OPERAND 1 OUT OF RANGE: 0x7A
22 posts / 0 new
Hello, I have 5 errors in my code, I need to show in LCD temperature, but when I check the code, Atmel Studio said me that OPERAND 1 OUT OF RANGE: 0x6e,  OPERAND 1 OUT OF RANGE: 0x7A, OPERAND 2 OUT OF RANGE: 0x78, OPERAND 2 OUT OF RANGE: 0x79, I cant found the solution of this problem, somebody can help me, please?
MAIN:
NOP
LDI R16, HIGH(RAMEND)
OUT SPH, R16
LDI R16, LOW(RAMEND)
OUT SPH, R16
LDI R16, -255
OUT TCNT0, R16
LDI R16, 0x02
OUT TCCR0B, R16
LDI R16, (1<<TOIE0)
OUT TIMSK0, R16
CLR R16
LDI R16, 0B01100011
STS 0x7C, R16
LDI R16, 0B11001111
STS ADCSRA, R16
CALL LCD_Init
CALL MSGDISP
LDI R16, 0x0C
CALL CMNDWRT
SEI
1. Tell us what AVR model you're using.
2. Please, quote the error messages verbatim, and show what lines generates the respective errors.
But you show us only four of those...
3. This makes no sense:
LDI R16, -255
R16 is eight bits. The (signed) value range for an 8-bit byte is -128..+127.
The value -255 implies nine bits! If you simply want all bits in the byte set then 0xFF should do it. Or -127, if you want to be cryptic about  it.
The address you use for OUT is different to the address used in STS. The datasheet explains this.
LDI R16, -255
Im sorry for not especific information, Im using atmega 2560, and all errors are:
Severity Code Description Project File Line Source
Error Operand 1 out of range: 0x6e LAB2_V2 D:\Universidad\Microprocesadores\Microprocesadores\ESTUDIO DE PROMACIËN\LAB2_V2\LAB2_V2\main.asm 43 Build
Error Operand 1 out of range: 0x7a LAB2_V2 D:\Universidad\Microprocesadores\Microprocesadores\ESTUDIO DE PROMACIËN\LAB2_V2\LAB2_V2\main.asm 74 Build
Error Operand 2 out of range: 0x78 LAB2_V2 D:\Universidad\Microprocesadores\Microprocesadores\ESTUDIO DE PROMACIËN\LAB2_V2\LAB2_V2\main.asm 79 Build
Error Operand 2 out of range: 0x79 LAB2_V2 D:\Universidad\Microprocesadores\Microprocesadores\ESTUDIO DE PROMACIËN\LAB2_V2\LAB2_V2\main.asm 80 Build
Error Wrong number of operands LAB2_V2 D:\Universidad\Microprocesadores\Microprocesadores\ESTUDIO DE PROMACIËN\LAB2_V2\LAB2_V2\main.asm 101 Build
I'll be very greatful, I'll leave my code down here:
.include "m2560def.inc"
.ORG 0x00
.EQU LCD_PRT = PORTA  ;
.EQU LCD_DDR = DDRA ;
.EQU LCD_PIN = PINA ;
.EQU LCD_RS = 0  ;
.EQU LCD_RW = 1
.EQU LCD_EN = 2
RJMP MAIN
.ORG ADCCaddr
RJMP ADC_INT_HANDLER
.ORG 0x2E
RJMP TIMER0_INT
.ORG 0x100
MAIN:
NOP
OUT SPH, R16
OUT SPH, R16
LDI R16, -255
OUT TCNT0, R16
LDI R16, 0x02
OUT TCCR0B, R16
LDI R16, (1<<TOIE0)
OUT TIMSK0, R16
CLR R16
LDI R16, 0B01100011 ; CON EL BIT 6 SE USAN LOS 5V DEL ARDUINO, CON EL BIT 5 SE HACEN LOS 10 bits que representan la valor analógico convertido a decimal 1024.
