AC dimmer
10 posts / 0 new
Hi all,
Please help me. I am trying to create an AC dimmer controlled with remote. I  have done it. But the problem is, I want to add two push button to increase and decrease the speed.
void main()
    uint8_t rcmd; //Command from remote
    Initialize();
        rcmd=GetRemoteCmd(1);
        //Seed Up
        if(rcmd==RV_UP)  // Here I want to add a button (in-case lost or malfunction of remote)
            if(speed<9)
                speed++;
        //Speed Down
        if(rcmd==RV_DOWN)  // Here I want to add a button (in-case lost or malfunction of remote)
            if(speed>0)
                speed--;
        //Turn ON/OFF
        if(rcmd==RV_ON)
            if(fan_on)
                POWER_LED_OFF();
                fan_on=0;    //Turn Off
                POWER_LED_ON();
                fan_on=1;    //Turn On
        Display(speed);
It is an ATmega8 based dimmer. crystal Oscillator is 16MHz. Please help me.
you need to add two pushbuttons then debounce them. Do a bit of Googling.
I have tried more, but no success. would u help me?
Show what you tried.
You need to read a button, debounce it, adjust the speed, and do this at some reasonable rate (just sitting in a while(1) loop could zoom the speed down to 0 or up to MAX in a single button push unless you regulate how often you respond to the buttons).
Sir, I have added those line but what was the mistake.
#define BUTIN() (PIND & 0x01)==0;
char but;
char butl;
char butos;
void main()
but=BUTIN();
butos=but && !butl;
butl=but;
    Initialize();
        //Seed Up
        if((rcmd==RV_UP)||(butos))
            if(speed<9)
                speed++;
        //Speed Down
        if(rcmd==RV_DOWN)
            if(speed>0)
                speed--;
        //Turn ON/OFF
        if(rcmd==RV_ON)
            if(fan_on)
                POWER_LED_OFF();
                POWER_LED_ON();
                fan_on=1;    //Turn On
        Display(speed);
Also tried
  DDRB &= ~(1<<PINB2);// Input
  PORTB |= 1<<PINB2;  // PIN High
		if(bit_is_clear(PINB, 2))
			if(speed<9)
				speed = speed + 1;
but still failure.
Also tried
			if(speed<9)
				speed = speed + 1;
but still failure.
How exactly does it fail?
Can you write a program that just turns on an LED when you push your button?
Sir,
thanks for ur reply.
#define F_CPU 16000000UL
#include <util/delay.h>
  DDRC |= 1<<PINC4; //Output
  DDRC &= ~(1<<PINC5);// Input
  PORTC |= 1<<PINC5;  // PIN High
  while(1) //infinite loop
    if(bit_is_clear(PINC, 5)) //If switch is pressed
      PORTC |= 1<<PINC4;
	  _delay_ms(100);
	PORTC &= ~(1<<PINC4);;
	      _delay_ms(100);
I have tried it.
