I nedd your help ... ASF can bus for two nodes !!
2 posts / 0 new
Hallo,
I am using AT32UC3C-EK board with 32-bit AT32UC3C0512C microcontroller and i have modified can_task.c in ASF "CAN-LIN-LOOPBACKS-DEMO" to work on two nodes by using one channel but it didn't work !!
would you help me please !!?
Thank you !!
//can_task.c
#include <stddef.h>
#include <stdio.h>
#include <avr32/io.h>
#include "compiler.h"
#include "board.h"
#include "power_clocks_lib.h"
#include "gpio.h"
#include "pm_uc3c.h"
#include "scif_uc3c.h"
#include "print_funcs.h"
#include "can_task.h"
#include "conf_can_task.h"
#include "dsp.h"
#include "conf_demo.h"
#include <asf.h>
#include "flashc.h"
//! Local Mob Declaration
can_msg_t mob_ram_ch0[NB_MOB_CHANNEL];
/*can_msg_t mob_ram_ch1[NB_MOB_CHANNEL];*/
//! Local function to prepare RX and TX buffers
void can_example_prepare_data_to_send_and_receive(void);
void can_out_callback_transmission_and_reception(U8 handle, U8 event);
//! External reference on ADC Current Conversion
extern volatile uint16_t adc_current_conversion;
//! Buffer to store ADC Conversions
A_ALIGNED dsp16_t signal3_buf[BUFFER_LENGTH];
//! Boolean for message transmitted on CAN channel 0
volatile bool message_transmitted_on_channel0 = false;
//! Boolean for message received on CAN channel 0
volatile bool message_received_on_channel0 = false;
/*! \brief CAN Call Back when message is transmitted
 gpio_tgl_gpio_pin(LED2_GPIO);
 // Transmission Only
 can_mob_free(0,handle);
 message_transmitted_on_channel0 = true;
 gpio_tgl_gpio_pin(LED3_GPIO);
 // Reception Only
 pCANMOB_message2[0].can_msg->data.u64 = can_get_mob_data(0,handle).u64;
 pCANMOB_message2[0].can_msg->id = can_get_mob_id(0,handle);
 pCANMOB_message2[0].dlc = can_get_mob_dlc(0,handle);
 pCANMOB_message2[0].status = event;
 message_received_on_channel0 = true;
/*! \brief CAN Call Back when message is received
void can_out_callback_reception(U8 handle, U8 event)
 // Reception Only
void can_task_init(void)
 // Setup the generic clock for CAN
 scif_gc_setup(AVR32_SCIF_GCLK_CANIF,
  SCIF_GCCTRL_OSC0,
  AVR32_SCIF_GC_NO_DIV_CLOCK,
  0);
 // Now enable the generic clock
 scif_gc_enable(AVR32_SCIF_GCLK_CANIF);
 static const gpio_map_t CAN_GPIO_MAP = {
  {AVR32_CANIF_RXLINE_0_0_PIN, AVR32_CANIF_RXLINE_0_0_FUNCTION},
  {AVR32_CANIF_TXLINE_0_0_PIN, AVR32_CANIF_TXLINE_0_0_FUNCTION},
  {AVR32_CANIF_RXLINE_1_2_PIN, AVR32_CANIF_RXLINE_1_2_FUNCTION},
  {AVR32_CANIF_TXLINE_1_2_PIN, AVR32_CANIF_TXLINE_1_2_FUNCTION}
 // Assign GPIO to CAN.
 gpio_enable_module(CAN_GPIO_MAP,
  sizeof(CAN_GPIO_MAP) / sizeof(CAN_GPIO_MAP[0]));
 can_example_prepare_data_to_send_and_receive();
/*! \brief CAN Task:
 *        - Check if messages are correctly transmitted/received
 *        - Update message for transmission/reception
// Prepare one mob for TX
void prepare_one_mob_for_tx(void)
 pCANMOB_message0[0].handle = can_mob_alloc(0); // ADC
 // Check return if no mob are available
 if (pCANMOB_message0[0].handle==CAN_CMD_REFUSED) {
  while(true);
 pCANMOB_message0[0].can_msg->data.u8[0] =
 ((adc_current_conversion&0xFF00)>>8);
 pCANMOB_message0[0].can_msg->data.u8[1] =
 (adc_current_conversion&0xFF);
 can_tx(0,
 pCANMOB_message0[0].handle,
 pCANMOB_message0[0].dlc,
 pCANMOB_message0[0].req_type,
 pCANMOB_message0[0].can_msg);
// Prepare one mob for RX
void prepare_one_mob_for_rx(void)
pCANMOB_message2[0].handle = can_mob_alloc(0);
can_rx(0,
pCANMOB_message2[0].handle,
pCANMOB_message2[0].req_type,
pCANMOB_message2[0].can_msg);
void can_task(void)
int16_t i;
int16_t value;
 if (message_transmitted_on_channel0 == true) {
  prepare_one_mob_for_tx();
 if (message_received_on_channel0 == true) {
  for (i=BUFFER_LENGTH-1;i>=1;i--) {
  signal3_buf[i] = signal3_buf[i-1];
  value = (pCANMOB_message2[0].can_msg->data.u8[0]<<8)| \
  (pCANMOB_message2[0].can_msg->data.u8[1]);
  signal3_buf[0] = ( value*0x20) - 0x8000;
  prepare_one_mob_for_rx();
/*! \brief CAN Prepare Data to Send
 *        - Allocate one MOB in transmission
 *        - Fill the MOB with the correct DATA
 *        - Start the transmission
 // Initialize channel 0 for transmission
 can_init(0,
  ((U32)&mob_ram_ch0[0]),
  CANIF_CHANNEL_MODE_NORMAL,
  can_out_callback_transmission_and_reception);
/*! \brief CAN Prepare Data to Receive
 *        - Allocate one MOB in reception
 *        - Start the reception
void can_example_prepare_data_to_receive(void)
 // Initialize channel 0 for reception
  can_init(0,
   can_out_callback_reception);
Topic locked
