Decode C sequence
27 posts / 0 new
Hello people,
Can somebody please explain me the logic/algorithm behind this code. I could figure out a couple things but wasn't able to connect them.
This section is for BiPhase encoded data capture:
void biphase_capture(void)
#ifdef DEBUG_EMDB409
  sbi(PORTA,DEC5);
#endif
  uint8_t y,delta;
  uint16_t capt;
  uint16_t icr = ICR1;
  TCCR1B ^= (1<<ICES1);             // Switchover of sensitive ICP edge
  capt = icr - last_capture;
  last_capture = icr;               // counter1 is now free-running
  if(capt>255) delta = 255; else delta = (uint8_t)capt;
  if (debug_mode > 2) {
     if(debug_mode==4) store_pulse_lenght(delta);
     else {
       store_pulse(delta);
       return;
  y = 0;
  delta += halfDataRate >> (TOLERANCE_SHIFT);   // dynamic resolution (dependent on datarate)   !!!!! >> 2
  delta -= halfDataRate;        // always subtract datarate/2
  if (delta > halfDataRate) {   // when longer than that, try to subtract once more
    y++;
  if (delta > halfDataRate) {        // check overflow of counter and range
                                    // this check is also dynamic, depends on current datarate
                                    // the faster datarate the more precise must the signal be
    if (last_valid == 0) {
      store_bit(bit_pos^1, 0);      // rtf feature
      store_bit ( 0, 1);            // store bad bit
      last_valid = 1;
    bit_pos = 0;
  } else {
    if (y) {
      store_bit(1, 0);
      bit_pos = 0;
      last_valid = 0;
    } else {
      if (bit_pos++) {
        store_bit(0, 0);
        bit_pos = 0;
        last_valid = 0;
  cbi(PORTA,DEC5);
#endif
This section is for Manchester encoded data capture:
void manchester_capture(void) {
  sbi(PORTA,DEC5); //debug port set
#endif
  uint8_t y, delta;
  uint16_t capt;
  uint16_t icr = ICR1; // T/C 1 input capture register
  edge = TCCR1B; //Timer/Counter 1 Control and Status Register
  TCCR1B = edge ^ (1<<ICES1);   //T/C 1 Control and Status Register Bit    // Switchover of sensitive ICP edge
    if(debug_mode==4)
    else {
      store_pulse(delta);
      return;
  if ((first != 0) && (forward_link_type == EM4150)) {                     // according to the first pulse length, manchester decoder is synchronized
    first = 0;
    last_bit = 0;
    capt = maxCaptureTimeLow + icr;
    if (capt < (uint16_t)(2*halfDataRate) )  //with setup latency of about 12 RF clocks
      bit_pos = last_bit = 1;
      store_bit(last_bit, 0);
    return;
  y = 0;
  delta += halfDataRate >> 2;   // dynamic resolution (dependent on datarate)
//  delta += (halfDataRate >> TOLERANCE_SHIFT);   // dynamic resolution (dependent on datarate)
    y++;
  if ((delta<<1) > halfDataRate) {     // check overflow of counter and range
    if(last_valid == 0) {
      last_bit = ((~edge)>>ICES1)&1;   // rtf feature 4026
      store_bit(last_bit, 0);           // rtf feature 4026
      store_bit ( 1, 1 );               // store bad bit
      last_valid = 1;
      bit_pos++;                        // change! 4026
    last_bit = 0;
  } else {
    if (y) {
      last_valid = 0;
      bit_pos = 0;
    } else {
      if (bit_pos++) {
        bit_pos = 0;
        last_valid = 0;
  cbi(PORTA,DEC5);
#endif
Really appreciate if someone could give me any input.
AM
Amateur programmer.
Believe when I tell you that my struggle on here is real.
What does this have to do with the previous questions in this thread??
For a new question, start a new thread!
I tried posting it on the Compilers and General Programming forum; it wasnt getting published. So I had asked a moderator to help out - it was suggested that I post it here. Is there a specific forum for posts like these?
Amateur programmer.
I've split/moved it. PM sent.
How to properly post source code: http://www.avrfreaks.net/comment...
So which bits don't you understand?
Do you actually understand how BiPhase encoding works?
Clearly, that is going to be fundamental to understanding the code ...
Atmel has an app note on Manchester Coding Basics #9164   using that as a google search will help you understand how biphase encoding/decoding works.
Yes I do. A transition happens from High to Low or Low to High at the beginning of each bit period. If 0 is transmitted - there will an additional transition in the middle of the bit period - in case of 1 no transition in the middle of the bit period.
Amateur programmer.
The Author of that code should be able to explain it!
Where did you find it? Have you asked there?
Right here: http://www.atmel.com/images/atmel-9164-manchester-coding-basics_application-note.pdf
It explains the principles, and includes example code ...
BiPhase in that document is defined the opposite of what I posted on here. Which convention is true?
Amateur programmer.
Thats what I followed from EM. The ATMEL document has it defined the opposite. Are there two conventions like the Manchester?
Amateur programmer.
Total votes: 2
I would think that someone with 70+ posts would have figured out how to post source code by now.
Greg Muth
Portland, OR, US
I don't think it maters if it is H/L or L/H, but whether a change occurs mid way or not.
So if the bit is backwards, just invert it.  You decide which coding/decoding is right for you.
Or in this case, how the algorithm above decodes it.
Thanks for showing me that.
Amateur programmer.
So say if some chips are encoded one way and some the other way - the decoding should support both right? (sorry if this was a dumb question)
Amateur programmer.
What chips are we talking about?
That's entirely up to you: it is your code - so you choose whether you want it to be specific to a particular chip or not ...
Ooops - transponders
Amateur programmer.
#define BUFFSIZE 128
#define UPPERTIMINGLMT 5000
#define SAMPLING 0
#define TIMING 1
#define MANCHESTER 0
#define BIPHASE1 1
#define BIPHASE2 2
#define INVERTED
//#define NONINVERTED
// Error codes
#define SyncErr 2
#define BitErr 3
#define TagErr 4
// Declare your global variables (extern) here
extern struct DecodeTiming DecodeReadTime;
extern volatile unsigned char cDataBuff[BUFFSIZE];
This is from the global definitions on that file - why do they have two versions of BiPhase? indecision
Amateur programmer.
See #14 ?
Can you post a link to where you found this code, as I don't see those defined values in the code snippet you posted, and my crystal ball is in the shop for repairs just now.
http://www.atmel.com/images/atme...
Crystal Ball..repairs..? wait, what?
Amateur programmer.
azimmali wrote:
why do they ... ?
Why don't you ask "them" ?
You know who "they" are - we don't.
Oh shoot. Ok.
Amateur programmer.
I don't know for sure, that is not explained in the Atmel doc or in their code.
In the code they define it and have a function prototype but no code.
Ok. No worries. I will try to understand whats being done. The algorithm in both cases are different.
Amateur programmer.
