64-bit variable on Imagecraft 8 AVR comiler
14 posts / 0 new
is the a way to process a 64-bit unsigned Long Long variable on this Compiler,
i have the advanced Version, but i find no way to do this.
Best regrads,
Thomas
The available data types and their sizes are listed in Table 1 on page 171 of the PDF manual:
https://imagecraft.com/documentation/jumpstart-c-documentation
The largest is clearly 32 bits (4 bytes).
Note that there is a contact address for support on page 12 - under "Support".
Do you really need 64-bit  arithmetic - on a little, eight-bit microcontroller ??!
If you do, your choices are
  1. Choose a different  compiler;
  2. Create your own functions (will probably need to be in assembler).
Or, of course, switch to a different processor...
long long is in AVR GCC with 64b signed and unsigned fixed point arithmetic :
https://gcc.gnu.org/wiki/avr-gcc#Type_Layout
ernesti001 wrote:
...to process a 64-bit unsigned Long Long variable...
What 'processes' do you need to do?
For the avoidance of doubt, long long is an integer type; the fixed-point arithmetic can make use of it
EDIT
What I mean is, long long is not just for fixed-point arithmetic
I can handle 64 bit integers with uint64_t (or int64_t) with 8bit AVR in the GCC environment.
Is that strange?
No - see #3
He says he wants to handle 64bit variables.
Giving up the use of 64bit variables is only a temporary one.
To give up if he sticks to the compiler.
Otherwise it is better to change the compiler.
Do not you think so?
But he hasn't said why - nor what kind of "handling" he wants to do
It could be that it isn't actually necessary at all ...
What do you mean by that?
As noted in #2, he could do it "manually"
We don't know how important the in-built 64-bit support is relative to whatever other reasons he may have for choosing that particular compiler ...
Seems a bit too fierce to change compilers just because of a lack of type that almost certainly is not required. If it really is you can build longer type support from what exists anyway. (cf Windows "LARGE_INTEGER")
Reference :
http://www.nongnu.org/avr-libc/user-manual/group__avr__stdint.html
also, aparently, 24-bit:
AVR-GCC Wiki wrote:
Extensions
Types
  • Signed and unsigned 24-bit integers: __int24 (v4.7), __uint24 (v4.7).
https://gcc.gnu.org/wiki/avr-gcc...
ernesti001 wrote:
Best regrads,
Thomas
You should contact imagecraft support about this, as the compiler does support Long Long, but there seems to be a bug in the stdint.h that is missing int64_t and uint64_t for the AVR platform.
If I modify the header file, it works just fine!
Also in the manuals - see #2.
