ATMega128 not responding
12 posts / 0 new
Have programmed ATMega128 to flash LED but not responding. Though I have connected a external Crystal of 16MHz, presently on internal at 8MHz. Programming thro AVR studio using AVR ISP2 and takes me thru the process. Only LED not flashing. IOs  though pulled up are not 5V but 1.9V . Reset is also at 5V.
Sorry the crystal ball is in the shop, please post a picture of your setup, and/or provide a schematic and post a small complete program that demos the problem.
As you can see, it is impossible to provide an answer given the info so far....
Some suggestions:
check VCC has been connected to ALL VCC and AVCC pins
check ALL GND pins are connected to ground
check that there is a 0.1 uf (100nf) cap between each pair of VCC/AVCC = Gnd pins
check that you have the proper current limiting resistor in series with each LED (if vcc = 5v, 330 ohm is normal)
All port pins default to inputs, so did you set the DDR register to make your port pin an output?
edit: spelling
Absolutely - although I would say you should definitely post both the schematic and a photograph.
Instructions for posting pictures and code: http://www.avrfreaks.net/comment...
The ATMega128 has on-chip debug - use it!
There is a lot we don't know; some of the questions have already been presented.
Some other common '128 issues:
I'd like to know about ISP connections, and see the log of the "programming".
-- M103C fuse is set by default -- has it been cleared?
-- What clock source is being used for the '128?
-- Is the device ever coming out of reset?
0.1 mfd cap connected between Vcc and GND.LEDs have current limiting resistor (1K). All DDRs are in Output mode (1). PORTs all pulled up. ISP connected to UART and not SPI being 128, to which the programmer (AVR ISP II) is responding. M103 fuse cleared to operate as 128. On internal Oscillator of 8MHz. Reset pin shows 5 Volts.
 AVCC is not connected to 5 Volts as no ADC used. Is it necessary to connect to 5V?
Any more suggestions please.
According to the datasheet, it is strongly suggested you connect this!
Have programmed ATMega128 to flash LED but not responding. ...
...being 128, to which the programmer (AVR ISP II) is responding. ...
So, to be clear, the m128 IS responding; it's just that your code doesn't work?
More?
You haven't supplied what was originally asked yet
  • A schematic (don't mess about trying to describe circuits in words)
  • Code
  • Photograph(s)
Connecting AVcc to 5V made the difference. All pulled up PORT pins showed 5V which was about 0.9 to 2V. The LEDs began to respond indicating ATMega 128 is active.
Thank you all
From the datasheet:
"Read a lot.  Write a lot."
Details, details...
So I nailed it with my first suggestion in reply #2!!!! smiley
