Reading the external crystal.
59 posts / 0 new
Pages
awneil wrote:
Isn't the transceiver crystal mandatory for radio operation anyhow?
To answer my own question:
Yes, the transceiver crystal is mandatory for radio operation - BUT selecting a different source for the CPU means that the CPU can continue to run while the radio is asleep
pika wrote:
From the datasheet this is the one thing I have found out.
So look also at Table 11-10 for the start-up time settings ...
pika: What you have to do is hook up a 16MHz crystal (Xtal, 2 pins) with capacitors (2x, 10-20picofarad) to the XTAL pins (doesn't actually matter which, but see the schematic in post #20) and then set the rest of the AVR to run off the transceiver crystal.  Set the CLKSEL fuses to Transceiver Oscillator, longest possible startup time.
Try that.  If it doesn't work, get back to us, and we'll blizzard you once more with irrelevant trivia.  cheeky
S.
PS - The original 8pF caps you had are probably too small.  S.
PPS - No, you can't do RF with the AVRs internal RC. - Edit:  Ref. post above, as I did without proper credit. S.
Okay. Now I have a clear picture. Thanks all of you. Its clear on my mind :) Thanks all for your time
Scroungre wrote:
PPS - No, you can't do RF with the AVRs internal RC. S.
See #52.
Hello all,
I seslcted the option : Transceiver Oscillator;Start-up time : 16K CK +65ms. The program is flashed without any errors (using Start without degugging option). Then I tried the Start debugging option,but that leads to an error like the picture below. When I tried the internal RC it works fine. What does this mean ?
Hello all,
This problem is solved. The launch failed happened because the external crystal was not working. Thank you all for your support.
Thanks for the feedback.
Now, please mark the solution: http://www.avrfreaks.net/comment...
Pages
