End of Atmelstudio
26 posts / 0 new
Hi, iam devlooper of c/c++ systems, and in first i use actual Visualstudio, in past times the new Atmelstudio7 is not more working
after installing it under W10, the devloopment of AVR stand still, and we have serch 1 year about solutions with none succseeds
I think is a war between MS and AS so no one can use both Programms on one system, but that is essential to continue on windows with
us software devlooping and debugging.  i am very down here, and i will lost customers by do nothing any more with the AVR Stuff.
Give it an alternative to compile and debug AVR systems without broken atmelstudio7 or an deep trick there let start the software .
Atmelstudio7 means immedately after klick "missing components ..."
If you install VS after AS, then sometimes you need to do a repair of Atmel Studio (if the VS installation messes with ourf registrations..)
:: Morten
Hi Meo,
the VS is always install first, it has many depends to the main project, after that we install AS. This comes up while install with a message box and means : that some things are wrong, but installation will be continue.
After next 20 Minutes the process ist complete. An Click on AtmelBugIcon pops up a box immedately and means some parts are wrong or missing. End of Session.
We have about 1 year to resolve the problem, have use all fixes from internet, re install clean install repair urinstall all registers we have taken.
The AS has all the years do problems but 2017 we can't hande it any more. Now we serch for alternates. we are not more able to handle atmel processors since new VS and W10.
This situation is more and more system relevant, we can't support us products with the old HEX files.
We need an alternate, this AS has lost my thrust, it's not repeatable and not installable on new systems, an lucky men u must they to have fun with that.
Give it an download for the main includes and libs / compiler and assembler ?  We are up to compile via scripts.
All my projects use the deep atmelstudio depends include/libs.. , we are hopeless.. and will be change to AnalogDevices. But  Not much better there :(
thx for answer
Total votes: 2
I dunno, I have AS4.19' AS6_2, and AS7 all running on a single Win10 Pro/64 machine without any issues worth mentioning...
Typically when complaints like this come in there is usually something else causing the hiccup. Are you using VS for anything else other than AS7?
A brute force method is a VM :
http://www.avrfreaks.net/forum/visual-studio-2015-update-1-incapacitates-atmel-studio-7#comment-1955576
IIRC, Atmel Studio 7 in VirtualBox with a USB interface is functional.
Atmel Studio 7 on VMware may exist (I have not searched for that)
A different VM tack is via Vagrant where Visual Studio is on VirtualBox, Hyper-V, VMware, and Parallels (i.e. Atmel Studio on Windows 10, Visual Studio via VM)
https://app.vagrantup.com/boxes/search?utf8=%E2%9C%93&sort=downloads&provider=&q=Visual+Studio
For a trial, install Atmel Studio 7.0.1417 onto Windows 10 then operate Visual Studio 2017 via a VM that Microsoft provides :
https://developer.microsoft.com/en-us/windows/downloads/virtual-machines
A possible alternative to a VM is Application Virtualization (App-V) on Windows 10 Enterprise and Windows Server 2016.
https://docs.microsoft.com/en-us/windows/application-management/app-v/appv-getting-started
A proposed solution is a virtual registry but that means forking Atmel Studio (Windows 10, Windows 10 S)
VisualGDB has tutorials on AVR and SAM for Microsoft Visual Studio.
AVR would be lacking there due to an interface via AVaRICE because :
  • reduced set of AVR
  • reduced functionality versus Atmel Studio
Would need to build AVaRICE from its repository to enable the Atmel-ICE interface.
Vagrant
https://www.vagrantup.com/
Development Environments Made Easy
Microsoft
Microsoft
Windows Blogs
Conversion options for bringing your existing desktop app to the Universal Windows Platform using the Desktop Bridge
By / Principal Program Manager Lead
Registry.dat – If the application writes to the registry at install time, or the app expects certain registry keys to be set when it starts, this information must be stored in a local application hive. At runtime, this hive is mounted and merged with the system registry so the application sees a merged view. The isolation provided by this model allows for no-impact install and uninstall guarantees provided by the UWP packaging model for apps in the Windows Store.
https://visualgdb.com/tutorials/avr/
https://visualgdb.com/tutorials/arm/at91sam7/
https://sysprogs.com/w/forums/topic/debugging-w-atmel-ice/
http://avarice.sourceforge.net/
Edits : Microsoft's VM for developers, App-V
What version, exactly?
And is it a full, paid-for edition, or one of the free ones - whatever they're called today ?
Hi awneil,
Microsoft Visual Studio Enterprise 2017
Version 15.3.5
VisualStudio.15.Release/15.3.5+26730.16
Microsoft .NET Framework
Version 4.7.02046
Installed Version: Enterprise
Visual Basic 2017   00369-90000-00000-AA462
Microsoft Visual Basic 2017
Visual C# 2017   00369-90000-00000-AA462
Microsoft Visual C# 2017
Visual C++ 2017   00369-90000-00000-AA462
Microsoft Visual C++ 2017
ASP.NET and Web Tools 2017   15.0.30726.0
ASP.NET Core Razor Language Services   1.0
Provides languages services for ASP.NET Core Razor.
