Split from: How to use FRAM..?
34 posts / 0 new
Dear all,
I am new to use FRAM,
Could you please tell me what is lower address and upper address ?
I am going to write and read 8 different value. So I need to store them in one matrix or in different and specific address. (am I right ?)
Well for a start you might want to say what part number. But if we assume the FM25L256 already mentioned in this thread then a Google for "FM25L256 datasheet" gets you to here:
http://datasheet.octopart.com/FM...
In one place that tells us:
Later it says this about SPI operation:
So you will send WREN as one 8bit command, then WRITE as the next 8 bit command. Then an address between 0x0000 and 0x7FFF to select the location within 32K where you want to start writing. Then the bytes of data to be written. You stop the write by raising _CS after you write the last byte.
So to answer your question, for a 32K byte device the 32K bytes have a lower address of 0x0000 and an upper address of 0x7FFF.
No doubt the datasheet for the device you actually plan to use tells you how many bytes it holds. The bottom will be 0x0000 and the top will be <device_size_bytes>-1
You do realise that you are waking a thread that has been dead for ten years ?!
In what context, exactly?
This doesn't sound like anything specifically to do with FRAM - in any memory, you will have "low" (ie, numerically "small") and "high" (ie, numerically "large")  addresses.
Or perhaps it's referring to the least/less significant and most/more significant parts of an address word - again, nothing specifically to do with FRAM.
You can store them in whatever arrangement makes most sense for the purposes of your application.
Of course, we know absolutely nothing about your application - so nobody can help you with what may or may not be appropriate.
This may also be unrelated to FRAM per se.
I think he's mistakenly thinking this is just going to appear in "AVR memory space" (presumably the RAM one?) and because there's already stuff there this FRAM will appear at some offset so will have lower/upper address bounds.
I think he may have failed to grasp the difference between serial and parallel addressed memory devices. Clearly for serially (SPI) addressed memory then all the addresses AND data all go down the same, single wire, one after another.
You may well be right.
But it certainly doesn't seem to have anything to do with the original topic - so should be split?
EDIT
Has now been split.
Original thread was: http://www.avrfreaks.net/forum/how-use-fram
One virtual beer on Hossein not returning and answering...
Dear clawson,
Thanks for your reply.
you make it clear now for me.
I'm gonna use MB85RS16N.
the datasheet is available in
http://edevice.fujitsu.com/fj/DA...
Again Thanks and sorry for my delay to reply.
Dear awneil
yes you are right I forgot to tell about my application.
My project is to read 7 different sensors (Hall sensors) and count the number of sense and store them in F-RAM.
and in some specific case micro controller need to read the numbers and continue ...
I hope I could make it clear for you.
yes right :)
laugh laugh laugh
Im here , SOrry for delay
Cheers
So does have an SPI connection to the microcontroller:
Fujitsu, in the MB85RS16N datasheet, wrote:
DESCRIPTION
MB85RS16N is a FRAM (Ferroelectric Random Access Memory) chip in a configuration of 2,048 words × 8 bits, using the ferroelectric process and silicon gate CMOS process technologies for forming the nonvolatile memory cells. MB85RS16N adopts the Serial Peripheral Interface (SPI).
https://edevice.fujitsu.com/fj/DATASHEET/e-ds/MB85RS16N-DS501-00030-3v0-E.pdf
So is your question now answered?
If so, please mark the appropriate post using the  'Mark Solution' button.
You could also edit the thread title so that it actually reflects the question that you were asking.
EDIT
See: http://www.avrfreaks.net/comment...
Kinda,,,,
to save my data as there is 8 different values /Variables do I need to set specific lower and upper address to write and read each variable ??
Here are 8 randomly selected variables:
int number;
long long_num;
char c;
short half_int;
uint16_t data[14];
struct {
    int n;
    long l;
} combined;
union {
    uint32 num;
    uint16_t word[2];
    uint8_t bytes[4];
} joined;
int32_t signed_var;
What do your 8 look like?
Anyway, given that there's no limit (speed or number) on writes to FRAM personally I'd be tempted to put all my 8 variables together in a struct then do a complete struct_write() when you want to save changes made to the RAM based copy.
Again, this has nothing specifically to do with FRAM.
Of course, you need to know where something is stored in memory in order to be able to access it!
Because, as Cliff pointed out, an SPI-connected memory does not appear in the microcontroller's address space, this is not something that can be managed by the compiler (as for "normal" program variables) - so you are going to have to define how stuff gets stored in your SPI memory.
A common way is to put all your data into a structure, and copy the entire structure to/from the SPI device.
EDIT
Cliff beat me to it.
int number;
long long_num;
char c;
short half_int;
uint16_t data[14];
struct {
    int n;
    long l;
} combined;
union {
    uint32 num;
    uint16_t word[2];
    uint8_t bytes[4];
} joined;
int32_t signed_var;
Thanks for your reply and I appreciate it .
My variables are float numbers.
Using structure is a good Idea.
EDIT
I got it.
Thanks to make it clear for me.
When quoting, don't quote the entire post - it clogs up the thread!