; LOS BITS 0,1,2 Y 3 REPRESENTAN EL NUMERO DECIMAL DEL PIN QUE SE DESEA USAR QUE EN EST CASO ES ADC3
STS 0x7C, R16 ; ESTO SE ESTA CONFIGURANDO EN ADMUX
LDI R16, 0B11001111 ; CUANDO EL BIT 7 ESTA EN 1 EL ADC ESTA ENCENDIDO, EL BIT 6 PARA HACER CONVERSIÓN A-D, EL BIT 5 ESTA EN 0 PORQUE NO SE HABILITARA LA CONVERSIÓN AUTOMATICA,
; EL BIT 4 SE PONE A 0 PARA QUE DETECTE SOLO LA INTERRUPCIÓN DEL ADC, EL BIT 3 SE PONE A 1 PARA HABILITAR LA INTERRUPCION DEL ADC, (PRESCALER 128)
; PARA OBTENER UNA FRECUENCIA DE MUESTREO DE 125KHZ
STS ADCSRA, R16 ; ADCSRA
CALL LCD_Init
CALL MSGDISP
LDI R16, 0x0C
CALL CMNDWRT
SEI ; ACTIVAR INTERRUPCIONES GLOBALES
HERE:
NOP
RJMP HERE
MSG: .DB "TEMPERATURA: ",0
.ORG 0x250
TIMER0_INT:
SBI ADCSRA, ADSC ;COMIENZO DEL ADC, PRIMERA VEZ EL TOMARA 25/26 CICLOS DE RELOJ DEL ADC
RETI
.ORG 0x300
ADC_INT_HANDLER:
IN R17, ADCL ;LEE EL VALOR BAJO DEL LOS 8 BITS DEL ADC
IN R16, ADCH ;LEE EL VALOR ALTO DE LOS 8 BITS DEL ADC
CALL CONVERSION
MOV R16, R1
CALL DATAWRT
MOV R16, R0
CALL DATAWRT
; VOLVER A DOS PUNTOS DEL CURSOR
LDI R16, 0x10
CALL CMNDWRT
LDI R16, 0x10
CALL CMNDWRT
RETI
; CONVERTIR LOS VALORES ENTREGADOS POR EL ADC EN SU CORRESPONDIENTE VALOR EN DECIMAL
CONVERSION:
LDI R17, 0x00
MOV R0, R17
MOV R1, R17
CPI R16, 0x0A
BRBS H1
H0:
SUBI R16, 0x0A
INC R1
CPI R16, 0x0A
BRSH H0
LDI R17, 0x30
OR R1, R17
H1:
MOV R0, R16
LDI R17, 0x30
OR R0, R17
RET
LCD_Init:
LDI R21, 0xFF
OUT LCD_DDR, R21 ; PUERTO DE DATOS ES SALIDA PARA EL LCD
LDI R16, 0x33 ; INICIALICE EL LCD PARA DATOS DE 4 BITS
CALL CMNDWRT
CALL DELAY_2ms
LDI R16, 0x32 ; INICIALICE EL LCD PARA DATOS DE 4 BITS
CALL CMNDWRT
CALL DELAY_2ms
LDI R16, 0x28 ; 2 LINEAS, 5X7 MATRIZ
CALL CMNDWRT
CALL DELAY_2ms
LDI R16, 0x0E ; DISPLAY ENCENDIDO, CURSOR ENCENDIDO
CALL CMNDWRT
CALL DELAY_2ms
LDI R16, 0x01 ; LIMPIA LCD
CALL CMNDWRT
CALL DELAY_2ms
LDI R16, 0x06 ; DESPLAZA CURSOR A LA DERECHA
CALL CMNDWRT
RET
MSGDISP:
LDI R31, HIGH(MSG<<1)
LDI R30, LOW(MSG<<1)
LOOP:
LPM R16, Z+
CPI R16, 0
BREQ HERE1
CALL DATAWRT
RJMP LOOP
HERE1:
RET
CMNDWRT:
  MOV  R27, R16
  ANDI R27, 0xF0
  IN  R26, LCD_PRT
  ANDI R26, 0x0F
  OR  R26, R27
  OUT  LCD_PRT, R26
  CBI  LCD_PRT, LCD_RS
  CBI  LCD_PRT, LCD_RW
  SBI  LCD_PRT, LCD_EN
  CALL SDELAY
  CBI  LCD_PRT, LCD_EN
  CALL DELAY_100us
  MOV  R27, R16
  SWAP R27
  ANDI R27, 0xF0
  IN  R26, LCD_PRT
  ANDI R26, 0x0F
  OR  R26, R27
  OUT  LCD_PRT, R26
  SBI  LCD_PRT, LCD_EN
  CALL SDELAY
  CBI  LCD_PRT, LCD_EN
  CALL DELAY_100us
  RET
DATAWRT:
  MOV  R27, R16
  ANDI R27, 0xF0
  IN  R26, LCD_PRT
  ANDI R26, 0x0F
  OR  R26, R27
  OUT  LCD_PRT, R26
  SBI  LCD_PRT, LCD_RS //RS=1 for data write else it is 0
  CBI  LCD_PRT, LCD_RW
  SBI  LCD_PRT, LCD_EN
  CALL SDELAY
  CBI  LCD_PRT, LCD_EN
  MOV  R27, R16
  SWAP R27
  ANDI R27, 0xF0
  IN  R26, LCD_PRT
  ANDI R26, 0x0F
  OR  R26, R27
  OUT  LCD_PRT, R26
  SBI  LCD_PRT, LCD_EN
  CALL SDELAY
  CBI  LCD_PRT, LCD_EN
  CALL DELAY_100us
  RET
SDELAY:
  NOP
  NOP
  RET
DELAY_100us:
    ldi  r18, 3
    ldi  r19, 19
L2: dec  r19
    brne L2
    dec  r18
    brne L2
DR0: CALL SDELAY
  DEC  R17
  BRNE DR0
  POP  R17
  RET
  DELAY_2ms:
    ldi  r18, 42
    ldi  r19, 142
L1: dec  r19
    brne L1
    dec  r18
    brne L1
    nop
It's in section 8.4 of the datasheet.
