Split from: OPERAND 1 OUT OF RANGE: 0x7A
9 posts / 0 new
CONVERSION:
LDI R17, 0x00
MOV R0, R17
MOV R1, R17
CPI R16, 0x0A
BRBS H1
H0:
SUBI R16, 0x0A
INC R1
CPI R16, 0x0A
BRSH H0
LDI R17, 0x30
OR R1, R17
H1:
MOV R0, R16
LDI R17, 0x30
OR R0, R17
RET
MSGDISP:
LDI R31, HIGH(MSG<<1)
LDI R30, LOW(MSG<<1)
LOOP:
LPM R16, Z+
CPI R16, 0
BREQ HERE1
CALL DATAWRT
RJMP LOOP
HERE1:
RET
CMNDWRT:
  MOV  R27, R16
  ANDI R27, 0xF0
  IN  R26, LCD_PRT
  ANDI R26, 0x0F
  OR  R26, R27
  OUT  LCD_PRT, R26
  CBI  LCD_PRT, LCD_RS
  CBI  LCD_PRT, LCD_RW
  SBI  LCD_PRT, LCD_EN
  CALL SDELAY
  CBI  LCD_PRT, LCD_EN
  CALL DELAY_100us
  MOV  R27, R16
  SWAP R27
  ANDI R27, 0xF0
  IN  R26, LCD_PRT
  ANDI R26, 0x0F
  OR  R26, R27
  OUT  LCD_PRT, R26
  SBI  LCD_PRT, LCD_EN
  CALL SDELAY
  CBI  LCD_PRT, LCD_EN
  CALL DELAY_100us
  RET
DATAWRT:
  MOV  R27, R16
  ANDI R27, 0xF0
  IN  R26, LCD_PRT
  ANDI R26, 0x0F
  OR  R26, R27
  OUT  LCD_PRT, R26
  SBI  LCD_PRT, LCD_RS //RS=1 for data write else it is 0
  CBI  LCD_PRT, LCD_RW
  SBI  LCD_PRT, LCD_EN
  CALL SDELAY
  CBI  LCD_PRT, LCD_EN
  MOV  R27, R16
  SWAP R27
  ANDI R27, 0xF0
  IN  R26, LCD_PRT
  ANDI R26, 0x0F
  OR  R26, R27
  OUT  LCD_PRT, R26
  SBI  LCD_PRT, LCD_EN
  CALL SDELAY
  CBI  LCD_PRT, LCD_EN
  CALL DELAY_100us
  RET
Somebody can explain me this code?? What function realize?
Formatted code - Moderator
1)  Use the <> (code tags) to post formatted source code.
2)  Use indentation to make it easier to read.
3)  Tell more about your mission.  Why should we decipher this block of uncommented source code?  Where did you get it?  Why do you need to explore it?
4)  For any complete answer, a complete program is needed.
5)  What have you done so far?  Which line in particular might have you "stuck"?  Have you used the AVR Instruction Set document to help?
http://www.atmel.com/images/Atme...
6)  It puts a message to a character LCD display.
I need to show in LCD display the values that contain the register ADCH and ADCL, but I don't know how to convert this values from binary to ASCII to show in LCD.
CONVERSION:
LDI R17, 0x00
MOV R0, R17
MOV R1, R17
CPI R16, 0x0A
BRBS H1
H0:
SUBI R16, 0x0A
INC R1
CPI R16, 0x0A
BRSH H0
LDI R17, 0x30
OR R1, R17
H1:
MOV R0, R16
LDI R17, 0x30
OR R0, R17
RET
MSGDISP:
LOOP:
LPM R16, Z+
CPI R16, 0
BREQ HERE1
CALL DATAWRT
RJMP LOOP
HERE1:
RET
CMNDWRT:
  MOV  R27, R16
  ANDI R27, 0xF0
  IN  R26, LCD_PRT
  ANDI R26, 0x0F
  OR  R26, R27
  OUT  LCD_PRT, R26
  CBI  LCD_PRT, LCD_RS
  CBI  LCD_PRT, LCD_RW
  SBI  LCD_PRT, LCD_EN
  CALL SDELAY
  CBI  LCD_PRT, LCD_EN
  CALL DELAY_100us
  MOV  R27, R16
  SWAP R27
  ANDI R27, 0xF0
  IN  R26, LCD_PRT
  ANDI R26, 0x0F
  OR  R26, R27
  OUT  LCD_PRT, R26
  SBI  LCD_PRT, LCD_EN
  CALL SDELAY
  CBI  LCD_PRT, LCD_EN
  CALL DELAY_100us
  RET
DATAWRT:
  MOV  R27, R16
  ANDI R27, 0xF0
  IN  R26, LCD_PRT
  ANDI R26, 0x0F
  OR  R26, R27
  OUT  LCD_PRT, R26
  CBI  LCD_PRT, LCD_RW
  SBI  LCD_PRT, LCD_EN
  CALL SDELAY
  CBI  LCD_PRT, LCD_EN
  MOV  R27, R16
  SWAP R27
  ANDI R27, 0xF0
  IN  R26, LCD_PRT
  ANDI R26, 0x0F
  OR  R26, R27
  OUT  LCD_PRT, R26
  SBI  LCD_PRT, LCD_EN
  CALL SDELAY
  CBI  LCD_PRT, LCD_EN
  CALL DELAY_100us
  RET
>  I need the comments of this code because I am amateur programming in ASM. I don't understand.
See:
http://www.avrfreaks.net/comment/264489#comment-264489
David (aka frog_jr)
See http://www.avrfreaks.net/comment... full, illustrated examples of what this means & how to do it
Note the OP here was originally a hijack of this thread: http://www.avrfreaks.net/forum/o...
This comment applies:
In the original thread, Kartman wrote:
It would be a good learning exercise for you to work through the code and add your comments. I learn of lot of my asm skills from reverse engineering code. Also, note that just about anything you need to ask has been asked before and example code provided. The AVR has been around nearly 20 years, so there’s very few new questions. Use keywords like avr asm bin to dec etc when googling.
To the general question of showing on LCD. You need to keep dividing by 10 and storing the remainders. Then use them is reverse order, adding 0x30 to each one.
So if ADC is 735. Divide 10. Store remainder 5. Divide 73 that is left by 10. Store remainder 3. Divide by 10 again. Store remainder 7. You have reached 0 so stop converting. Now use the 7 then the 3 then the 5 that you stored (stack can be a good place for this). To each add 0x30 so 0x37, 0x33, 0x35. The LCD will show "735".
The key to all this is a divide 16 bit value by 8 bit value routine to do the /10 operations. Atmel have an application note with such routines.
PS in hex 10 is 0x0A. Wonder if that fact and the original code in #1 are in any way related?
