ATSAMD21 SERCOM I2C inverting SDA SCL
9 posts / 0 new
I made a custom board using ATSAMD21E18, and made a little mistake for my I2C line:
SDA is on SERCOM1 PAD1 (PA17) and SCL on SERCOM1 PAD0 (PA16)
Is i possible to have SCL on pad0 and SDA on pad1, or they are only working in pad0 for SDA and pad1 for SCL ?
Thanks in advance
Check "Signal Description" under SERCOM I2C in the datasheet. Looks like the pad to signal mapping is fixed for SERCOM I2C (unlike USART and SPI).
/Lars
Thanks alot for your quick answer, that is what I feared
I will change my board layout then
 I'm not sure I understand how the PAD mapping is supposed to be helpful.   Uart TX is always on Pad0,  SPI SCK is always Pad1,  I2C isn't changeable at all...  Grr.
Fixed for I2C yes but USART has TXPO, RXPO and SPI has DIPO, DOPO.
/Lars
But not all combinations are available.
Inevitable, Murphy dictates that the one you really want is the one that's not available!
angry
Like I said: not really.   USART RX can be any pin, but TX *must* be on Pad0 (you get to enable RTS or RTS and CTS, or XCK.  But there are no choices as to where they go.)
Not really, at least from the datasheet I get that USART TX can be on Pad[0] or Pad[2].
/Lars
(ah.  I was looking at SAMD51, and assuming that its Sercom was the same as the other SAMD Sercom chips.   Apparently not!  :-(   The SAMD51 seems to allow uart tx only on pad0, while the samd21 allows pad0 or pad2...)
