ADC attiny817
9 posts / 0 new
#include <stdio.h>
#include <avr/pgmspace.h>
#include <util/delay.h>
#include <avr/interrupt.h>
#include <stdlib.h>
uint16_t results;
	CPU_CCP= CCP_IOREG_gc; //Un-protect protected I/O registers
	CLKCTRL_MCLKCTRLB =!(CLKCTRL_PEN_bm);	//OFF Prescaler
	sei();
	//*********************************ADC*******************************************************
	PORTA.DIRCLR = PIN7_bm;
	ADC0.CTRLA |= ADC_RESSEL_bm; //8 bit
	ADC0.CTRLA |= ADC_FREERUN_bm; // FREE RUN
	VREF.CTRLA |= VREF_ADC0REFSEL_1V1_gc;   // dont work :(
	//VREF.CTRLB |= VREF_ADC0REFEN_bm;
	//ADC0.CTRLC |= ADC_SAMPCAP_bm;
	ADC0.CTRLC = ADC_PRESC_DIV32_gc;  //32 PRESCALER
	ADC0.MUXPOS = ADC_MUXPOS_AIN7_gc; //MUX
	ADC0.CTRLA |= ADC_ENABLE_bm;  // ADC ON
	ADC0.COMMAND |= ADC_STCONV_bm; // START
	//***************************D A C **************************************************************
    while (1)
		results = ADC0.RES;
		_delay_ms(1500);
Attiny817
Anyone know how to turn internal reference source, above 0.55V? I can't change it :(
What register is used to set VREF?
See 30.5.3 in the datasheet
I try with  ADC0.CTRLC = ADC_REFSEL_INTREF_gc; but the bits are automatically set to zero so there is an internal reference source.
Automatic reference source is internal 0.55V,  change   ""VREF.CTRLA |= VREF_ADC0REFSEL_1V1_gc;"" register does not change anything.
I use 18.1 in the datasheet.
Those bits are not in CTRLA, the page I posted is for CTRLC!
My mistake, those bits select VDD or internal reference....
It may be you have enable freerun mode, and the ADC will not accept a change in vref while running, so either do not enable freerun and use single start conversion mode,
or setup vref before enabling freerun.
I tried many options and nothing works :( I use xplained mini.
I found a solution - the voltage for the ADC came from the DAC
(earlier from the divisor and had similar problems)
In the DAC I have typed VREF.CTRLA =  VREF_DAC0REFSEL_1V1_gc;
should be                      VREF.CTRLA |= VREF_DAC0REFSEL_1V1_gc;
difference " |= "
This error resets the registry CTRLA.
I'm not understand the difference between "|="  and  "="
Aw, that would do it!
The "|=" is a read/modify/write which "or"'s in the 1 bits and writes the results back.
while the "=" just assigns the value of all bits to the register, possibly changing all bit values.
Glad you found it.
