How to get Auth and AuthCompute to work? ATAES132A
8 posts / 0 new
Hi All,
I ran authCompute cmd but kept getting 0x50 error.   My data sent :
uint8_t Blk1[] = {
       0x03,0x01,0x00,0x00,0x00,0x07,0x00,0x00,0x00,0x00,0x00
    uint8_t Blk2[] = {
         0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
ret = aes132m_execute(AES132_AUTH_COMPUTE,0b00000000,0,0x0000,11,(uint8_t*)Blk1,16,(uint8_t*)Blk2,0,NULL,0,NULL,(uint8_t*)TxBuff,(uint8_t*)RxBuff);
MacFlag was wrt pg 112
Blk 1 and blk 2 was wrt pg 116
I tried all the modes in blk 1 but still got error 0x50 returned
As for Auth, I ran and obtained the outbound Mac, fed it back as an InMac but got Mac error 0x40
I set the nonce inseed with all 0xA5. As its still in testmode, I got all 0xA5 for output random no from Nonce cmd.
I checked to ensure the commands ran right after nonce cmd and even used info cmd to check macCount to verify its 1.
Please advise
You cannot use an outbound MAC as an inbound MAC, and vice-versa. Both the mac_count and the mac_flag will be different for each even if the nonce is the same.
Each MAC calculation is unique - as it's supposed to be.
The AuthCompute command (which I didn't use as I calculated/verified any MACs myself, will calculate MACs for you to send to a 2nd synchronised device.
According to the datasheet, error code 0x50 is "Bad opcode, bad mode, bad param, invalid length, or other encoding failure".
So it looks like your command format is wrong so the authentication is not even attempted.
Hi anha6317,
Thanks for your reply.
I cannot figure out what is wrong with the input I've sent to AuthCompute.
Page 34:
Opcode 0x14
Mode 0x00
MacKeyID  0x0000
Zero 0x0000
FirstBlock  0x03 01 0000 0007 00 00000000
SecondBlock 0x00000000000000000000000000000000
Could you clue me in?
You can debug into the aes132m_execute call to see what the command packet the library is building.
Then you can also look at the I2C or SPI  bus and see what is actualoly being sent to the chip.
What you do know is the chip isn't happy with the command it receives.
Hi anha6317,
Yes, I've done that and verified with the debugger that it is indeed sending out the commands are above.
Could it be one of those errata in datasheet issue you've previously spotted? Seems the previous guy asking you about AuthCompute also has problems with this
A couple more thoughts...
Is the AuthCompute command enabled in the ChipConfig register? The ChipConfig.AuthComputeE bit must be set to 1.
Does the KeyConfig register for the key specify a random nonce?
Thanks anha6317, nice catch. AuthComputeE bit did the trick :) Thank you :)
Nice one :)