Greg Muth
Portland, OR, US
Yeah, I change the syntaxis to STS, but the errors continue
I just created a test project and loaded your code and hit BUILD, and got the same errors.  All of them are very straight forward:
Error    1    Operand 1 out of range: 0x7a    Z:\Scratch_Pad\AssemblerApplication1\AssemblerApplication1\AssemblerApplication1.asm    133    0    AssemblerApplication1
 Points to:
SBI will not work on that register as it is out of the range of the lower 32 I/O registers as it explains in the Assembly help file:
Now this error:
Error    1    Operand 1 out of range: 0x6e    Z:\Scratch_Pad\AssemblerApplication1\AssemblerApplication1\AssemblerApplication1.asm    75    0    AssemblerApplication1
Points to this line:
out TIMSK0, R16
Again, the OUT instruction cannot operate on the register as it is not in the lower 32 I/O registers.  Use STS istead
Error    3    Operand 2 out of range: 0x78    Z:\Scratch_Pad\AssemblerApplication1\AssemblerApplication1\AssemblerApplication1.asm    143    0    AssemblerApplication1
points to:
Again, IN does not operate on that register as it is out of range.  Try using LDS  instead.
Same thing for the other errors.
Now this one:
Error    5    Wrong number of operands    Z:\Scratch_Pad\AssemblerApplication1\AssemblerApplication1\AssemblerApplication1.asm    187    0    AssemblerApplication1
Which points to this:
BRBS H1
 YOu are missing what bit you are testing.
Lastly, in this routine at the very end of the code:
  DELAY_2ms:
    ldi  r18, 42
    ldi  r19, 142
L1: dec  r19
    brne L1
    dec  r18
    brne L1
    nop
You need a RET otherwise the program dives off into nowhere.
 Points to:
Now this error:
out TIMSK0, R16
points to:
Now this one:
BRBS H1
  DELAY_2ms:
    ldi  r18, 42
    ldi  r19, 142
L1: dec  r19
    brne L1
    dec  r18
    brne L1
    nop
Thank you Jim, right now I reduce 4 errors, I made some changes to the timer, but Atmel Studio show me that INVALID REGISTER LINE 84: After 1s Start ADC...  and ADSC is the register to clear the ADC, I dont understant this error.
I
You cannot alter a bit using STS.  You will need to set up the bits in a temp register, then use the OR instruction to set the bit.
In your case:
LDI  TEMP, 0x40;            //Bit 6 is ADSC
OR   ADCSRA,TEMP;          //Set teh bit, leaving the others alone
Untested, and I am sure others may have a better way.
JIm
In your case:
JIm
I used:
LDI R25, 0x40
OR ADCSRA, R25
But the error continue.
What does the error say?
volterius wrote:
I used: LDI R25, 0x40 OR ADCSRA, R25   But the error continue.
Yes, bevcause the OR instruction can not handle ADCSRA, which is an I/O register. Only CPU registers (R0..R31) can be used in the OR instruction.
First thing you need to do when getting these errors is to look in the document AVR Instruction Set: http://www.atmel.com/Images/Atme...
