Atmega 1284P, unknown behaviour
37 posts / 0 new
Hello, I will try to explain this as good as I can. I am developing a project consisting a few sensors and also a HM-10 copy. After the code started growing, I encounteried a problem. The code works fine when powering the board, after about 4 minutes , the behaviour changes. I will try to explain what I observed:
I start sending data from the sensor continously. The program works without any problem for 3,4 minutes, after this time the MCU does not respond to any command sent through bluetooth and it stops sending data. The MCU does not restart only hangs-up.
What is interesting is that no interrupt works anymore  ( ex: an interrupt is generated when the phone is connected to the bluetooth module). The program is made as a state machine, the MCU is able to switch to the other state. For example I have 2 states ACTIVE and SLEEP, if no BLE connection is up for 1 minute it enters in sleep mode. After hanging up the MCU enters sleep mode but no interrupt can wake him up anymore. Usually when it is working as soon as I connect the phone to the module, it exits sleep mode.
We're going to need to see code, schematics and preferably the smallest cut down code that still exhibits the same fault. In preparing the latter you will likely find the issue anyway!
If the code is modular and each module has unit tests then the points of failure should already be identified anyway.
Are you certain that the BT is still working?
WHat if you take BT out, and just use a wired connection?
Is it?
Again, how have you verified that it's not the BT module that's stopped generating interrupts?
So instrument the state machine to allow you to see what state it's in.
But sometimes it doesn't?
You need to take a methodical approach to find where the problem occurs - this is the essnce of debugging.
http://www.avrfreaks.net/comment...
I am reading the incoming signal from the bluetooth with a serial converter. The bluetooth is connected through UART to the MCU. On the Rx pin of the MCU I have also the RX of the serial converter and I receive the text sent from the phone.
Yes it is , before the MCU hangs up I can check if the interrupt is generated. Also the bluetooth has a led for connection.
I am using a led for this issue and I see when the state changes, and it is able to do this .
I said usually by mistake, every time I connect the phone , before this error occurs , it works.
I was thinking that this is the next step, but I am not able to post any code or any schematic here. I am trying to find some clues where to find. I am also thinking at some memory corruption. Is it anyway to check the memory state, or the memory usage time to time. I am thinking at some pointers badly mannered, or some stack overflows, but I am not sure. I lost a lot of time trying to identify the problem. Also if anyone want to see the code, we can use some remote control programs.
two things come to mind, for projects that work for awhile then suddenly stop working.
Stack overflow, corrupting memory,  can you place "guard bytes" below the stack to track how deep it goes before the problem happens?
or improper sleep mode setup, i.e. no wake up source setup before going to sleep mode.
For the first one, can you substitute a larger family member part, i.e. tiny85 instead of tiny25, mega 328 instead of mega 48, etc.... so you have more head room to work with?
..... ok, scratch that, I see your using a large member part already!
edit: family part correction...
It may not be your problem but the 1284P is known for having problems when using an external crystal and running the oscillator not in full swing mode. Especially when using the USART.
I don`t know how to put such guard bytes, if you can tell me, it would be perfect.
I am using the oscillator in full swing mode . I have a crystal attached to xtal1 and xtal 2.
For Stack checking, One of the GCC freaks will need to guide you on how to do it with that toolchain.
But for an overview see, https://en.wikipedia.org/wiki/Bu...
Atmel Studio
Stack Overflow Detection Using Data Breakpoint
http://www.atmel.com/webdoc/GUID-ECD8A826-B1DA-44FC-BE0B-5A53418A47BD/index.html?GUID-A4FC8DB5-6B28-4893-93BA-7A4406698E5D
gchapman wrote:
Atmel Studio
I need to mention that I do not have access to debug. I am programming through ISP.
I have used a modification of the technique described here when developing code:
http://www.avrfreaks.net/forum/soft-c-avrgcc-monitoring-stack-usage
David (aka frog_jr)
Then test for a change in your main() loop and light an LED (or provide some indication) when detected.
I am doing the led thing already , but as I said, I cannot obtain some specific clues.
I will try this right now.
Is the error mode reproducible?
i.e. Will it always crash after 3 - 4 minutes?
Will it crash if it just sits still for 4 minutes without the BT connection going active?
Does increasing the number of BT connection / disconnection episodes shorten the time to crash?
How do you in your programming language set the stack?
(i.e. in Basic I set three stack sizes in the program's header)
If the crash is reproducible, can you simply significantly increase your stack sizes and see if that changes the crash behavior?
Now while I was testing I see that the device does not respond anymore. The state hangs in sending data state and also does not respond to any command. What I tested today was if the amount of data corrupts the MCU. I tried to send a bigger quantity of data over serial, by decreasing the delays used. My states had delays to decrease the speed of data transmission. I removed all the delays and the MCU hangs at the same amount of time it hanged before.
