GCC optimization fail
13 posts / 0 new
This simple program shows a poor optimization by GCC:
int main () {
	OCR1A = (PIND << 8) | PIND;
gcc 4.8.1 and 5.4.0 give:
int main () {
  80:	29 b1       	in	r18, 0x09	; 9
  82:	89 b1       	in	r24, 0x09	; 9
  84:	90 e0       	ldi	r25, 0x00	; 0
  86:	92 2b       	or	r25, r18
  88:	90 93 89 00 	sts	0x0089, r25
  8c:	80 93 88 00 	sts	0x0088, r24
  90:	80 e0       	ldi	r24, 0x00	; 0
  92:	90 e0       	ldi	r25, 0x00	; 0
  94:	08 95       	ret
I also tested gcc 7.2.0, which I use because of C++17 support. It's even worse:
00000080 <main>:
  80:   89 b1           in      r24, 0x09       ; 9
  82:   99 b1           in      r25, 0x09       ; 9
  84:   89 27           eor     r24, r25
  86:   98 27           eor     r25, r24
  88:   89 27           eor     r24, r25
  8a:   90 93 89 00     sts     0x0089, r25     ; 0x800089 <__TEXT_REGION_LENGTH__+0x7e0089>
  8e:   80 93 88 00     sts     0x0088, r24     ; 0x800088 <__TEXT_REGION_LENGTH__+0x7e0088>
  94:   80 e0           ldi     r24, 0x00       ; 0
  96:   08 95           ret
Yes, very clever the use of 3 eors to exchange r24 and r25. Very clever but very useless since you could just revert the 2 in instructions and achieve the same result... or reverse r24 and r25 in the store instructions.
I'm using -Os flag, but the other optimization levels don't seem to do any difference.
Is there one of those obscure gcc options I usually miss that might fix this?
No.
You could optimize the C! smiley
int main () {
//    OCR1A = (PIND << 8) | PIND;
    uint8_t test = PIND;
    OCR1AH = test;
    OCR1AL = test;
    while(1) {};
which yields:
int main () {
  aa:	89 b1       	in	r24, 0x09	; 9
    OCR1AH = test;
  ac:	80 93 89 00 	sts	0x0089, r24	; 0x800089 <__TEXT_REGION_LENGTH__+0x7e0089>
    OCR1AL = test;
  b0:	80 93 88 00 	sts	0x0088, r24	; 0x800088 <__TEXT_REGION_LENGTH__+0x7e0088>
  b4:	ff cf       	rjmp	.-2      	; 0xb4 <main+0xa>
David (aka frog_jr)
Is it?  >>You<< essentially forced the sequence of operations, as the code >>you<< chose to write does two reads of a volatile location.
As pointed out in #3, if you write to code without forcing said operation the compiler seems to do just fine.
If indeed you do the double-read of PIND, aren't you racing a change?  Or is that the whole point of the sequence?
It also works without volatile:
unsigned char c, d;
unsigned cd;
void f (void)
    cd = (d << 8) | c;
The responsible pattern is:
(define_insn_and_split "*iorhi3.ashift8-ext.zerox"
  [(set (match_operand:HI 0 "register_operand"                        "=r")
        (ior:HI (ashift:HI (any_extend:HI
                            (match_operand:QI 1 "register_operand"     "r"))
                           (const_int 8))
                (zero_extend:HI (match_operand:QI 2 "register_operand" "r"))))]
  "optimize"
  { gcc_unreachable(); }
  "&& reload_completed"
  [(set (match_dup 1) (xor:QI (match_dup 1) (match_dup 2)))
   (set (match_dup 2) (xor:QI (match_dup 2) (match_dup 1)))
   (set (match_dup 1) (xor:QI (match_dup 1) (match_dup 2)))]
    rtx hi = simplify_gen_subreg (QImode, operands[0], HImode, 1);
    rtx lo = simplify_gen_subreg (QImode, operands[0], HImode, 0);
    if (!reg_overlap_mentioned_p (hi, operands[2]))
        emit_move_insn (hi, operands[1]);
        emit_move_insn (lo, operands[2]);
        DONE;
    else if (!reg_overlap_mentioned_p (lo, operands[1]))
        DONE;
    gcc_assert (REGNO (operands[1]) == REGNO (operands[0]));
    gcc_assert (REGNO (operands[2]) == 1 + REGNO (operands[0]));
It expresses the combination of 5 16-bit operations:  2 extensions to 16 bits, one 16-bit shift, a 16-bit IOR and a 16-bit assignment.  We are hitting the corner case of 2 overlaps (which will execute the 2 assertions at the end) that triggers the 3 XORs.
