SAM-BA v2.16 Applets Compilation Error
3 posts / 0 new
 Need help with compilation of applets for SAM-BA v2.16 on windows platform. As i am using a custom board for that i need to compile the applets. I tried compiling the applets with the customize settings but it stuck ended me at following below mention error in the image file. I thought may be my customization are wrong but for the default present applets i tried compiling there also i got same error. And i have followed the customization procedure for the SAM-BA which is present on website i followed the steps.
I have compiled the default applets for AT91SAM9g15 and i getting this error.Please provide any suggestion or solution for this.Thanks in advance.
Thanks & regard
Vijay Patil
Well the error is about a '[' character - so maybe looks for a stray one in makefile/batch file being used to build.
I bet the author has done something like:
[Insert path here]arm-sometool -some_parameters
with the intention that you edit the file and replace [Insert path here] with the right value.
Hi clawson,
I have checked withe make file, i guess the it is not recognising the command.
The statement is something like this,
@[ -e $(INSTALLDIR) ] || mkdir $(INSTALLDIR)
and -e is the preprocessing directoey i guess.
Please help if you know this.
Thnaks in advance.