JavaScript Language Service   2.0
Microsoft JVM Debugger   1.0
Provides support for connecting the Visual Studio debugger to JDWP compatible Java Virtual Machines
Microsoft MI-Based Debugger   1.0
Provides support for connecting Visual Studio to MI compatible debuggers
Microsoft Visual C++ Wizards   1.0
Microsoft Visual Studio VC Package   1.0
NuGet Package Manager   4.3.1
NuGet Package Manager in Visual Studio. For more information about NuGet, visit http://docs.nuget.org/.
Visual Studio Code Debug Adapter Host Package   1.0
Interop layer for hosting Visual Studio Code debug adapters in Visual Studio
Visual Studio tools for CMake   1.0
HOST THINKS
CPU Name
Intel® Core™ i7-6950X CPU @ 3.00GHz
Threading
1 CPU - 10 Core - 20 Threads
Frequency
4206.54 MHz (42 * 100.16 MHz) - Uncore: 2804.4 MHz
Multiplier
Current: 42 / Min: 12 / Max: 35
Architecture
Broadwell-E/EP / Stepping: M0 / Technology: 14 nm
CPUID / Ext.
6.F.1 / 6.4F
IA Extensions
MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX, AVX2, FMA3, TSX
Caches
L1D : 32 KB / L2 : 256 KB / L3 : 25600 KB
Caches Assoc.
L1D : 8-way / L2 : 8-way / L3 : 20-way
Microcode
Rev. 0x00000B00001C
TDP / Vcore
140 Watts / 1.502 Volts
Temperature
83 °C / 181 °F
Type
Retail (Stock Frequency : 3000 MHz)
Cores Frequencies
#00: 4206.54 MHz  #01: 4206.54 MHz  #02: 4206.54 MHz  #03: 4206.54 MHz 
#04: 4507.01 MHz  #05: 4206.54 MHz  #06: 4206.54 MHz  #07: 4206.54 MHz 
#08: 4206.54 MHz  #09: 4206.54 MHz 
Motherboard
Model
Asus RAMPAGE V EXTREME
Socket
Socket 2011 LGA
North Bridge
Intel Broadwell-E rev 01
South Bridge
Intel X99 rev 05
BIOS
American Megatrends Inc. 3301 (06/28/2016)
Memory (RAM)
Total Size
32768 MB
Type
Quad Channel (256 bit) DDR4-SDRAM
Frequency
1402.2 MHz - Ratio 1:28
Timings
17-18-18-36-2 (tCAS-tRC-tRP-tRAS-tCR)
Slot #1 Module
Corsair 8192 MB (DDR4-2137) - XMP 2.0 - P/N: CMD32GX4M4A2400C14
Slot #2 Module
Slot #3 Module
Slot #4 Module
Graphic Card (GPU)
GPU #1 Type
NVIDIA GeForce GTX 1080 (GP104) @ 139 MHz
GPU #1 Brand
EVGA Corp.
GPU #1 Specs
GP104-400 / Process: 16nm / Transistors: 7200M / Die Size: 314 mm² / TDP: 180W
GPU #1 Units
Shader Units: 2560 / Texture Units (TMU): 160 / Render Units (ROP): 64
GPU #1 VRAM
8192 MB GDDR5X 256 bit @ 405 MHz
GPU #1 APIs
DirectX 12.0 (12_1) / OpenGL 4.5 / OpenCL 1.2 / Vulkan 1.0
GPU #2 Type
GPU #2 Brand
EVGA Corp.
GPU #2 Specs
GPU #2 Units
GPU #2 VRAM
GPU #2 APIs
Storage (HDD/SSD)
Model #1
SAMSUNG SSD 830 Series
Capacity #1
128 GB
Model #2
SAMSUNG MZVLW512HMJP-00000
Capacity #2
512 GB
Model #3
Western Digital WDC WD2003FZEX-00SRLA0
Capacity #3
2000 GB
Display
Screen #1
ASUS PB287Q (ACI28A3)
Screen #1 Spec
27.8 inches (70.6 cm) / 3840 x 2160 pixels @ 30-80 Hz
Screen #2
Hewlett Packard HP LA2405x (HWP301F)
Screen #2 Spec
24 inches (61 cm) / 1920 x 1200 pixels @ 50-63 Hz
Screen #3
Screen #3 Spec
Miscellaneous
Windows Version
Microsoft Windows 10 (10.0) Professional 64-bit
Windows Subver.
