Ultrasonic Sensor HC-SR04
24 posts / 0 new
Using atmega 8
code is written to glow led at a distance of 3cm or 5 cm but it is doing nothing.
components used are :- atmega8,HC-SR04
 * Ultrasonic.c
 * Created: 9/26/2017 5:23:14 PM
 * Author : PC
#define F_CPU 1000000UL
#include <avr/interrupt.h>
#include <util/delay.h>
 int i=0;
 int pulse=0;
 int count;
DDRC= 0xff;
DDRD |= 0x01;         //PIN0 for trig
DDRD &= ~0x04;        //PIN2 for Echo(For INT0)
PORTD &= ~0x04;
GICR |= 1<<INT0;
MCUCR |= 1<<ISC00;
sei();
    while (1)
PORTD |= 0x01;
_delay_us(15);
PORTD &=~0x01;
if(count == 174)
PORTC = 0x01;
if(count == 290)
PORTC = 0x02;
ISR(INT0_vect)
if(i==0)
TCCR0=0x01;
TCNT0 = 0;
i=1;
if(i==1)
pulse  = TCNT0;
count = pulse/58;
TCCR0 = 0x00;
TCNT0 = 0;
i=0;
vemohit
Have you looked at the 1000 other questions and answers about this same/similar topic on this website> I suspect not!
How to properly post source code: http://www.avrfreaks.net/comment...
vemohit wrote:
if(count == 174) { PORTC = 0x01; } if(count == 290) { PORTC = 0x02; }
What are the odd's that the range will be exactly that value?  and for how long?
Why not use a range of values to test and activate your LED's.  i.e. say 170 to 180, or 280 to 300?  or perhaps using an even wider range to start then narrow it down once it works.
Also, you need to look up "volatile" and how it is used with variables shared between main() and ISR()!
I suspect that this bit of code doesn't do what you think it does...
ISR(INT0_vect)
    if(i==0)
        TCCR0=0x01;
        TCNT0 = 0;
        i=1;
    if(i==1)
        pulse  = TCNT0;
        count = pulse/58;
        TCCR0 = 0x00;
        TCNT0 = 0;
        i=0;
HINT: trace the execution paying particular attention to the value of i.
vemohit wrote:
 * Author : PC
So have you asked "PC" why his/her code doesn't work?
Well spotted. Why are some people so allergic to switch/case/break? It makes stuff like this so much easier to avoid.
Including the very recent http://www.avrfreaks.net/forum/h...
Indeed:
...which includes a Tutorials forum article.
tried it earlier but it didn't workout!!!!
vemohit
I think u r suggesting to make 'i' volatile?
vemohit
Can anyone suggest a solution? I am new to this forum it will be really helpful.
vemohit
See #2 & #8
Do you have any experience with microcontrollers? electronics? programming in general? how to use an internet search engine?
Not i, but count yes.
volatile int count;
Also replace
if(i==1)
in your ISR with
else // if(1==1)
Nope not working!!!
vemohit
Show current code so we can check you have applied the advice given so far. The 'i' thing is vital.
Show us your new code, please use <> code buttons this time.
See #3
Another major flaw of your code: you are constantly starting new measurements. I personally have no idea how the module reacts when you give a new start pulse while an ongoing measurement.
Stefan Ernst
int i=0;
int pulse=0;
volatile int count;
	DDRC= 0xff;
	PORTD &= ~0x04;
	GICR |= 1<<INT0;
	MCUCR |= 1<<ISC00;
	sei();
    while (1)
		PORTD |= 0x01;
		_delay_us(15);
		PORTD &=~0x01;
		if((count>170)&&(count<180))
			PORTC = 0x01;
		if(count == 290)
			PORTC = 0x02;
ISR(INT0_vect)
	if(i==0)
		TCCR0=0x01;
		TCNT0 = 0;
		i=1;
		pulse  = TCNT0;
		count = pulse/58;
		TCCR0 = 0x00;
		TCNT0 = 0;
		i=0;
vemohit
Total votes: 2
No commentary?
You have been told that exact matching isn't going to work well, if at all.
TCNT0 is an 8-bit register.  It can only have values 0-255.  Divided by 58, your "count" will only have possible values of 0 1 2 3 4.
Actually I'm testing the Ultrasonic.
so previously i have also tried with
if (count>0)
{ PORTC = 0x01;
So the thing is 'count' is not getting any value.
vemohit
And one result of this testing seems to be: the ultrasonic module doesn't like to get a new start pulse before finishing the measurement.
Stefan Ernst
Surely in the many previous discussions I pointed out above, there are working approaches.
The most recent link I gave uses pin-change interrupt, and looks at the state of the pin.  If you are going to use external interrupt, don't you have to wait for rising edge first, start your timer, and then change to look at falling edge?  I see no management of edge selection in the code you posted.  I guess the selection of "any change" might work, >>if<< you never get out of syncronization
Thank you all for your help!!!
Changing the timer from TIMER0 to TIMER1 works.
Thanks @theusch.
vemohit
