USI / SPI info
11 posts / 0 new
Is there a tutorial on using USI / SPI?
Maybe a good reference that will enable me to get SPI up and running on a tiny84.
larry wilson
There's an Atmel app note about this isn't there?
it seems somewhat vague. I want nuts and bolts details...
larry wilson
You do realise that AVR319 even comes with example C code? Surely that's enough to get you started?
I have looked at AVR139 and see the code references, but I don't see any actual code. Asm code would be preferred.
larry wilson
Isn't there something in the data sheet for the device?
EDIT: just checked; there is no SPI, just USI.
Example ASM code in the datasheet; ch. 14.3.2 (page 119 onwards).
http://www.atmel.com/dyn/resourc...
If you think education is expensive, try ignorance.
The AVR319 files are in:
And in general, at the Atmel site (specifically the page with app notes) the notes per se have PDF icons, and to the right of some of these are disc icons which are links to the sample code.
I would like to utilize the SPI. App Note AVR151 says most AVRs have it onboard, but it appears to me it is only for flash programming. I say that because I cannot find the SPI registers on the attiny's I looked at. I am using the tiny24 but would switch if anybody knows of any attiny that has a general purpose SPI. I cannot simulate with USI because I need mode 3. Thank you.
Tinies (in small packages) as a rule don't have real SPI, some larger ones do. Some have USARTs that can be used as SPI masters.
You can do mode #3 with USI if you want to.   (I think)
As a general rule,  it is never wise to use USI as a Master.   It works quite well as a Slave.   (which is what a Tiny is intended for)
If you want a Master,   the t2313A, t4313, t1634 can all do USART_MSPI which is miles better than a Mega SPI peripheral.
