Atmel ICE Debugwire
8 posts / 0 new
Another new guy needing debugging abilities for his arduino....
I am trying to use debugwire to debug on an Arduino mega with an Atmel ICE and Atmel studio 7.  All of the tutorials and information I could find said that to debug over the ICSP port I just need to program the device with the programmer in ISP mode then switch it to DebugWire mode.  When I go to do that, I do not get the option for anything apart from ISP or JTAG modes.  Is there somewhere else I need to change settings for the ICE?  I did find the advanced/standard mode button and put the IDE in advanced mode; but, it shows the same options.
The mega uses JTAG, not DEbugwire so thats why you do not see it as an option
JIm
The Arduino Mega2560 has got JTAGEN fuse disabled.
If you enable the JTAG, you lose those particular Analog pins.
Otherwise, you should find debugging straightforward,
The Uno uses debugWIRE. You must break the RESET-EN solder-bridge before first use. (cut the thin copper link on the virgin solder bridge)
You are probably looking at the programming dialogue (hard to tell since you've cropped your screenshot).
If you want to do debugging you simply have the ICE connected and select "Start debugging and break". Atmel Studio will take care of programming the DWEN, which btw will also disable ISP programming. You can start and stop debugging repeatedly. Once you're done and want the ISP enabled again, then  choose "Disable debugWire and close".
I would advice to read not only tutorials  or instructables etc on the web (they might be wrong, confusing or simply outdated), but to actually read the official documentation/help on the subject. Look no further than Atmels Studios Help menu. If you want to read it on the web, go here: www.atmel.com/webdoc. Go to Software, Atmel Studio, and then the Debugging section.
EDIT: Everything I said applied to AVR with debugWire. I read the OP sloppily and didn't notice that this was about an AVR with JTAG rather than debugWire. (The advice on reading the help still applies. Just focus on generic documentation and JTAG specifics rather than debugWire). Sorry for any confusion.
Johan, he says in the OP:
I don't believe teh Mega supports debugwire...only JTAG
JIm
Thanks! So I need to follow HanSolo's tutorial on this page? http://www.avrfreaks.net/forum/a...
[EDIT]This is in reply to jims post above[/EDIT]
Yup. See my EDIT in the previous post. I saw "Arduino" and my brain short-circuited on mega328 (which, as you know, has debugWire) rather than the 2560 (which, as I know, has JTAG).
Thank you!
