Simplest way to extract flash from ATMega164P
18 posts / 0 new
Hello, we have developed firmware for a medical device on an ATMega164P.  It performs internal logging to flash.  We program the 164 using an AVRONE and IAR embedded workbench, and we extract the flash using the same setup, and then look at the logging information.
Our device is going to undergo testing by medical technicians, who, ideally, will be able to extract the flash periodically and upload it to a web server, where our client will examine the logs.  The problem is that the whole process of connecting an AVRONE and launching IAR and using it the right way may be too much for a medical technician.
So my question is, what is the simplest-as-possible way to extract the flash from the ATMega164P.  Someone suggested AVRDude, but it looks like that is just software (command line, at that) and it still requires the AVRONE programmer.   Is there any simpler setup that we could specify to the client?  (They have not yet tasked us with engineering a simpler way... so for now I'm asking if there is a COTS solution.)
Thanks for the help!
Get a USBAsp and a copy of avrdude then wrap that in a one click batch file that does the entire thing.
Oh, good point the command line ability of AVRDude allows us to batch it.
The AVROne is bigger and less wieldy, but is the USBAsp somehow simpler to use than the AVROne?
Only suggested USBAsp as they are expendable ($3 versus $600 for AVROne!) so you can buy 10 and don't worry if someone loses or screws up the first 5 - it's still only cost $15 so far ;-)
I've never looked but I assume avrdude knows how to drive an AVR One! ? It certainly knows about usbasp's.
Very helpful, thanks very much!
Actually, I'd lean more toward a little reporting mechanism, via UART or whatever.
Logging to program flash on a medical device?  Kind of scary...
+1
Who are, "They" ?
Seems like a very fundamental, glaring oversight for a recording device !!
surprise
Otherwise, you just end up with one of these: http://repeater-builder.com/molo...
A few more to add to the interesting datasheet collection:
https://www.mikrocontroller.net/attachment/37410/datasheet.pdf
http://www.sigwom.com/?page_id=17
Extremely.
At least a dozen safer ways to do this.
For starters, flash should be locked down completely.
Second, log to a device that you can readily interface to other equipment.  SD card comes to mind.
"Read a lot.  Write a lot."
Just saw the continuing conversation.  It's actually not a recording device, it does something else and it records data about the main function to understand usage (and make improvements) during clinical trials.  The recording function will be removed afterwards.
Indeed.  My comments still stand.  Find someplace else to log.
"Find someplace else to log"
I guess I don't understand why, if it will be removed before it would become a safety issue.
1)  "Clinical trials" don't involve people or equipment or similar?
2)  When you then disable or remove the mechanism, then don't you have to re-certify?
3)  If you log "somewhere else", then you can gather information over time, and from field unit history, and similar helpful situations
But suit yourself.
+1
Aren't there are rather strict regulations on certifying medical equipment in most countries? "We certified 0.9 but will be shipping 1.0" does not sound like it would pass...
Yep, it will be re-certified (fully re-tested) in its final implementation.
If 2K is enough logging space, could you swap in a mega644 and log to EEPROM, instead of risking program memory corruption ?
Mike Adams
ADI Development, Inc.
http://www.adidev.com
... When it has to actually work.
I would never develop such a device.
I would never invest in such a device.
I would never let anyone I love wear such a device.
I would read with detached interest a news story covering litigation surrounding the use of such a device ;-)
Surely.  Surely.  Surely there is a better way which will still meet your requirements.
