External Interrupt (EIC) on multiple pins
3 posts / 0 new
The SAMD chips only seem to have 16 EIC channels, and up to 7 pins (on sam51p) can share the same channel.
Is it the case that if I enabled multiple pins on the same channel, that a pin change on ANY of the pins will cause an interrupt?
Does anyone have a particularly clever technique for figuring out which pin has actually changed, assuming that you've enabled the EIC on ALL the pins?
From 23.6.6 in the datasheet:
2. If an external interrupts (EXTINT) is common on two or more I/O pins, only one will be active (the
first one programmed)
Ah; thanks!    Bummer.
That makes a 128pin SAMD51 a bit lacking in the interrupt department!
