AVRdude rebuilt with patch
12 posts / 0 new
Hi all,
I'm not an expert with software building. But I'm looking for a tutorial that describes how to make an own built for avrdude.
I have an AVRispmkII from olimex and avrdude is not working on my windows 7 machine in combination with the XMEGA128A4U.
I notices the bug report, but I have no clue how to apply the patch and how to rebuilt avrdude 6.3 with the patch applied. Can somebody help me?
thx!
Windows or Linux? Latter should be trivial, former will make you weep blood!
First: While I have not built AVRDUDE on Windows I recently did so on Linux Mint. OTOH I have done e lot of other development work on Windows.. So what follows is a "vague extrapolation" based on those two experiences:
You need a C/C++ tool chain that runs on, and targets, Windows. I assume it should be GCC. You can get that, and the eco-system it can work in, by installing MinGW (Minimal GNU for Windows), probably including (or amended by) MSYS. It's been too long since I did set up a MinGW environment on Windows, so I'll direct you to the MinGW wiki for this. WithMinGW/MSYS in place you can attempt an actual build.
AVRDUDE uses the GNU build system ("Autotools"). I.e. it comes with a configure script that, when run, will probe the system for functionality needed/supported and create a makefile. Thiss makefile can be used to do the build.
Looking in my notes from my build on Linux it goes like this:
First, in the root of the source tree
prompt> ./configure
to create the makefile. Keep a lookout for reports of errors or things missing. You'll have to fix any of those before proceeding. (On my Mint I had a lot of library stuff missing that I had to d/l and install at this stage).
After that the actual build is accomplished by this:
prompt> make
As for how to apply the patch, it depends on what form this patch has. If it is a .patch (or .diff (?)) file then you apply it by using the patch command.
Also note this terse stuff in the AVRDUDE docs on building on Windows: http://www.nongnu.org/avrdude/us... . It focuses on using Cygwin, which I (for possibly biased reasons) discourage. Alas, the note on the alternative ("use MinGW/MSYS directly") is not fleshed out in any detail.
If you tell us more about the problem with current AVRDUDE and the ATXmega128A4U we might be able to toss in some detailed advice. It could be that it is only a matter of patching the config file of AVRDUDE, not the executable as such. If you actually link to the bug-report/patch you are hinting at things might become clearer.
I wish to apply this patch in order to get it to work. http://savannah.nongnu.org/bugs/...
I have cygwin installed. Further steps are unknown for me.
Is the GCC tool chain in good working order? What happens if you simply type
gcc --version
on a command line?
Note the remark in the AVRDUDE doc page I linked to above that says
 recent versions of Cygwin (starting with 1.7) removed the MinGW support from the compiler that is needed in order to build a native Win32 API binary that does not require to install the Cygwin library cygwin1.dll at run-time
This might, or might not, be something that will influence your descision on if to use Cygwin or "use MinGW directly". Main difference, as I understand it is that building with Cygwin requires the Cygwin1.dll present when running the program while building directly with MinGW/MSYS does not.
The patch you want to apply is actually a .patch file, so the patch command should be used. Any manpage should tell you how to use the patch command, e.g. https://linux.die.net/man/1/patch .
As for the build, I would hope that the aforementioned steps should suffice, e.g.
./configure
make
As I hinted at above I am not a fan of Cygwin, but use MinGW/MSYS without groaning too much. I'm sorry I thus can't help you more explicitly with Cygwin. Let us know if you go down the "direct MinGW/MSYS" route. I believe I still have MinGW/MSYS installed on my Windows 7 system and might  be able to follow/help you with the build.
http://download.savannah.gnu.org/releases/avrdude/avrdude-doc-6.3.pdf
(page 39)
There are two options to build avrdude from source under Windows.
(Cygwin + MinGW, MinGW)
@gchapman: Same text as I linked to in my first post.
For reason I don't recall I have the Cygwin on my system. I recall something on Msys or MinGW. I just don't know if it is still installed. This is also done through the Cygwin right? Both path are possible for me. I'm just looking for the most efficient way to get a complied version of avrdude for windows with the patch included.
FYI: GCC is working.
Well, JohanEkdahl brought MinGW to my attention. Therefor I started looking on the internet. I found this guide to compile avrdude.
http://tomeko.net/other/avrdude/...
Using this command I applied the patch.
patch < endpointdetect_pass1.patch
Unfortunatly the make failed with the following response which leaves me clueless.
make[2]: *** [libavrdude_a-lexer.o] Error 1
make[2]: *** Leaving directory '/c/MinGW/msys/1.0/home/hebbrem/avrdude-6.3'
make[1]: *** [all-recursive] Error 1
make[1]: *** Leaving directory '/c/MinGW/msys/1.0/home/hebbrem/avrdude-6.3'
make: *** [all] Error 2
Any suggestions?
MathieuMH wrote:
Any suggestions?
Work further back up the output - that final error is the consequence, not the reason.
Oke, I'll try to be more complete. There seems to be an issue is the usleep instance.
Bellow a screenshot of the whole result of the make command.
Apparently nothing in this life is ever really new. That was happening back in 2008 (9 years go) too...
https://lists.gnu.org/archive/ht...
EDIT: The curious thing though is back then the fix was:
-void usleep(unsigned long us);
+int usleep(unsigned int us);
yet this now seems to be the cause of the error. Sounds a lot like a 32 bit versus 64 bit thing to me.
(which is EXACTLY why God invented stdint.h). You might want to determine how your headers define useconds_t I guess.
EDIT2: apparently useconds_t is in <sys/types.h>. I guess you need to modify the .h in avrdude source to match.
One day someone will push a change to avrdude source to remove use of nasty things like "int".