I downloaded the files included in my project and called only the function StackCount. I receive value 0 no matter what I do , even if I call the function right after port initialization, without calling any function. What am I doing wrong?
Did you add the StackPaint to your program (in the .init1 section)?
And if using gcc, you use the following (depending on what you want to measure):
extern uint8_t _etext;		// End of program (actually points to next not used location)
extern uint8_t __data_start;	// Start of initialized variables (bottom of SRAM)
extern uint8_t __data_end;	// End of initialized variables (== __bss_start)
extern uint8_t __bss_start;	// Start of uninitialized variables
extern uint8_t __bss_end;	// End of uninitialized variables (== __heap_start,  == _end)
extern uint8_t _end;
extern uint8_t __heap_start;	// Start of dynamically allocated memory (malloc)
extern uint8_t __stack;		// Top of Stack == Top of SRAM
David (aka frog_jr)
Ok. I added the folders to my project, I included them and I did the next things:
#include "string.h"
#include <avr/wdt.h>
#include "stackmon.h"
void StackPaint(void) __attribute__ ((naked)) __attribute__ ((section (".init3")));
first part .
memorySpace=StackCount();
	printf("Valoare %d\r\n",memorySpace);
second one
Now , the MCU is restarting continuously, after the same amount of time. I think I could time the restarts perioad :))). It is like a counter did this stupid thing. I really don`t know how to solve this.
Sounds like the Watchdog ...
I am checking the MCUSR register. No watchdog reset is there.
I am trying to implement the stackCount , but I had no success so far. I don`t know how to do it.
The Mcu restarts around 7 minutes. It happened to restart exactly at 7 minutes.
What does mcusr say >>is<< the restart cause? It may be time to go get yourself a debugger. In lieu if that, you could insert some code into .init0 which could test mcusr and send captured state to the usart in the event it traps a restart with no cause.
"Read a lot.  Write a lot."
+999999999999999999999999999999999999999999999999
Time for that quote again:
js wrote:
[not having a debugger is] like a mechanic not having any spanners.
See: http://www.avrfreaks.net/comment...
And: http://www.avrfreaks.net/comment...
  It does not show any restart source. The problem is that i designed the whole program for not having debugger. On the pins that a debugger is connected i have other things.
Seems like you've painted yourself into a corner.
Looks like you'll have to:
... or some other interface in lieu of the usart.
Ask if you need help with that.
So not only do you have no spanners yourself, but you've also ensured that spanners cannot be used at all!
surprise
Kinda! I made some changes today,( more exactly the entire day and I connected the JTAG ( Dragon). Now the problem is that I don`t know how to look for the problem. What memory to check for. On the memory tab on debugger I have :
progFlash
prog BOOT_SECTION_1
prog BOOT_SECTION_2
prog BOOT_SECTION_3
prog BOOT_SECTION_4
data registers
data MAPPED_IO
data EEPROM
data IRAM
osccal osccal
What should I do to track the problem. Any chance that any of you connect with me on skype to help me a little bit more. I want to find this error quickly :(
If you're fortunate a lint would identify the actualized defect.
Otherwise, sprinkle the source code with asserts.
If you have data or information or intuition that there's a probable/likely stack overflow then the assert will test for SP in the stack guard region.
Other asserts can examine for buffer overflows, divide by zero, range constraints, etc (overflow results in an infinite loop that's terminated by the watchdog)
The problem with AVR libc's assert macro is it calls abort(); when SP is out of bounds then abort is inconsistent so exit() may not be invoked (breakpoint in exit(), operate debugger to read data)
Could create an application-specific assert macro to do what you want like write a byte in .noinit that's specific to that instance of assert or write that byte to a spare port to be captured by a logic analyzer.
An alternative is a circular buffer in .noinit that contains "breadcrumbs"; this is akin to the in-RAM instruction trace buffer of AVR32 UC3 and ARM Cortex-M.
Another is, if there's a spare SPI or a spare port, to write a unique byte for a source code line; this is the instrumented trace of MPLAB X with REAL ICE's logic analyzer.
The Ganssle Group logo
The Ganssle Group
Automatically Debugging Firmware
By Jack Ganssle
Major rewrite: May, 2014
http://www.ganssle.com/dbc.htm
http://www.nongnu.org/avr-libc/user-manual/group__avr__assert.html
http://www.nongnu.org/avr-libc/user-manual/mem_sections.html
While I was trying to make some debug I discovered something. I was in debug mode, on pause. Even If I was pausing at a instruction the MCU restarted itself and the code was reexecuted.
IIRC, there's a debugger configuration during break to disable ISRs and/or timers.
Otherwise, an oscillating Vdd could trigger BOD or the reset signal is inadvertently active.
This is another photo of the stack pointer and it seems to keep its value. How can I see who is the entity which writes that portion.
For me it does not look so good, I think i know the function that writes that part of memory.
I've not read the whole thread but if you have rogue writes why can't you use a data breakpoint to catch the culprit?
