"CHaN fatfs" initialization problem: send_cmd (CMD0) returns 0!!
4 posts / 0 new
Hello, I am working with the CHaN fatfs routines for atmega and I have a problem that is driving me crazy.
I have tested the routines with several 4gb kingnston memories, and there are memories with which they work ok and memories with which they do not. Debugging the code, I found that the error occurs in the process of initializing the memory, because "send_cmd (CMD0)" returns 0 instead of 1. Does anyone have any idea where the problem might be? This is the code of the rutine.
Thanks!!
DSTATUS disk_initialize (
	BYTE drv		/* Physical drive nmuber (0) */
	BYTE n, ty, cmd, buf[4];
	UINT tmr;
	DSTATUS s;
	if (drv) return RES_NOTRDY;
	dly_us(10000);			/* 10ms */
	CS_INIT(); CS_H();		/* Initialize port pin tied to CS */
	CK_INIT(); CK_L();		/* Initialize port pin tied to SCLK */
	DI_INIT();				/* Initialize port pin tied to DI */
	DO_INIT();				/* Initialize port pin tied to DO */
	for (n = 10; n; n--) rcvr_mmc(buf, 1);	/* Apply 80 dummy clocks and the card gets ready to receive command */
	ty = 0;
	if (send_cmd(CMD0, 0) == 1) {			/* Enter Idle state */
		if (send_cmd(CMD8, 0x1AA) == 1) {	/* SDv2? */
			rcvr_mmc(buf, 4);							/* Get trailing return value of R7 resp */
			if (buf[2] == 0x01 && buf[3] == 0xAA) {		/* The card can work at vdd range of 2.7-3.6V */
				for (tmr = 1000; tmr; tmr--) {			/* Wait for leaving idle state (ACMD41 with HCS bit) */
					if (send_cmd(ACMD41, 1UL << 30) == 0) break;
					dly_us(1000);
				if (tmr && send_cmd(CMD58, 0) == 0) {	/* Check CCS bit in the OCR */
					rcvr_mmc(buf, 4);
					ty = (buf[0] & 0x40) ? CT_SD2 | CT_BLOCK : CT_SD2;	/* SDv2 */
		} else {							/* SDv1 or MMCv3 */
			if (send_cmd(ACMD41, 0) <= 1) 	{
				ty = CT_SD1; cmd = ACMD41;	/* SDv1 */
			} else {
				ty = CT_MMC; cmd = CMD1;	/* MMCv3 */
			for (tmr = 1000; tmr; tmr--) {			/* Wait for leaving idle state */
				if (send_cmd(cmd, 0) == 0) break;
				dly_us(1000);
			if (!tmr || send_cmd(CMD16, 512) != 0)	/* Set R/W block length to 512 */
				ty = 0;
	CardType = ty;
	s = ty ? 0 : STA_NOINIT;
	Stat = s;
	deselect();
	return s;
What version are you working with?
I'm using an older version.  So I thought you would be referring to the latest -- the Web site has version 13.  The disk_initialize looks nothing like yours:
	BYTE pdrv				/* Physical drive nmuber to identify the drive */
	DSTATUS stat;
	int result;
	switch (pdrv) {
	case DEV_RAM :
		result = RAM_disk_initialize();
		// translate the reslut code here
		return stat;
	case DEV_MMC :
		result = MMC_disk_initialize();
		return stat;
	case DEV_USB :
		result = USB_disk_initialize();
		return stat;
	return STA_NOINIT;
Gotta love the "reslut" typo:  "She used to be pretty loose, but then got married.  After the divorce, it was reslut time..."
I must be missing something -- why don't I see e.g. MMC_disk_initialize in the downloaded source?
That said, the disk_initialize that I use has substantially the same flow as yours.  But I do slow down the SPI clock rate for disk_initialize...
				if (disk_status(0) & STA_NOINIT)
					// also add checks for PRESENT and WP
					SPCR = SPCR_SD_INIT;
					card_status = disk_initialize(0);
					SPCR = SPCR_SD_RUN;	// return to SD card setup as the default
...where
#define    SPCR_SD_INIT    ((1 << SPE) | (1 << MSTR) | (1 << SPR1))
#define    SPCR_SD_RUN        ((1 << SPE) | (1 << MSTR))
So my only guess:  Try slowing down your SPI during init.
Not sure if it helps but Chan has words about the init sequence under "Initialization Procedure for SPI Mode" on this page in the documentation:
http://elm-chan.org/docs/mmc/mmc...
ISTR that's important:
http://elm-chan.org/docs/mmc/mmc_e.html
On that page, Chan wrote:
Set SPI clock rate between 100 kHz and 400 kHz.
