mEDBG tool not appearing in ATTiny1616 project
11 posts / 0 new
I have an ATTiny817 Xplained Mini board (which has an mEDBG built-in) connected to an external ATTiny1616 (with the zero-ohm resistor removed to bypass the on-board 817).
While the target appears and programs properly in the Device Programming window (so long as I key in "ATTiny1616" in the "Device" field...), it does not appear in the "Tool" section of my ATTiny1616-targetted project.
It does appear in the Tool section of projects that target the ATTiny817.
How do I get this tool to appear in Atmel Studio?
I purchased the ATTiny817 Xplained Mini board specifically because it advertises that it has an mEDBG debugger built-in, and Atmel Studio reports that the ATTiny1616 supports mEDBG debuggers:
I would have purchased an Xplained Mini ATTiny1616 board, but they don't appear to exist.
Sorry to be OT, but how do you configure a dark background on Atmel Studio?
Why would anyone want a dark background in Studio?
@jaycarlson:
If I recall correctly, the mEDBG on Xplained boards are "locked down" to only handle the AVR model on the specific board. I.e. (and if I'm correct) you can only debug ATtiny817 AVRs with that board.
Like it or not, but my recollection kind-of makes sense. If any Xplained board with an mEDBG could debug every AVR then there would be a much smaller actual market for the Atmel-ICE.
(So, how come it can program your tiny1616? Maybe Atmel missed something, or maybe they didn't care..)
I had a look though the 817 Xplained users guide, but could see no proof of my hypothesis/recollection.
@El Tangas: Tools menu, Options. In the tree control in the Options dialogue: Environment, General. In the right pane, select a Color theme.
Well, some people find dark backgrounds less tiring on the eyes and I'm one of them. It's just personal preference.
Now, back to the OP problem, when I look into the file medbg_fw.zip inside my Atmel\Studio\7.0\tools\mEDBG folder, it has 4 versions of firmware inside, they seem specialized for each protocol, but not for each chip. So I don't know how Studio "locks" them. However, it would be interesting to flash a Mega32U4 with this firmware and see what happens.
The file "Atmel.ATtiny_DFP.pdsc" (look for it in the installation folder of AS7) contains the information that appears in the "Device" tab, but it's not really useful either. The locking mechanism must be somewhere else.
edit: Tnx Johan
Here's som (of many) hypotheses: Remember that Studio can recognize a board model, i.e. every Xplained board has some board model ID on it. With that the lock-down would be doable. Or it could actually be that the mEDBGs are is some way customized for the board they are on.
My recollection of this lock-down is from something I read several years ago when the first Xplained boards came out. (Or I could have mixed things up with some Luminary Micro I was testing then..)
The tiny817 xplained manual says
3.1. Mini Embedded Debugger
The ATtiny817 Xplained Mini contains the Atmel Mini Embedded Debugger (mEDBG) for on-board
programming and debugging. The mEDBG is a composite USB device of two interfaces; a debugger and
a Virtual COM Port.
Together with Atmel Studio, the mEDBG debugger interface can program and debug the ATtiny817.
There's nothing there to suggest the medbg can be used for anything but the 817 on the board. Most xplained boards are like this. If you want an medbg that can program/debug any AVR you need an Atmel-ICE. Otherwise why would anyone ever pay for an ICE?
"mEDBG" isn't a protocol; it's a type of embedded debugger found on dev boards. Atmel-ICE does not have support of "mEDBG" — it does have support for UPDI. If mEDBG debuggers are target-specific, why on earth would Atmel Studio list that the ATTiny1616 supports "mEDBG" debuggers if Atmel doesn't make an ATTiny1616-specific mEDBG-enabled dev board? It's misleading.
While this may seem obvious to you, it is unheard of outside of the Atmel ecosystem. Most semiconductor manufacturers have realized the ridiculousness of trying to make money off tools — basically every MCU out there is available on a sub-$30 dev board, and that dev board can almost universally be used for debugging arbitrary targets in the CPU's family. In fact, I'd say the majority of dev boards from Silicon Labs, TI, Microchip, ST, and NXP are actually designed from the ground up to easily debug external targets. Why would a manufacturer want to make it more difficult to use their part in a design?
The big difference I see is that most manufacturer's embedded debuggers are USB Full Speed, instead of USB High Speed, which the stand-alone third-party debuggers (think SEGGER J-Link or Microchip ICD) use.
I don't have an Atmel ICE; I only an AVR Dragon, which was the debugger recommended to me by an Atmel rep a year or so ago. Yet, it seems like Atmel's MCUs use a new debug protocol every time I look at the ecosystem, and the AVR Dragon is unable to debug (or even program) the new chips.
I am so, so sick of getting burned by Atmel tools, especially given how average these AVR parts are when compared to everything else out there these days.
The pricing policy is Microchip's. They doubled the cost of ATMEL-ICE almost as the first action when they took over Atmel.
And the electronics inside an Atmel-ICE is basically the same as on xplained just with less limited firmware.
By the way, @ataradov over on the EEVBlog forums mentioned that you can totally use an mEDBG with different targets — just go to Tools (Main Menu) -> Options ... -> Tools -> Hide Unsupported Device -> False