For the OR instruction:
    Syntax:        Operands:                  Program Counter:
(i) OR Rd,Rr       0 ≤ d ≤ 31, 0 ≤ r ≤ 31     PC ← PC + 1
Notice the Rd and Rr notation where the "R" implies a CPU register and under "Operands" you can see which CPU registers that can be used. In the case of OR it is any of the CPU registers.
So you'd need to
1) Get the current ADCSRA value into a CPU register (R0..R31) . say Rn
2) Get the immediate value  0x40 into another register, say Rm
3) OR the value of Rm into Rn
4) Store the value in Rn into ADCSRA
But notice that there is also an instruction ORI that will effectively combine steps 2) ans 3) above leaving you with (sketchy, untested)
1) Load ADCSRA into a CPU register (Rn)
2) ORI the immediate value 0x40 into that same register
3) Store that registers value back to ADCSRA
Surely the same "Invalid register" as before? See my previous post.
So you'd need to
Thank you, I wrote this and the errors have been solve:
LDI  R25, 0x40;
OR R26, R25
STS ADCSRA, R26
Right now, Im going to upload the code for the simulation.
Yeah, I created a new project and ran my code and got the error as well.  Then I looked at the help file and saw my blunder.  My apologies to VOLTERIUS for the wrong code, and thanks to Johan for catching it.  I am getting too used to using C nowadays it would seem.
volterius wrote:
OR R26, R25
What does R26 contain? Where have you initialized it?
I believe you need:
LDS R26, ADCSRA     ; Get current value of ADCSRA into R26
ORI R26, 0x40       ; Set the ADSC bit
STS ADCSRA, R26     ; Write the modified value back to ADCSRA
Edit: correct comments
David (aka frog_jr)
hello the code worked well, but at the time of simulating using proteus, the value shown on the LCD is half of the value delivered by the LM35:
I think that the solution is the multiply by 2 the value of the registers in the conversion, or failing to move those current values to a new register and then make the sum of them and that the value generated in a new record is the one that comes out of the conversion, any other solution?
CONVERSION:
LDI R17, 0x00
MOV R0, R17
MOV R1, R17
CPI R16, 0x0A
BRLO H1
H0:
SUBI R16, 0x0A
INC R1
CPI R16, 0x0A
BRSH H0
LDI R17, 0x30
OR R1, R17
H1:
MOV R0, R16
LDI R17, 0x30
OR R0, R17
RET
With this code I have the problem.
CONVERSION:
LDI R17, 0x00
MOV R0, R17
MOV R1, R17
CPI R16, 0x0A
BRLO H1
H0:
SUBI R16, 0x0A
INC R1
CPI R16, 0x0A
BRSH H0
LDI R17, 0x30
OR R1, R17
H1:
MOV R0, R16
LDI R17, 0x30
OR R0, R17
RET
Right now the program is working correctly, I only change the ADMUX register with:
LDI R16, 0B11100011
STS 0x7C, R16
It use the Internal 2.56V Voltage Reference with external capacitor at AREF pin
thanks to the people who helped me.
You can use these handy macros which will autopick IN or LDS and also OUT or STS for you...must put the macro scripts at the top of your file
example:  OUTREG ADCSRA, r27  ;copies r27 into ADCSRA
example:  INREG   temp, ADMUX  ;read copy of ADMUX into register temp  (such as .def temp=r24)
; usage: InReg reg, addr
.macro InReg
    .if @1 < 0x40
        in @0, @1
    .elif ((@1 >= 0x60) && (@1 < SRAM_START))
        lds @0,@1
    .else
       .error "InReg: Invalid I/O register address"
    .endif
.endmacro
; usage: OutReg addr, reg
.macro OutReg
    .if @0 < 0x40
        out @0, @1
    .elif ((@0 >= 0x60) && (@0 < SRAM_START))
        sts @0,@1
    .else
       .error "OutReg: Invalid I/O register address"
    .endif
.endmacro
torresuao wrote:
>  I need the comments of this code because I am amateur programming in ASM. I don't understand.
It would be a good learning exercise for you to work through the code and add your comments. I learn of lot of my asm skills from reverse engineering code.
Also, note that just about anything you need to ask has been asked before and example code provided. The AVR has been around nearly 20 years, so there’s very few new questions. Use keywords like avr asm bin to dec etc when googling.
Kartman wrote:
Where? No sign of either that comment or that username in the entire thread. Split?
There was a hijack post that now seems to have been deleted.
EDIT
Found it: http://www.avrfreaks.net/forum/s...
