PS2 controller in AVR2560 ; I unable to configure ps2 in analog mode and i am not getting output ;
4 posts / 0 new
BIT BANG PS2  for atmega640 -connection according to SPI
-------------LOOKING AT THE PLUG-------------------
 PIN 1->| o  o  o | o  o  o | o  o  o |
        \_____________________________/
PIN # USAGE
 1    DATA
 2    COMMAND
 3    N/C (9 Volts unused)
 4    GND
 5    VCC
 6    ATT
 7    CLOCK
 8    N/C
 9    ACK
----NOTES--
*> 0x5A(by controller) to say "here comes the data".
*> bite 1. header. (should possibly put test on this byte to detect unplugging of controller.)
 ie if (temp==0x73)
#ifndef F_CPU
#define F_CPU 14745600UL // or whatever may be your frequency
#endif
#include<avr/io.h>
#include<avr/interrupt.h>
#include<util/delay.h>
#define PSdata             3               // PB3
#define PScommand          2               // PB5
#define PSclock            1               // PB2
#define PSattention        0               // PB6
#define sbi(x,y)  x|=(1<<y)
#define cbi(x,y)  x&=~(1<<y)
//#define _BV(y)  (1<<y)
// PSx controller communication function.
// send a byte on the command line and receive one on the data line.
// needs Attention pin to have gone low before called to activate controller.
int gameByte(short int command)
        short int i ;
        _delay_us(1);
        short int data = 0x00;                             // clear data variable to save setting low bits later.
for(i=0;i<8;i++)
if(command & _BV(i))
sbi(PORTB, PScommand);       // bit bang "command" out on PScommand wire.
cbi(PORTB, PScommand);
cbi(PORTB, PSclock);                             // CLOCK LOW
_delay_us(1);                                    // wait for output to stabilise
if((PINB & _BV(PSdata)))
sbi(data, i);                               // read PSdata pin and store
     cbi(data, i);
sbi(PORTB, PSclock);                             // CLOCK HIGH
        _delay_us(20);                                                   // wait for ACK to pass.
        return(data);
void  int_PS2inanalougemode()
      // this loop continues to put PSx controller into analouge mode untill the
   // controller responds with 0x73 in the 2nd byte.
   // (PS2 controller responds with 0x73 when in analouge mode.)
   // the status LEDs will continue to count upwards untill a controller is found.
   // if everything is working correctly this should happen on the first pass of
   // this loop but occasionally errors occur and a 2nd or 3rd itteration happen.
   unsigned char chk_ana = 0, cnt = 0;
   while(chk_ana != 0x73)
   // put controller in config mode
   cbi(PORTB, PSattention);
   gameByte(0x01);
   gameByte(0x43);
   gameByte(0x00);
   gameByte(0x01);
   gameByte(0x00);
   _delay_ms(1);
   sbi(PORTB, PSattention);
   _delay_ms(10);
   // put controller in analouge mode
   gameByte(0x01);
   gameByte(0x44);
   gameByte(0x00);
   gameByte(0x01);
   gameByte(0x03);
   gameByte(0x00);
   gameByte(0x00);
   gameByte(0x00);
   gameByte(0x00);
   _delay_ms(1);
   _delay_ms(10);
   // exit config mode
   gameByte(0x01);
   gameByte(0x43);
   gameByte(0x00);
   gameByte(0x00);
   gameByte(0x5A);
   gameByte(0x5A);
   gameByte(0x5A);
   gameByte(0x5A);
   gameByte(0x5A);
   _delay_ms(1);
   _delay_ms(10);
   // poll controller and check in analouge mode.
   gameByte(0x01);
   chk_ana = gameByte(0x42);            // the 2nd byte to be returned from the controller should = 0x73 for "red" analouge controller.
   gameByte(0x00);
   gameByte(0x00);
   gameByte(0x00);
   gameByte(0x00);
   gameByte(0x00);
   gameByte(0x00);
   gameByte(0x00);
   _delay_ms(1);
   _delay_ms(10);
  // keep increasing counter to be dispalyed untill PSx controller confirms it's in analouge mode.
   PORTC=cnt++;
   if (cnt > 254){ cnt=0;}
     DDRC=0XFF;
     // PSx controller I/O pin setup:
   sbi(DDRB, PB1);                 // clock. output. (blue)
   cbi(DDRB, PB3);                 // data. input. (brown)
   sbi(PORTB, PB3);               //    enable pullup resistor
   cbi(DDRB, PB4);                 // acknolage. input. (green)
   sbi(PORTB, PB4);               //    enable pullup resistor
   sbi(DDRB, PB2);                 // command. output. (orange)
   sbi(DDRB, PB0);                 // attention. output. (yellow)
   int_PS2inanalougemode();
   short int temp, data0, data1, data2, data3, data4, data5, i ,debounceSelect;
sbi(PORTB, PScommand);                          // start communication with PSx controller
gameByte(0x01);                                       // bite 0. header.
temp = gameByte(0x42);                          // bite 1. header. (should possibly put test on this byte to detect unplugging of controller.)
gameByte(0x00);                                       // bite 2. header.
data0 = gameByte(0x00);                         // bite 3. first data bite.
data1 = gameByte(0x00);                         // bite 4.
data2 = gameByte(0x00);                         // bite 5.
data3 = gameByte(0x00);                         // bite 6.
data4 = gameByte(0x00);                         // bite 7.
data5 = gameByte(0x00);                         // bite 8.
_delay_us(1);
sbi(PORTB, PScommand);                      // close communication with PSx controller
_delay_us(1);
sbi(PORTB, PSattention);                        // all done.
   PORTC=data5;
sagar
How to properly post source code: http://www.avrfreaks.net/comment...
Also tell us what you are trying to do, what you were expecting to happen, what did happen, how is that different from what you were expecting...
Just posting code and asking what is wrong is impossible to answer without knowing what you want.
Lower your cpu clock. The controller use 8MHz.
MG
