Warning of redefining a register
6 posts / 0 new
I have ATmega8 and I write its codes in assembly only using AS6.2 SP1.
I agree that, in case a register is redefined, the warning is useful in general; it was discussed here years ago.
But, as you know, there are always exceptions to the rule ;)
For example, in some projects, redefining a register with different names when it is used as a temporary one in different functions (called exclusively) lets the source code be clearer (without extra comments); mainly if there are many of such register.
So I thought that perhaps an option to disable this warning (in a project) was included in recent versions. By searching so far, I couldn’t find this option but perhaps I missed it.
Thank you.
KerimF wrote:
redefining a register with different names when it is used as a temporary one in different functions lets the source code be clearer
I disagree - that sounds like a Really Bad Idea.
Surely, by obfuscating the fact that you are sharing the same register, you just increase the risk of this causing problems!
Yes, in general, it is a really bad idea as you mentioned.
But after designing tens of controllers in which it was better, for me in the least ;) , redefining my temporary registers with different names, I just liked to know if it is possible for me to get rid of tens of warning lines (about redefining) that separate me from the error lines :) during syntax debugging.
So I hoped that someone here can 'confirm' that the option doesn't exist. After all, I became familiar with this warning :)
You first need to tell which assembler you are referring to.  Is it Atmel's AVRASM2?  Or GCC GAS?
Are you speaking of fragments like this?
AVRASM ver. 2.1.30  C:\OptiCode\HY148\List\HY148p.asm Wed Sep 27 16:07:24 2017
C:\OptiCode\HY148\List\HY148p.asm(1101): warning: Register r2 already defined by the .DEF directive
C:\OptiCode\HY148\List\HY148p.asm(1102): warning: Register r3 already defined by the .DEF directive
C:\OptiCode\HY148\List\HY148p.asm(1103): warning: Register r5 already defined by the .DEF directive
C:\OptiCode\HY148\List\HY148p.asm(1104): warning: Register r4 already defined by the .DEF directive
C:\OptiCode\HY148\List\HY148p.asm(1105): warning: Register r7 already defined by the .DEF directive
...where the offending lines might be
;NAME DEFINITIONS FOR GLOBAL VARIABLES ALLOCATED TO REGISTERS
    .DEF _worknum=R2
    .DEF _worknum_msb=R3
    .DEF _state=R5
    .DEF _line_dirty=R4
    .DEF _item=R7
Now, the above are excerpts from the .ASM produced by the CodeVision C compiler.  The "offending" lines correspond to global register variables.  The redefinition allows the ASM source to refer to those register variables by name.
[As further background, CV .DEFs all the GP registers thus creating the conflicts...
    .DEF R0X0=R0
    .DEF R0X1=R1
    .DEF R0X2=R2
    .DEF R0X3=R3
    .DEF R0X4=R4
    .DEF R0X5=R5
    .DEF R0X6=R6
    .DEF R0X7=R7
    .DEF R0X8=R8
    .DEF R0X9=R9
    .DEF R0XA=R10
When I've done ASM apps, I remember redefining  some registers to give more meaningful names in different sections of the program.
If the above is your situation, I wouldn't find those warnings to be a "bad thing".  It would alert you when you >>do<< give registers different names.
I am sorry for not being clearer when I started my OP with "I have ATmega8 and I write its codes in assembly only using AS6.2 SP1".
I should remember that the assembler I am using is AVRASM2.
I agree that this warning is surely not a bad thing. I just wished I can disable it whenever necessary. So it was just a wish that won't be the first or the last one that cannot be made real.
Total votes: 2
Greg Muth
Portland, OR, US
