LM258D question
13 posts / 0 new
Dear freaks,
I am using an LM258D opamp connected as a comparator, beeing supplied by single voltage 5.1Vdc. Would you be able to tell me what it's gonna be happen if the input (+) voltage is higher than the opamp supply? For ecample what will happen if the input voltage (+) will be at 30Vdc ?
Michael.
User of:
IAR Embedded Workbench C/C++ Compiler
Altium Designer
According to the following, as long IN(-) is between Vcc and GND, IN(+) can go to VccMAX, so +30V should be OK:
Greg Muth
Portland, OR, US
Xplained Boards mostly
icarus1 wrote:
LM258D
What does the 'D' signify?
I'm not finding any datasheets which mention a 'D' suffix
The absolute max is +32V - so you could be cutting it a bit fine ... ?
Andy, if my memory is correct, D is dip plastic. The first digit 2 signifies industrial. 1 is military and 3 commercial.
The OP can use a resistor divider to lower the voltage to the input of the opamp.
Thank you all.
Michael.
User of:
Altium Designer
From what I read in the data sheet you must not exceed Vcc at your inputs so if Vcc is 5.1 then you cannot put 30vdc into an input. I am guessing there might be a protection diode at play here.
I've Vcc is 30v then you can apply 30v to the inputs. But if Vcc is 5.1 then you cannot
After Jim's reply I am completely confused !!! Where is the truth ?
Michael.
User of:
Altium Designer
From the datasheet...
(4) The input common-mode voltage of either input signal voltage should not be allowed to go negative by more than 0.3 V (at 25°C). The upper end of the common-mode voltage range is V+ -1.5 V (at 25°C), but either or both inputs can go to 32 V without damage (26 V for LM2904), independent of the magnitude of V+.
So, for normal operation the input must not exceed (+ve pin - 1.5V) but no harm will happen if it goes to 32V.
But 30V is very close to 32V which is the absolute maximum.
That's for correct op-amp operation.
The datasheet extract in #2 shows that you can go beyond that - up to 32V - without damage.
Since the OP is just using it as a comparator, that should be fine.
EDIT
So long as he also observes the other provisos in that extract
Yeah, but...
Is the op-amp going to function correctly,  as a comparator, with the 30 V input?
I don't think that is guaranteed.
So, are we talking about some transient voltage spikes, or about a steady state input at 30 V with which the op-amp is expected to correctly function as a comparator?
More info is needed.
One might consider clamping the 30 V to 5 V with a resistor and zener, for example, as part of the front end analog signal processing, prior to feeding that signal into the op-amp.
From my interpretation of the datasheet, as long as one of the inputs is within valid range (-0.3 to VCC - 1.5V) then the output will at least have the correct phase, so it should work OK as comparator.
Yes - that's the way I read it.
The + input is a steady voltage of 30Vdc. I am not talking about spikes.
In any case I am going to put a voltage divisor before the input. In any case...
Michael.
User of:
Altium Designer