Just pick out enough to give context to your reply.
See, for example, #13 and #14
EDIT
Or, for a general reply, just use the 'Reply' button on the post in question - then the forum will identify which post you're replying to:
#Quoting
Sure, my bad
I appreciate it if you guide me how to write and read the structure to/from the memory
How can we guide you when you’ve told us very little?
There’s examples using arduino. This should get you started.
thanks for your reply
I am using ATmega 644, and Code Vision (C language)
I already got that I need to make structure for my data, so I need to know how I can write and read created struct to/from external FRAM
please let me know if you need more details.
How many times does this have to be repeated?
The fact that it's FRAM is irrelevant - the approach would be exactly the same for any other type of SPI-connected memory. And, in fact, any other SPI-connected peripheral at all.
There are plenty of examples of using serial memories - especially EEPROM.
You will have to check the chip datasheet for the specific command/response format.
3 to 4 timesdevil
eg, https://github.com/hackscribble/hackscribble-ferro-library/blob/master/Hackscribble_Ferro.cpp
found by simply putting "MB85RS16N c code" into google.
other search engines are available.
So, if you've never used SPI at all before, you might want to start with some basic SPI exercises.
Microchip has a nice little board with 7 common SPI peripherals on it:
http://www.microchip.com/DevelopmentTools/ProductDetails.aspx?PartNO=pkserial-spi1
There's
  • SPI temperature sensor
  • SPI Analogue-to-Digital converter (ADC)
  • SPI digital potentiometer
  • SPI Programmable-Gain Amplifier (PGA)
  • SPI IO expander
and, of course, an SPI serial EEPROM (ie, memory).
Have you got functions to read/write bytes/blocks of data to the fram? You’ll need these first.
Thanks for your suggestion
I will consider it  smileyyes
thanks for your reply;
well I write the following code (but I need to improve it and I am not sure its correct or not):
void WriteFRAM(char AddrL, char AddrU, float data )
        PORTB.0 = 0;
        F_Transmit(WREN); // opcode
        PORTB.0 =1;
        delay_us(10);
        PORTB.0 =1;
        F_Transmit(WRITE); // opcode
        F_Transmit(AddrU); // upper adress bits
        F_Transmit(AddrL); // lower adress bits
        F_Transmit(data); // Data byte
        PORTB.0 =1;
void SaveDataST(float P0,float P1, float P2,float P3,float P4,float P5,float P6,float P7 )
   int sizeST;
   int Address;
   char *p;
   typedef unsigned char BT;
    struct Position
    float M0;
    float M1;
    float M2;
    float M3;
    float M4;
    float M5;
    float M6;
    float M7;
   }Position_M;
p = (BT*)&Position_M;
      for ( Address = 0; Address < sizeof(Position_M); Address++ )
        WriteFRAM(0x10, Address, *p);
        p++;
You can only write one byte at a time to SPI memory. A "float" in CodeVision occupies 4 bytes so it will take 4 writes to store the float.
But really a struct (or more obviously an array?) holding eight float variables is really just a block of 32 bytes (8 * 4) so create a routine to write any block of N bytes to the memory then call it to write 32 bytes giving it the start address of the struct or array.
Hopefully this is sinking in by now:
For any SPI peripheral, you will need to start with functions to send/receive bytes of data. Then you take those functions, and use them to send/receive blocks of data, etc ...
The thing to note with SPI is that it is always full-duplex - meaning that it is always receiving at the same time it is sending.
It is the sending (from the master) which causes the clock to be generated - so you cannot receive anything without sending something.
So, with SPI, you will not have separate send byte & receive byte functions - but an "exchange" function which sends & retrieves the byte received while sending.
You can see this on page 9 of the datasheet.
Again, if you've never done SPI before, it may be easier to get your head around this by starting with a simpler slave device ...
How to properly post source code: http://www.avrfreaks.net/comment...
The MB85RS16N does support "automatic address increment" for writing multiple bytes in a single "transaction"
See datasheet, page 9
hossein128 wrote:
 PORTB.0 = 0;
Why no comment on this, nor any of the other PORTB.0 lines?
What do you think these lines do?
#define FRAM_SELECT PORTB.0
void WriteFRAM(uint16_t Addr,  uint8_t data )
        FRAM_SELECT = 0;
        FRAM_SELECT =1;
        delay_us(10);
        FRAM_SELECT = 0;
        F_Transmit(Addr>>8); // upper adress bits
        F_Transmit(Addr & 0xff); // lower adress bits
        FRAM_SELECT =1;
void WriteBlockFRAM(uint16_t Addr,  uint8_t *data , uint16_t length)
        FRAM_SELECT = 0;
        FRAM_SELECT =1;
        delay_us(10);
        FRAM_SELECT =0;
        uint16_t a = 0
        while ( a < length)
            F_Transmit(*data++); // Data byte
            a++;
        FRAM_SELECT =1;
I've not read the datasheet on your device, so the above code is just a guess. I expect it will work better than yours - you had some glaring defects.
Thanks for your reply,
it was very helpful and now its clear for me .
