Help to find Synaptics TM-01571-001 touchpad pinout
2 posts / 0 new
I want to make a USB touchpad using an old one from Sony Vaio laptop.
The model number is TM-01571-001 and Synaptics number is TM1571 920-001769-01RevA
The problem is I cannot find the pinout of the touchpad anywhere. Is there anyone who is familiar with this model or can provide a datasheet?
Here's my two cents:
These are the only signal connected to FPC connector, comparing with older models gives the following assumptions:
T23 is obviously GND
T22 is +5V (on other synaptics devices)
T5 and T6 are probably the buttons
So that leaves T12 and T13. They are most probably the USB signals. I'd just try connecting them to USB+ and USB- with 330 Ohm resistors in between. If it doesn't work, switch the two.
T10 and T11 were PS/2 CLK and DATA on older devices, they are not present on yours.
-Patrick
"Some people die at 25 and aren't buried until 75." -Benjamin Franklin
What is life's greatest illusion?"  "Innocence, my brother." -Skyrim