(Build 15063)
CPU-Z Version
1.80.1 (64 bit)
This is an full registered version. And the ground why i use an computer :)
thx for answer ! But no one can help me, outer let me know what is the alternate AtmelChip Devlooper IDE (Eqlipse is it not) ?
Best regards
At this point I think this is one for Morten.
What you posted in #7 he might be able to decipher.
JIm
You haven't said what chip(s) you are using.
IAR, CodeVision, and Imagecraft spring to mind for AVR.
EDIT
typo
I know this is not an ideal solution BUT........
Computers are pretty cheap for the most part.  Why not either buy a new one, or re-purpose one you have lying around dedicated for Studio?  Use a KVM to switch between the two.  I do this for an older system I still use.  It's really rather painless.
Just an option.
JIm
+1
Or some kind of remote desktop ...
  I looked at your website and I assume that your products do not use the AVR as the main embedded-systems CPU processor.   Perhaps you are using Atmel's 32-bit processors.
If you wish to continue AVR development and can't get Atmel Studio 7 to work with Windows 10, then I suggest using Arduino UNO for small applications and Arduino Mega2560 for larger applications.
Arduino is based on AVR GCC++,  which is open source.  Open-Source means that you can usually find someone/somewhere who understands what is going wrong with your development system.
I do not have any reason to believe that any program that has been written for Atmel Studio 7 can not be adapted for Arduino as long as the target CPU is either the AVR Mega328P or the Mega2560.
Arduino gives you several levels on which to write your code.   For example, to simply change an GPIO pin's (say PortD4) logic value you can use (from easy to harder and faster):
         pinMode(4, OUTPUT); digitalWrite(4, HIGH);   // slow and easy student/hobbyist Arduino code
         DDRD |= (1<<4);  PORTD |= (1<<4);  // write directly to AVR's peripheral config registers in SRAM
         _triggerMode = (uint8_t *) portModeRegister(digitalPinToPort(4));   // use pointer into AVR's peripheral configs
         _triggerBit = digitalPinToBitMask(4);
         _triggerOutput = portOutputRegister(digitalPinToPort(4));
Are you using a machine translator from German to English? Your text is very difficult to understand.
thank you ,
i use for my AVR8Bit internal assembler code to manage USB with 20Mhz like Atiny85, the Arduino thinks are funny, this i use too for easy projects like axisencoder.
I think i must have the AtmelStudio Stuff to compile my source for the Atiny85 in asm and c . Need them Libs / Headers. And i have an AtmelDebuger/Programmer
the problem is that atmelstudio wont start wehen VS2015 is installed.  The only solution is a virtual mashine, all other IDE's are not good enough for me.
My english is free translated by me :) Named Denglish
thanks all for answer and help.
 Best regards
   Karsten
If ARM, then that widens the available 3rd-party tools significantly ...
Interesting.
I run VS, an AS 4.x, 6.0, and 6.2 on my Win10 system without any problems.
I use Atmel programmers, (mk II), and a Dragon.
I don't have the fancy debuggers.
I have Try it again, and while installing i got the same MessageBox thy will be pop up by klick Studio on DesktopIcon after Install is ready.
You gotta LOVE errors like that! How hard would it have been for the author to actually say what component it was looking for at the time?
i dont now  .. still with that.. have all try..
Indeed!
angry
One for the Pet Peeves list: http://www.avrfreaks.net/comment...
Solution is found , have install AStudio6_2sp2_1563net.exe  an all works fine.
Hmmm ... that's not really a solution - just a workaround to get you going for now ...
There was a number of known issues with 6.2 ...
Yes i have save the install binary.exe , and only so u can ensure  that your projects works in the future too. It's impossible too thrust newer coming versions, an repeatable devloopment  is need for own customers.
It sounds to me you're a professional business (rather than a hobbyist or student). If so then you might escalate this by talking to an Atmel/Microchip sales representative or "field engineer".
Absolutely!
side question, do you do a full installation? or only the smaller limited one? might be that you indeed are missing somethings that are present in the full installation, but in the smaller studio only package are presumed to be installed already.
On my linux box 10 year old or older software just keeps on working.
Your old fladbed scanner does not work anymore with your fancy new os?
Gimme that. It will work here :)
On the other hand. Atmel (microsoft) studio won't work on my linux box (Shame on them ! ).
I tend to still use good old make files.
Avr projects are simple enough to handle via make.
make lets me use the IDE I just happen to fancy at that moment.
I can switch easily. Used Code::Blocks for some time. Lately I'm using Qt.
In the future I might swap make for SCONS.
Atmel not releasing their debug protocols was one of the reasons for me to not use Xmega's.
Switched to ARM Cortex 3 instead.
Guess what: Debugging works (very breef test) with a USD 2 dongle from China.
Paul van der Hoeven.
http://www.hoevendesign.com
