported only once for each function it appears in
		.././level4.c: At top level:
E:\EMTestRunDev\EMTestRun\EMTestRun\level4.c(409,13): warning: 'uart_str' defined but not used [-Wunused-variable]
		 static FILE uart_str = FDEV_SETUP_STREAM(uart_putchar, uart_getchar, _FDEV_SETUP_RW);
Build FAILED.
uart_str  - undeclared error
You also need the
prior to the
David (aka frog_jr)