So see the effect of removing the pattern (actually anything synthesized be combine) use -fdisable-rtl-combine
You can try to change the constraint of operand 2 from "r" to "0" and elaborate what happens for possible operand combinations / overlaps.
I was recently a bit disappointed by:
void loop() {
  for (byte d = 0; d < 8; d++) {
    uint32_t s = cathall;  // all cathodes 1 (off)
    :  // more manipulations of s
    PORTB = s & 255;
 250:   85 b9           out     0x05, r24       ;;;  Good.
    PORTC = (s >> 8) & 255;
 252:   49 2f           mov     r20, r25        ;;; Would rather have out 0x8, r25
 254:   5a 2f           mov     r21, r26
 256:   6b 2f           mov     r22, r27
 258:   77 27           eor     r23, r23
 25a:   48 b9           out     0x08, r20       ; 8
    PORTD = (s >> 16);
 25c:   cd 01           movw    r24, r26      ;;;  And out 0xb, r26
 25e:   aa 27           eor     r26, r26
 260:   bb 27           eor     r27, r27
 262:   8b b9           out     0x0b, r24       ; 11
Weren't there at one time some optimizations in the avr-gcc code generator to specially deal with byte-sized results?
I have tried the option -fdisable-rtl-combine, for the older versions of GCC, the code indeed is de-optimized, but we can now see clearly how the compiler is "thinking":
00000080 <main>:
  82:	29 b1       	in	r18, 0x09	; 9
  84:	90 e0       	ldi	r25, 0x00	; 0 ;zero extend to 16 bit
  86:	98 2f       	mov	r25, r24   ;shift: move the data
  88:	88 27       	eor	r24, r24   ;shift: clear lower bits
  8a:	30 e0       	ldi	r19, 0x00	; 0 ;zero extend
  8c:	82 2b       	or	r24, r18  ; do the or operation
  8e:	93 2b       	or	r25, r19  ; do the or operation
  90:	90 93 89 00 	sts	0x0089, r25	; 0x800089 <__TEXT_REGION_LENGTH__+0x7e0089>
  94:	80 93 88 00 	sts	0x0088, r24	; 0x800088 <__TEXT_REGION_LENGTH__+0x7e0088>
  98:	80 e0       	ldi	r24, 0x00	; 0
  9a:	90 e0       	ldi	r25, 0x00	; 0
  9c:	08 95       	ret
For the newer gcc 7.2.0, -fdisable-rtl-combine seemed to have no effect.
-fdisable-rtl-combine has still the effect of disabling insn combine, but the above pattern was added just recently as http://gcc.gnu.org/r242907 hence in older versions there is no such pattern.
The first asm of which OP complains has two extra instructions: LDI and OR.
frog_jr's suggestion is semantically different and is an example of what one should not have to do.
The pattern (fred<<8) | greg
where fred and greg are 8-bit variables often seems to give avr-gcc trouble.
Sometimes (fred<<8) & 0xFF00 | greg works better.
Note that OP's code does require reading PIND twice.
International Theophysical Year seems to have been forgotten..
Anyone remember the song Jukebox Band?
Based on #5, I have a further test:
int main () {
	return (PIND << 8) | PIND;
This compiles to
00000080 <main>:
  88:	08 95       	ret
on gcc 4.8.1 and 5.4.0, but on the newer version 7.2.0 I get:
00000080 <main>:
  80:   99 b1           in      r25, 0x09       ; 9
  84:   08 95           ret
So at least this case has been fixed.
Added a "r,r,0" alternative to the mentioned pattern, you can try it from gcc trunk svn 253343 or newer.
Thank you, however I wouldn't dare to actually compile avr-gcc, it seems to be quite a challenge. I will wait until this is incorporated in a new release and someone compiles it, then I will test for sure.
I'm back, as promised. SprinterSB, thanks for compiling avr-gcc 8.0.1 for MinGW, it includes your fix for the issue I mentioned in the OP.
I tested, and indeed the code it generates is:
0000007a <main>:
  7a:	99 b1       	in	r25, 0x09	; 9
  7c:	89 b1       	in	r24, 0x09	; 9
  7e:	90 93 89 00 	sts	0x0089, r25	; 0x800089 <__TEXT_REGION_LENGTH__+0x7e0089>
  82:	80 93 88 00 	sts	0x0088, r24	; 0x800088 <__TEXT_REGION_LENGTH__+0x7e0088>
  86:	90 e0       	ldi	r25, 0x00	; 0
  88:	80 e0       	ldi	r24, 0x00	; 0
  8a:	08 95       	ret
Now the dumb register exchange is gone. Much better yes
